# How to Install ZED SDK with Docker on NVIDIA® Jetson™
## Setting Up Docker
On NVIDIA® Jetson™, the NVIDIA® Container Runtime lets you build and run GPU-accelerated containers with Docker. Its support is installed with NVIDIA® JetPack™ through the `nvidia-container-toolkit` package.
> On recent JetPack™ releases, Docker itself is not always installed by default. If the `docker` command is missing, [install Docker](/docs/integrations/docker/install-on-linux#setting-up-docker) first.
Check that the NVIDIA® runtime is available to Docker:
sudo docker info | grep -i runtime
# Runtimes: io.containerd.runc.v2 nvidia runc
## Download a ZED SDK Docker Image
To build and run an application with the ZED SDK, you first need to pull a ZED SDK Docker image.
The official ZED SDK Docker images for Jetson™ are hosted in the [StereoLabs DockerHub](https://hub.docker.com/r/stereolabs/zed/) repository. Jetson releases are [tagged](https://hub.docker.com/r/stereolabs/zed/tags/) by ZED SDK and L4T (or JetPack) version. These images are built on top of NVIDIA® L4T container images (such as [l4t-jetpack](https://catalog.ngc.nvidia.com/orgs/nvidia/containers/l4t-jetpack)) and add the ZED SDK library and its dependencies.
The tag format for Jetson images is `stereolabs/zed:<sdk>-<variant>-l4t-r<l4t>` (or `stereolabs/zed:<sdk>-<variant>-jetson-jp<jetpack>`), where `<variant>` is `runtime` or `devel` (the `py-runtime`, `py-devel`, and `tools-devel` variants are also available). For example:
# Generic form: replace the placeholders with the versions matching your board
docker pull stereolabs/zed:<ZED_SDK_version>-runtime-l4t-r<L4T_version>
# Example
docker pull stereolabs/zed:5.5-runtime-l4t-r36.5
> Not every ZED SDK release is published for every L4T version. Browse the [available tags](https://hub.docker.com/r/stereolabs/zed/tags/) and pick the combination that matches your board.
> ***Always make sure the L4T (Linux for Tegra) version of your host system matches the L4T version of the container you are using.*** You can check your host L4T version with `cat /etc/nv_tegra_release` or `dpkg-query --show nvidia-l4t-core`.
## Start a Docker Container
To start a container from a ZED SDK image, use the following command:
docker run --runtime nvidia -it --privileged stereolabs/zed:<container_tag>
The `--runtime nvidia` flag selects the NVIDIA® container runtime so the container can access the GPU, and `--privileged` grants the container access to the camera devices.
For example, replacing `<container_tag>` with the tag matching your host:
docker run --runtime nvidia -it --privileged stereolabs/zed:<ZED_SDK_version>-runtime-l4t-r<L4T_version>
Congratulations, the ZED SDK is now available inside your container!
> **Using a ZED X / ZED X One ([GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2)) camera?** The [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) driver must be installed on the **host** Jetson™. Install the latest version by following [Install the ZED Link driver](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers) or from the [ZED X Camera Drivers](https://www.stereolabs.com/developers/drivers) download page. You will also need to share a few extra volumes when running the container; see [Volumes](/docs/integrations/docker/create-docker-images#volumes).
## Run the ZED Explorer Tool
To verify the installation, we are going to run the ZED Explorer tool. By default, a Docker container can only run command-line applications. On NVIDIA® Jetson™, however, OpenGL, CUDA, and TensorRT are ready to use within the ZED SDK Jetson images.
To enable display output, we simply grant the container access to the X server when running it:
xhost +si:localuser:root  # allow containers to communicate with the X server
docker run -it --runtime nvidia --privileged -e DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix stereolabs/zed:<container_tag>
* `--runtime nvidia` selects the NVIDIA® container runtime.
* `-v /tmp/.X11-unix:/tmp/.X11-unix` lets the container access the display.
* `-e DISPLAY` makes your `DISPLAY` environment variable available inside the container.
* `<container_tag>` must be replaced with the tag of the image you want to use.
You can now run any GUI application in the container. Let's launch ZED Explorer:
/usr/local/zed/tools/ZED_Explorer
You should now see the ZED Explorer GUI running on your display from within a Docker container!
## Run a Sample Application
In this example, we will build and run the Depth Sensing sample available in the ZED SDK samples folder.
apt update && apt install cmake -y
cp -r /usr/local/zed/samples/depth\ sensing/depth\ sensing/ /tmp/depth-sensing
cd /tmp/depth-sensing/cpp ; mkdir build ; cd build
cmake .. && make
./ZED_Depth_Sensing
> Compiling on a Jetson™ board can be slow. We recommend [building your image on an x86 host](/docs/integrations/docker/create-images-for-nvidia-jetson) and running it on the Jetson™, especially for resource-constrained boards such as the NVIDIA® Jetson™ Orin™ Nano. See [Creating a Docker Image for your ZED Application](/docs/integrations/docker/create-docker-images) to get started.
