# Multi-Camera Tracking
Since [ZED SDK 5.6](/docs/development/zed-sdk/release-notes/5-x/5-6), several ZED and ZED One cameras mounted on the same rigid body can be tracked together, as one rig, with a single shared map. This multi-camera SLAM runs through the Sensors API (`sl::Sensors`), with `PositionalTrackingSensorsParameters::multi_sensor_mode` set to `MULTI_SENSOR_TRACKING_MODE::SINGLE_BODY`.
> The Sensors API is in beta: its interfaces and behavior may change in future ZED SDK releases. Multi-camera tracking is available in the C++ and Python APIs.
## Tracking Modes
| Mode                                      | Behavior        |
| `MULTI_SENSOR_TRACKING_MODE::AUTO`        | Default. The ZED SDK chooses; it currently resolves to `PER_SENSOR`.                |
| `MULTI_SENSOR_TRACKING_MODE::PER_SENSOR`  | Each ZED stereo camera tracks on its own, with its own map.                         |
| `MULTI_SENSOR_TRACKING_MODE::SINGLE_BODY` | The ZED stereo and ZED One cameras are tracked as one rig with a single shared map. |
`Sensors::getMultiSensorTrackingMode()` returns the mode the tracking actually runs in.
## Requirements
* `POSITIONAL_TRACKING_MODE::GEN_3`.
* At least one ZED stereo camera, and up to 8 cameras in total. LiDARs cannot be part of the rig.
* All cameras at the same resolution and frame rate, sharing one CUDA context (see `InitSensorsParameters::sdk_cuda_ctx`).
* Hardware-synchronized cameras, whose simultaneous images are captured within 1.5 ms of each other. This is checked on the first images: if it fails, an error is logged and the pose stays `POSITIONAL_TRACKING_STATE::UNAVAILABLE`. See [Frame synchronization](/docs/development/zed-sdk/modules/camera/multi-camera#frame-synchronization).
* The pose of each camera on the rig, set with `Sensors::setSensorPose()` before enabling the tracking. It is expressed in the BASELINK frame of the rig, in the `coordinate_units` and `coordinate_system` of `InitSensorsParameters`.
`enablePositionalTracking()` returns `SENSORS_ERROR_CODE::INVALID_FUNCTION_PARAMETERS` when the mode is not `GEN_3`, when the rig contains a LiDAR, no ZED stereo camera or more than 8 cameras, when the cameras do not share one resolution, frame rate and CUDA context, or when `tracking_camera_id` is not a ZED stereo camera of the rig. The hardware synchronization is checked on the first images instead, as described above.
## How It Works
* One ZED stereo camera, set by `PositionalTrackingSensorsParameters::tracking_camera_id` (by default the first ZED stereo camera added), drives the tracking of the rig: its IMU is the one fused, and its pose places the rig in the world.
* Each ZED One adds its images to the shared map and moves with the rig through its sensor pose.
* The tracking of each sensor starts at its sensor pose, so the WORLD frame matches the BASELINK frame at start, unless you set `initial_world_transforms`. In `SINGLE_BODY` mode, only the `initial_world_transforms` entry of the tracking camera is used.
* `getPosition()` in `SENSORS_REFERENCE_FRAME::WORLD` returns the pose of a sensor in the world frame. `SENSORS_REFERENCE_FRAME::SENSOR` returns its motion since the previous frame in its own axes, and `SENSORS_REFERENCE_FRAME::BASELINK` the same motion in the BASELINK axes.
* `saveAreaMap()` saves the shared map, with the position of each camera on the rig. Area files in this format cannot be loaded by ZED SDK 5.5 or earlier.
## Using the API
```cpp
sl::Sensors sensors;
sl::InitSensorsParameters init_parameters;
init_parameters.coordinate_units = sl::UNIT::METER;
sensors.init(init_parameters);
// Add the cameras of the rig: hardware-synchronized, same resolution and frame rate
sl::SensorDeviceIdentifier zed_id, zed_one_id;
sl::InitParameters zed_parameters;
zed_parameters.input.setFromSerialNumber(zed_serial_number);
sensors.add(zed_parameters, zed_id);
sl::InitParametersOne zed_one_parameters;
zed_one_parameters.input.setFromSerialNumber(zed_one_serial_number);
sensors.add(zed_one_parameters, zed_one_id);
// Pose of each camera on the rig, in the BASELINK frame, set before enabling the tracking
sensors.setSensorPose(zed_pose_on_rig, zed_id);
sensors.setSensorPose(zed_one_pose_on_rig, zed_one_id);
sl::PositionalTrackingSensorsParameters tracking_parameters;
tracking_parameters.mode = sl::POSITIONAL_TRACKING_MODE::GEN_3;
tracking_parameters.multi_sensor_mode = sl::MULTI_SENSOR_TRACKING_MODE::SINGLE_BODY;
tracking_parameters.tracking_camera_id = zed_id;
sensors.enablePositionalTracking(tracking_parameters);
sl::Pose pose;
while (sensors.process() == sl::SENSORS_ERROR_CODE::SUCCESS) {
    // Pose of the tracking camera in the world frame
    sl::POSITIONAL_TRACKING_STATE state = sensors.getPosition(pose, sl::SENSORS_REFERENCE_FRAME::WORLD, zed_id);
## Using a Motion Prior
`Sensors::ingestMotionPrior()` feeds your own motion source to the Sensors API tracking, like [`Camera::ingestMotionPrior()`](/docs/development/zed-sdk/modules/positional-tracking/using-the-api#using-a-motion-prior). The difference is `RelativePoseData::sensor_transform`: it is the pose of your source in the BASELINK frame, not in the frame of a camera.
* In `SINGLE_BODY` mode, the motion is given to the rig: call it once per sample, with the default identifier or any camera of the rig.
* In `PER_SENSOR` mode, the motion is given to the camera named by `sensors_id` only: call it for each camera that should use the source.
## Sample
ZED SDK 5.6 adds a C++ sample for this mode. It runs from live cameras, SVO files or streams listed in a YAML file and shows the rig, its path and the shared map in 3D. See the [Positional Tracking samples](/docs/samples/positional-tracking).
