# Using the Video API
The ZED API provides low-level access to the camera hardware and video features, facilitating camera control and high-quality video recording and streaming.
## Camera Configuration
To configure the camera, create a `Camera` object and specify your `InitParameters`. Initial parameters let you adjust camera resolution, FPS, depth sensing parameters and more. These parameters can only be set before opening the camera and cannot be changed while the camera is in use.
> `InitParameters` contains a default configuration.
**`C++`**
```cpp C++
// Create a ZED camera object
Camera zed;
InitParameters init_params;
init_params.camera_fps = 30;
// Open the camera
    exit(-1);
**`Python`**
```python Python
# Create a ZED camera object
zed = sl.Camera()
# Set configuration parameters
init_params.camera_resolution = sl.RESOLUTION.HD1080
# Open the camera
    exit(-1)
**`C#`**
```csharp C#
sl.Camera zed = new sl.Camera(0);
sl.InitParameters init_parameters = new sl.InitParameters();
init_parameters.resolution = sl.RESOLUTION.HD1080;
init_parameters.cameraFPS = 30;
// Open the camera
sl.ERROR_CODE err = zed.Open(ref init_parameters);
if (err != sl.ERROR_CODE.SUCCESS)
    Environment.Exit(-1);
Camera settings such as exposure, white balance and others can be manually set at runtime using `setCameraSettings()`.
**`C++`**
```cpp C++
// Set exposure in manual mode at 50% of camera framerate
zed.setCameraSettings(VIDEO_SETTINGS::EXPOSURE, 50);
// Set white balance to 4600K
zed.setCameraSettings(VIDEO_SETTINGS::WHITEBALANCE_TEMPERATURE, 4600);
// Reset to auto exposure
zed.setCameraSettings(VIDEO_SETTINGS::EXPOSURE, -1);
**`Python`**
```python Python
# Set exposure to 50% of camera framerate
zed.set_camera_settings(sl.VIDEO_SETTINGS.EXPOSURE, 50)
# Set white balance to 4600K
zed.set_camera_settings(sl.VIDEO_SETTINGS.WHITEBALANCE_TEMPERATURE, 4600)
# Reset to auto exposure
zed.set_camera_settings(sl.VIDEO_SETTINGS.EXPOSURE, -1)
**`C#`**
```csharp C#
zed.SetCameraSettings(sl.VIDEO_SETTINGS.EXPOSURE, 50);
zed.SetCameraSettings(sl.VIDEO_SETTINGS.WHITEBALANCE_TEMPERATURE, 4600);
//Reset to auto exposure
zed.SetCameraSettings(sl.VIDEO_SETTINGS.EXPOSURE, -1);
To see the list of available video modes and settings, read [Camera Controls](/docs/development/zed-sdk/modules/camera/camera-controls/).
## Image Capture
To capture images from the ZED, specify your `RuntimeParameters` and call `grab()` to grab a new frame and `retrieveImage()` to retrieve the grabbed frame. `retrieveImage()` lets you select between different views such as left, right, unrectified and grayscale images.
**`C++`**
```cpp C++
sl::Mat image;
    // A new image is available if grab() returns SUCCESS
    zed.retrieveImage(image, VIEW::LEFT); // Retrieve the left image
**`Python`**
```python Python
image = sl.Mat()
runtime_parameters = sl.RuntimeParameters()
if zed.grab(runtime_parameters) == sl.ERROR_CODE.SUCCESS:
    # A new image is available if grab() returns SUCCESS
    zed.retrieve_image(image, sl.VIEW.LEFT) # Retrieve the left image
**`C#`**
```csharp C#
sl.Mat image = new sl.Mat();
uint mWidth = (uint)zed.ImageWidth;
uint mHeight = (uint)zed.ImageHeight;
image.Create(mWidth, mHeight, MAT_TYPE.MAT_8U_C4, MEM.CPU); // Mat needs to be created before use.
    zed.RetrieveImage(image, sl.VIEW.LEFT); // Retrieve the left image
## Video Recording
The ZED SDK uses StereoLabs' SVO format to store videos along with additional metadata such as timestamps and sensor data. An SVO file only holds the raw unrectified images and the sensor data: depth, rectification and all other processing are performed live by the ZED SDK when the file is played back. See [What an SVO File Contains](/docs/development/zed-sdk/modules/camera/recording#what-an-svo-file-contains) for details.
To record SVO files, you need to enable the Recording module with `enableRecording()`. Specify an output file name (eg: *output.svo*) and `SVO_COMPRESSION_MODE`, then then call `grab()`: each grabbed frame is added to the SVO file. SVO lets you record video and associated metadata (timestamp, IMU data and more if available).
**`C++`**
```cpp C++
// Create and open a ZED camera object
Camera zed;
ERROR_CODE err = zed.open(init_parameters);
    exit(-1);
// Enable recording with the filename specified in argument
String output_path(argv[1]);
RecordingParameters recordingParameters;
recordingParameters.compression_mode = SVO_COMPRESSION_MODE::H264;
recordingParameters.video_filename = output_path;
err = zed.enableRecording(recordingParameters);
while (!exit_app) {
    // Each new frame is added to the SVO file
    zed.grab();
// Disable recording
zed.disableRecording();
**`Python`**
```python Python
# Create and open a ZED camera object
zed = sl.Camera()
init_parameters = sl.InitParameters()
    exit(-1)
# Enable recording with the filename specified in argument
output_path = sys.argv[1]
recordingParameters = sl.RecordingParameters()
recordingParameters.compression_mode = sl.SVO_COMPRESSION_MODE.H264
err = zed.enable_recording(recordingParameters)
while not exit_app:
    # Each new frame is added to the SVO file
    zed.grab()
# Disable recording
zed.disable_recording()
**`C#`**
```csharp C#
sl.RuntimeParameters runtimeParameters = new sl.RuntimeParameters();
string output_path = args[0];
sl.RecordingParameters recordingParameters = new sl.RecordingParameters();
recordingParameters.compressionMode = sl.SVO_COMPRESSION_MODE.H264_BASED;
recordingParameters.videoFilename = output_path;
err = zed.EnableRecording(recordingParameters);
while (!exit_app) {
    zed.Grab(ref runtimeParameters);
zed.DisableRecording();
## Video Playback
To play SVO files, simply add the file path as an argument in `setFromSVOFile()`.  When loading SVO files, the ZED API will behave as if a ZED was connected and a live feed was available. Every module of the ZED API will be available: depth, tracking, spatial mapping and more, regardless of what was enabled during the recording session. When an SVO file is read entirely, `END_OF_SVOFILE_REACHED` error code is returned.
**`C++`**
```cpp C++
Camera zed;
// Set SVO path for playback
String input_path(argv[1]);
init_parameters.input.setFromSVOFile(input_path);
// Open the ZED
sl::Mat svo_image;
while (!exit_app) {
    ERROR_CODE grab_status = zed.grab();
    if (grab_status == ERROR_CODE::SUCCESS) {
        // Read side by side frames stored in the SVO
        zed.retrieveImage(svo_image, VIEW::SIDE_BY_SIDE);
        // Get frame count
        int svo_position = zed.getSVOPosition();
    else if (grab_status == ERROR_CODE::END_OF_SVOFILE_REACHED) {
        std::cout << "SVO end has been reached. Looping back to first frame" << std::endl;
        zed.setSVOPosition(0);
**`Python`**
```python Python
zed = sl.Camera()
# Set SVO path for playback
input_path = sys.argv[1]
init_parameters.set_from_svo_file(input_path)
# Open the ZED
svo_image = sl.Mat()
while not exit_app:
    if grab_status == sl.ERROR_CODE.SUCCESS:
        # Read side by side frames stored in the SVO
        zed.retrieve_image(svo_image, sl.VIEW.SIDE_BY_SIDE)
        # Get frame count
        svo_position = zed.get_svo_position()
    elif grab_status == sl.ERROR_CODE.END_OF_SVOFILE_REACHED:
        print("SVO end has been reached. Looping back to first frame")
        zed.set_svo_position(0)
**`C#`**
```csharp C#
string input_path = args[0];
init_parameters.inputType = sl.INPUT_TYPE.SVO;
init_parameters.pathSVO = input_path;
// Open the ZED
sl.Mat svo_image = new sl.Mat();
svo_image.Create(mWidth * 2, mHeight, MAT_TYPE.MAT_8U_C4, MEM.CPU); // Mat needs to be created before use.
while (!exit_app) {
    if (zed.Grab(ref runtimeParameters) == sl.ERROR_CODE.SUCCESS) {
        zed.RetrieveImage(svo_image, sl.VIEW.SIDE_BY_SIDE, sl.MEM.CPU);
        // Get frame count
        int svo_position = zed.GetSVOPosition();
    if (zed.GetSVOPosition() >= zed.GetSVONumberOfFrames() - 1) {
        Console.WriteLine("SVO end has been reached. Looping back to first frame");
        zed.SetSVOPosition(0);
## Local Streaming
To learn how to stream stereo video on the local network using the ZED SDK, read [Local Streaming](/docs/development/zed-sdk/modules/camera/local-network-streaming/) section.
## Code Examples
Get started with stereo video capture, recording and streaming using the following code samples on GitHub:
* [Camera Control](https://github.com/stereolabs/zed-sdk/tree/master/camera%20control)
* [SVO Recording](https://github.com/stereolabs/zed-sdk/tree/master/recording/recording), [SVO Playback](https://github.com/stereolabs/zed-sdk/tree/master/recording/playback) and [SVO Export](https://github.com/stereolabs/zed-sdk/tree/master/recording/export)
* [Camera Streaming](https://github.com/stereolabs/zed-sdk/tree/master/camera%20streaming)
