# Supported Platforms
> Check which Windows, Ubuntu, JetPack and L4T versions, NVIDIA GPUs and CUDA versions the ZED SDK 5.6 and ZED X Driver 1.5 support, per ZED Link card and ZED Box.
This page lists the platforms supported by the latest releases: **ZED SDK 5.6** and **ZED X Driver 1.5.0**, both released on November 16, 2026. It is updated with every release.
What you need:
* **On a PC:** a ZED SDK installer for your operating system and CUDA version, and a [supported NVIDIA® GPU](#nvidia-gpus).
* **On an NVIDIA® Jetson™:** a ZED SDK installer for your Jetson™ Linux (L4T) version.
* **With ZED X family cameras** (ZED X, ZED X Mini, ZED X Nano, ZED X One, ZED X One Core): a [ZED X Driver](#zed-x-driver) for your capture card or ZED Box and your L4T version.
Download the installers from the [ZED SDK release page](https://www.stereolabs.com/developers/release) and the drivers from the [ZED X Camera Drivers](https://www.stereolabs.com/developers/drivers) page.
## Check the versions installed on your system
| To check                    | Command        |
| Jetson™ Linux (L4T) version | `cat /etc/nv_tegra_release`        |
| JetPack version             | `apt-cache policy nvidia-jetpack`        |
| ZED X Driver version        | `dpkg -l \| grep stereolabs`        |
| NVIDIA® GPU and driver      | `nvidia-smi` (PC only). The CUDA version it shows is the highest one the driver supports, not the installed one. |
| Installed CUDA version      | `nvcc --version` (on Jetson™: `/usr/local/cuda/bin/nvcc --version`)                                              |
The first line of `/etc/nv_tegra_release` gives the L4T version: `# R36 (release), REVISION: 4.3` means L4T 36.4.3.
## PC: Windows and Ubuntu
### Operating systems and CUDA
ZED SDK 5.6 installers:
| Operating system  | CUDA 12, TensorRT 10 | CUDA 12, TensorRT 11 | CUDA 13, TensorRT 10 | CUDA 13, TensorRT 11 |
| Windows 10 and 11 |           ✔          |           ✔          |           ✔          |           ✔          |
| Ubuntu 22.04      |           ✔          |           ✔          |           ✔          |           ✔          |
| Ubuntu 24.04      |           ✔          |           ✔          |           ✔          |           ✔          |
| Ubuntu 26.04      |           ❌          |           ❌          |           ✔          |           ✔          |
Pick the installer that matches the CUDA major version installed on your system.
For NVIDIA® DGX systems such as the DGX Spark, an experimental **DGX OS 7** installer is available. It uses CUDA 13 with TensorRT 10 or 11.
### NVIDIA® GPUs
ZED SDK 5.6 needs an NVIDIA® GPU with a [Compute Capability](https://developer.nvidia.com/cuda-gpus#compute) of **7.5 or higher**, which means Turing or a more recent micro-architecture. This is a requirement of TensorRT 10 and TensorRT 11, used by every ZED SDK 5.6 installer.
| GPU generation                            |   Compute Capability   | ZED SDK 5.6 |
| Blackwell (GeForce RTX 50 series)         | 10.0, 10.3, 12.0, 12.1 |      ✔      |
| Hopper                                    |           9.0          |      ✔      |
| Ada Lovelace (GeForce RTX 40 series)      |           8.9          |      ✔      |
| Ampere (GeForce RTX 30 series)            |        8.0, 8.6        |      ✔      |
| Turing (GeForce RTX 20 and GTX 16 series) |           7.5          |      ✔      |
| Volta                                     |           7.0          |      ❌      |
| Pascal (GeForce GTX 10 series)            |           6.x          |      ❌      |
| Maxwell and older                         |      5.x and lower     |      ❌      |
### Older PC platforms
ZED SDK 5.6 has no installer for the platforms below. Their last installers are available in the [release archive](https://www.stereolabs.com/developers/release/archives).
| Platform        | Last ZED SDK release |
| GPUs with a Compute Capability lower than 7.5, such as the GeForce GTX 10 series (TensorRT 8 installers) |          5.0         |
| Ubuntu 20.04        |          5.0         |
| CUDA 11 with TensorRT 10 (Windows, Ubuntu 22.04)                                                         |          5.1         |
## NVIDIA® Jetson™
### ZED SDK installers
Each Jetson™ installer is built for one L4T version, such as L4T 36.5. It also runs on the later patch versions of it, such as L4T 36.5.2, but stops on any other version. See [Install the ZED SDK on Jetson](/docs/development/zed-sdk/linux/work-with-nvidia-jetson/) for the installation steps.
| JetPack                 | Jetson™ Linux (L4T) | Hardware     | CUDA | Status                                       |
| JetPack 7.2, 7.2.1      | L4T 39.2            | Orin™, Thor™ | 13.2 | Recommended                                  |
| JetPack 6.2.2, 6.2.3    | L4T 36.5            | Orin™        | 12.6 | Supported                                    |
| JetPack 6.1, 6.2, 6.2.1 | L4T 36.4            | Orin™        | 12.6 | Legacy                                       |
| JetPack 7.1             | L4T 38.4            | Thor™        | 13.0 | Legacy                                       |
| JetPack 7.0             | L4T 38.2            | Thor™        | 13.0 | Legacy (beta). No video encoding or decoding |
| IGX OS 2.0              | L4T 38.5            | IGX Thor™    | 13.0 | Legacy                                       |
**Legacy** installers are still built for this release, but they can be dropped in a future release. The JetPack 7.2 installer comes in two variants, with TensorRT 10 or TensorRT 11.
On Jetson™ Thor™, use JetPack 7.2 or newer. JetPack 7.0 and 7.1 have TensorRT issues that the ZED SDK can only work around.
### Older JetPack versions
ZED SDK 5.6 has no installer for the JetPack versions below. Upgrade JetPack, or use an older ZED SDK release from the [release archive](https://www.stereolabs.com/developers/release/archives).
| JetPack               | Jetson™ Linux (L4T)  | Last ZED SDK release |
| JetPack 6.0           | L4T 36.3             |          5.2         |
| JetPack 5.1.2         | L4T 35.4             |          5.2         |
| JetPack 5.1.1         | L4T 35.3             |          5.0         |
| JetPack 5.1, 5.0, 4.6 | L4T 35.2, 35.1, 32.7 |          4.2         |
### ZED X Driver
The ZED X Driver is built for one capture card or ZED Box and one L4T version. Download the package that matches both from the [ZED X Camera Drivers](https://www.stereolabs.com/developers/drivers) page. Each package also comes in a real-time (RT) kernel variant.
| JetPack                 | Jetson™ Linux (L4T) | ZED Link Mono | ZED Link Duo | ZED Link Quad | ZED Link MIPI Quad 1 | ZED Box | ZED Box Mini |   ZED Box 2   |
| JetPack 7.2.1           | L4T 39.2.1          |       ✔       |       ✔      |       ✔       |           ✔          |    ✔    |       ✔      | Coming soon 2 |
| JetPack 6.2.2, 6.2.3    | L4T 36.5, 36.5.2    |       ✔       |       ✔      |       ✔       |           ✔          |    ✔    |       ✔      |       ✔       |
| JetPack 6.1, 6.2, 6.2.1 | L4T 36.4            |       ✔       |       ✔      |       ✔       |           ✔          |    ✔    |       ✔      |       ✔       |
1 *On the Jetson™ AGX Orin™ Developer Kit.*
2 *Fixes are in progress. Until they are released, use JetPack 6.2.x on the ZED Box 2.*
> The ZED X Driver for JetPack 7 is built for JetPack 7.2.1 (L4T 39.2.1) and does not run on L4T 39.2.0. A Jetson™ flashed with JetPack 7.2 runs L4T 39.2.0: upgrade it to L4T 39.2.1 before you install the driver.
> More generally, a new L4T version can change the kernel version, so an `apt upgrade` that installs newer `nvidia-l4t-*` packages can stop the cameras from working. Before you upgrade JetPack, check that a driver exists for the new L4T version.
On the Jetson™ AGX Thor™, the ZED Link MIPI Quad uses the [Holoscan Driver](/docs/development/zed-x-driver/release-notes/holoscan-driver/) 1.0.0, built for L4T 39.2.1, with up to 2 cameras.
The ZED Box 2 Max ships with JetPack 7 and its ZED X Driver pre-installed. Its driver package is not on the drivers page yet.
Drivers for JetPack 6.0 and JetPack 5 remain available on the drivers page as long as NVIDIA® supports these JetPack versions.
### Partner carrier boards and ECUs
Partners' carrier boards and ECUs use drivers built for each device. [Third-Party ECUs](/docs/products/embedded/zed-link-capture-card/gmsl2/third-party-ecus/) lists the certified devices and where to download their drivers. Make sure the driver matches your L4T version and the ZED SDK installer you use.
## Related pages
* [Recommended Specifications](/docs/development/zed-sdk/specifications/): RAM, GPU and connectivity requirements, and the minimum ZED SDK version per camera.
* [Install the ZED SDK on Jetson](/docs/development/zed-sdk/linux/work-with-nvidia-jetson/): installer options, upgrade and uninstall.
* [ZED X Driver release notes](/docs/development/zed-x-driver/release-notes/): changes in every driver release.
* [ZED SDK release notes](/docs/development/zed-sdk/release-notes/): changes in every ZED SDK release.
