# API Reference
The complete ZED SDK API reference (every class, method, parameter and enum) for
C++, Python, C# and C. Generated from the SDK source for each release.
## Browse the reference
The full browsable API reference is available at
[stereolabs.com/docs/api](https://www.stereolabs.com/docs/api/).
## For AI agents and LLMs
Each language ships a single, self-contained Markdown file containing the entire
API reference for that language, ideal to load into an AI coding assistant alongside
this documentation's `llms-full.txt` (which provides the concepts, guides and code
samples). Fetch the file for the language you are working in:
* [C++ API reference (Markdown)](https://www.stereolabs.com/docs/api/llms-api-cpp.txt) (≈ 200k tokens)
* [Python API reference (Markdown)](https://www.stereolabs.com/docs/api/llms-api-python.txt) (≈ 130k tokens)
* [C# API reference (Markdown)](https://www.stereolabs.com/docs/api/llms-api-csharp.txt) (≈ 90k tokens)
* [C API reference (Markdown)](https://www.stereolabs.com/docs/api/llms-api-c.txt) (≈ 80k tokens)
Each file is version-stamped and opens with a `## Contents` list of all symbols.
For concepts, tutorials and usage examples, see the documentation
[llms-full.txt](https://docs.stereolabs.com/llms-full.txt).
