# GStreamer - ZED RTSP Server
The **R**eal **T**ime **S**treaming **P**rotocol (**RTSP**) is a network control protocol designed for use in entertainment and communications systems to control streaming media servers. The protocol is used for establishing and controlling media sessions between endpoints.
**ZED RTSP Server** is a GStreamer application for the Linux operating system that allows instantiating an RTSP server from a text launch pipeline using the "gst-launch" style.
The ZED RTSP server listens for connection requests on a TCP/IP port and allows the delivery of several ZED media streams simultaneously and independently of each other.
## Usage
The RTSP Server can be started with the following command:
 gst-zed-rtsp-launch [OPTION?] PIPELINE-DESCRIPTION
Help Options:
* `-h`, `--help` -> Show help options.
* `--help-all` -> Show all help options.
* `--help-gst` -> Show GStreamer Options.
Application Options:
* `-p`, `--port=PORT` -> Port to listen on (default: 8554).
* `-a`, `--address=HOST` -> Host address (default: 127.0.0.1).
### Example
Acquire a ZED stream using the default configuration, and provide RTSP connection streams using H264 encoding:
gst-zed-rtsp-launch zedsrc ! videoconvert ! 'video/x-raw, format=(string)I420' ! x264enc ! rtph264pay pt=96 name=pay0
A console log provides information about the RTSP server address at which an RTSP-capable client can connect to acquire the ZED stream:
 ZED RTSP Server
 * Stream ready at rtsp://127.0.0.1:8554/zed-stream
> It is mandatory to define at least one payload named `pay0`; it is possible to define multiple payloads using an increasing index (i.e. `pay1`, `pay2`, ...).
> By default, the server only listens on `127.0.0.1`, so it is reachable only from the same machine. To accept connections from other machines on the network, start it with `-a 0.0.0.0` (or the IP address of the network interface to use).
A client can be created using GStreamer with the standard `gst-launch` application:
gst-launch-1.0 rtspsrc location=rtsp://${SERVER_IP}:8554/zed-stream latency=0 ! decodebin ! fpsdisplaysink
The `decodebin` element automatically creates the required pipeline to decode the incoming stream and convert it for the `fpsdisplaysink` sink element.
