# Set Up Your Device
> First steps after unboxing a ZED camera, ZED Link capture card or ZED Box: connect it, install the ZED X Driver and the ZED SDK, test with the ZED Tools and run your first code.
This page takes you from unboxing to your first application. Find your hardware in the table, then follow its steps. Each step links to the detailed instructions.
| Your hardware        | Path                                                  |
| ZED 2i or ZED Mini (USB 3) on a PC or a Jetson™                                      | [USB camera](#usb-camera-zed-2i-zed-mini)             |
| ZED X, ZED X Mini, ZED X Nano or ZED X One (GMSL2) on a Jetson™ with a ZED Link card | [GMSL2 camera on a Jetson](#gmsl2-camera-on-a-jetson) |
| ZED X One Core (MIPI) with a ZED Link MIPI Quad                                      | [MIPI camera](#mipi-camera-zed-x-one-core)            |
| ZED Box, ZED Box Mini, ZED Box 2 or ZED Box 2 Max                                    | [ZED Box](#zed-box)                                   |
Before you start, check that your operating system, GPU or JetPack version is in [Supported Platforms](/docs/development/zed-sdk/supported-platforms/).
## USB camera (ZED 2i, ZED Mini)
1. **Connect the camera** to a USB 3 port, as described in [ZED 2i and ZED Mini](/docs/products/cameras/zed/#connect-your-camera).
2. **Install the ZED SDK** for your platform: [Windows](/docs/development/zed-sdk/windows/), [Linux](/docs/development/zed-sdk/linux/) or [Jetson™](/docs/development/zed-sdk/linux/work-with-nvidia-jetson/).
3. **Test the camera** with [ZED Explorer](/docs/development/zed-tools/zed-explorer/) for the video and [ZED Depth Viewer](/docs/development/zed-tools/zed-depth-viewer/) for the depth.
4. **Write your first application** with the [Hello ZED](/docs/tutorials/hello-zed/) tutorial.
## GMSL2 camera on a Jetson
GMSL2 is the high-speed serial link of the ZED X family. GMSL2 cameras do not connect over USB: they need a ZED Link capture card on an NVIDIA® Jetson™, a [ZED Box](#zed-box), or a certified [third-party embedded computer (ECU)](/docs/products/embedded/zed-link-capture-card/gmsl2/third-party-ecus/).
1. **Install the capture card and connect the cameras**, with the Jetson™ powered off. Follow the guide for your card and developer kit, listed in [ZED Link GMSL2 capture cards](/docs/products/embedded/zed-link-capture-card/gmsl2/#setting-up-your-system-for-using-a-gmsl2-camera). GMSL2 cameras are not hot-pluggable: after any change, reboot the Jetson™ or restart the ZED X daemon with `sudo systemctl restart zed_x_daemon`.
2. **Install the ZED X Driver** for your capture card and your L4T version. L4T (Jetson™ Linux) is the operating system release installed with JetPack. See [Install and upgrade the drivers](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers/).
3. **Install the ZED SDK** for your JetPack version: [Install the ZED SDK on Jetson™](/docs/development/zed-sdk/linux/work-with-nvidia-jetson/).
4. **Test the cameras** with [ZED Explorer](/docs/development/zed-tools/zed-explorer/). With a stereo camera, also check the depth with [ZED Depth Viewer](/docs/development/zed-tools/zed-depth-viewer/).
5. **Write your first application**:
   * With a ZED X, ZED X Mini or ZED X Nano, follow the [Hello ZED](/docs/tutorials/hello-zed/) tutorial.
   * With a ZED X One, start with the [ZED X One samples](/docs/samples/zed-x-one/), which use the monocular `CameraOne` API. To use two ZED X One cameras as a stereo camera, see [Dual Camera Stereo Vision](/docs/products/cameras/zedxone/dual-camera-stereo-vision/).
To develop on a PC with GMSL2 cameras connected to a Jetson™, stream them over the network: see [Developing with ZED X on a PC](/docs/products/cameras/zedx/development-on-pc/) or [Developing with ZED X One Stereo on a PC](/docs/products/cameras/zedxone/zed-x-one-stereo-on-a-pc/).
## MIPI camera (ZED X One Core)
1. **Set up the ZED Link MIPI Quad**, including the wiring, the driver and the ZED SDK. Follow the guide for your developer kit: [Jetson AGX Orin™](/docs/products/embedded/zed-link-capture-card/mipi/zed-link-mipi-quad/jetson-orin-agx-devkit-setup/), with up to four cameras, or [Jetson AGX Thor™](/docs/products/embedded/zed-link-capture-card/mipi/zed-link-mipi-quad/jetson-agx-thor-devkit-setup/), where the card mounts on an NVIDIA® Holoscan Sensor Bridge, with up to two cameras.
2. **Test the cameras** with [ZED Explorer](/docs/development/zed-tools/zed-explorer/). To use them as monocular cameras or in stereo pairs, see [ZED X One Core](/docs/products/cameras/zedxone-core/#how-to-use-zed-x-one-core).
3. **Write your first application** with the [ZED X One samples](/docs/samples/zed-x-one/), which also apply to the ZED X One Core.
## ZED Box
All ZED Boxes ship with JetPack, the ZED SDK and the ZED X Driver installed.
1. **Connect the cameras, then power on the ZED Box**, and complete the operating system setup. Follow the installation guide of your model: [ZED Box](/docs/products/embedded/zed-box-series/zed-box/installation/), [ZED Box Mini](/docs/products/embedded/zed-box-series/zed-box-mini/installation/), [ZED Box 2](/docs/products/embedded/zed-box-series/zed-box-2/installation/) or [ZED Box 2 Max](/docs/products/embedded/zed-box-series/zed-box-2-max/installation/).
2. **Update the ZED SDK** if a newer release is available for your JetPack version: [Install the ZED SDK on Jetson™](/docs/development/zed-sdk/linux/work-with-nvidia-jetson/).
3. **Test the cameras** with [ZED Explorer](/docs/development/zed-tools/zed-explorer/), and with [ZED Depth Viewer](/docs/development/zed-tools/zed-depth-viewer/) for a stereo camera.
4. **Write your first application** with the [Hello ZED](/docs/tutorials/hello-zed/) tutorial, or the [ZED X One samples](/docs/samples/zed-x-one/) for a ZED X One.
## Before you upgrade JetPack
> On a Jetson™ developer kit with GMSL2 or MIPI cameras, check in [Supported Platforms](/docs/development/zed-sdk/supported-platforms/#zed-x-driver) that a ZED X Driver exists for the new L4T version before you upgrade JetPack with `apt`. Without a matching driver, the cameras can stop working after the upgrade.
> On a ZED Box, change the JetPack version by flashing it, as described in the Reset and Update page of your model.
## Next steps
* **Find the pages for your application:** [Start by Use Case](/docs/getting-started/start-by-use-case/) covers robotics, AI, body tracking, AR/VR and simulation.
* **Learn the ZED SDK modules:** [depth sensing, ZED SLAM (positional tracking), object detection, body tracking and more](/docs/development/zed-sdk/modules/).
* **Run ready-made code:** the [samples](/docs/samples/) cover each module.
* **Fix a problem:** see the troubleshooting page of your product, or contact [support@stereolabs.com](mailto:support@stereolabs.com).
