# Running ZED SDK in a Docker Container
Docker is the easiest way to set up [ZED SDK](https://www.stereolabs.com/developers/release/) on Linux and NVIDIA® Jetson™. Docker uses containers to create virtual environments that contain all the required dependencies and isolate an installation from the rest of the system.
StereoLabs provides two types of [ZED SDK Docker images](https://hub.docker.com/r/stereolabs/zed) for each release:
* `runtime` images include the minimum dependencies required to run applications using the ZED SDK. Use these images for production.
* `devel` images are ideal for development. They contain all the tools needed to compile an application, including CUDA and the static libraries and headers of the ZED SDK.
## Run a ZED SDK Container
Use the following command:
docker pull stereolabs/zed:[tag]  # Download image with specified tag
docker run --gpus all -it --privileged stereolabs/zed:[tag]  # Start container
The `--gpus all` flag adds all available GPUs to the container, and `--privileged` grants the container permission to access the camera connected via USB.
On NVIDIA® Jetson™, use `--runtime nvidia` instead of `--gpus all`. See [Install on NVIDIA® Jetson™](/docs/integrations/docker/install-on-nvidia-jetson) for the complete setup, including GMSL2 cameras.
