# GStreamer - ZED Data mux
The **ZED Data Mux**, `zeddatamux` GStreamer element, allows adding [ZED Metadata](/docs/integrations/gstreamer/zed-metadata/) to a ZED video stream. This is useful if the metadata is removed by a transform filter element that does not automatically propagate it.
The `zeddatamux` element has the following pads:
* `sink_video`: sink pad receiving a video stream compatible with the ZED caps
* `sink_data`: sink pad receiving the `application/data` metadata stream generated by the `src_data` pad of a [`zeddemux` element](/docs/integrations/gstreamer/zed-demux)
* `src`: source pad pushing the video stream with the metadata attached
## Properties
The element defines no specific property. `gst-inspect-1.0 zeddatamux` only reports the `name` and `parent` properties inherited from `GstObject`:
  name                : The name of the object
                        String. Default: "zeddatamux0"
  parent              : The parent of the object
                        Object of type "GstObject"
## Example pipelines
### Inject ZED metadata information in a stream
Example pipeline that resizes the 2K RGB and depth streams to VGA resolution for display purposes, remuxing the Object Detection metadata as input for the [`zedodoverlay` element](/docs/integrations/gstreamer/zed-od-overlay/):
gst-launch-1.0 zeddatamux name=mux \
 zedsrc stream-type=4 camera-resolution=0 camera-fps=15 od-detection-model=0 od-enabled=true ! \
 zeddemux stream-data=true is-depth=true name=demux \
 demux.src_aux ! queue ! autovideoconvert ! videoscale ! video/x-raw,width=672,height=376 ! queue ! fpsdisplaysink \
 demux.src_data ! mux.sink_data \
 demux.src_left ! queue ! videoscale ! video/x-raw,width=672,height=376 ! mux.sink_video \
 mux.src ! queue ! zedodoverlay ! queue ! \
 autovideoconvert ! fpsdisplaysink
![Pipeline graph: zeddemux splits the stream into a rescaled depth display branch, a rescaled left branch and a metadata branch, both recombined by zeddatamux before zedodoverlay](/_fern-files/stereolabs.docs.buildwithfern.com/863f7c4e8bac338ed0f1cbeed8597dff08a50fc136ddda5fe185d2f917960d30/docs/software-integration/gstreamer/images/datamux_pipeline.svg)
* **Line 1**: a `zeddatamux` element is defined with the name `mux`.
* **Line 2**: the `zedsrc` element is configured to acquire Left and Depth data with HD2K resolution at 15 FPS, enabling Object Detection with the MULTI-CLASS FAST model.
* **Line 3**: a `zeddemux` element is defined to split the pipeline into 3 separate branches: one to process the Left Color stream, one to process the Depth stream, and one with binary data created from the Sensors and Detected Objects metadata, which is injected into the `mux` element.
* **Line 4**: the depth stream is processed by a `videoscale` transform filter element to reduce the size of the image and is finally displayed on the screen with FPS info.
* **Line 5**: the metadata stream from the `src_data` pad of `demux` is injected into the `sink_data` pad of the `mux` element.
* **Line 6**: the left stream is processed by a `videoscale` transform filter element to reduce the size of the image and is injected into the `sink_video` pad of the `mux` element.
* **Line 7**: the muxed stream from the `mux` element is processed by the `zedodoverlay` transform filter element to draw object detection data.
* **Line 8**: the object detection result is converted and displayed on screen with FPS info.
The `zeddatamux` element is important to ensure that the stream filtered by `zedodoverlay` contains the Object Detection metadata, which could be removed from the original ZED stream by the `videoscale` transform filter if it does not handle this kind of metadata.
> The ZED metadata is designed to handle scaling transformations of the image stream; in this particular case, the object bounding boxes are rendered correctly even if the filtered images have a size different from the grabbed frames.
