# GStreamer - ZED X One Camera Source
The GStreamer element **ZED X One Camera Source**, `zedxonesrc`, injects the monocular color stream of a ZED X One camera into a GStreamer pipeline.
## Properties
> `zedxonesrc` is built and installed only on NVIDIA® Jetson™ platforms (L4T 35.3/35.4 or L4T 36.3 and newer), because the ZED X One cameras are connected through a GMSL2 capture card.
The following listing is the output of `gst-inspect-1.0 zedxonesrc`:
  async-grab-camera-recovery: Async Grab Camera Recovery
                        flags: readable, writable
                        Boolean. Default: false
  blocksize           : Size in bytes to read per buffer (-1 = default)
                        Unsigned Integer. Range: 0 - 4294967295 Default: 4096
  camera-flip         : Mirror image vertically if camera is flipped
  camera-fps          : Camera frame rate
                        Enum "GstZedXOneSrcFPS" Default: 30, "30  FPS"
                           (120): 120 FPS          - Only with SVGA. Not with ZED X One 4K
                           (60): 60  FPS          - Not available with 4K mode
                           (30): 30  FPS          - Available with all the resolutions
                           (15): 15  FPS          - Available with all the resolutions
  camera-id           : Select camera from cameraID
                        Integer. Range: -1 - 255 Default: -1
  camera-resolution   : Camera Resolution
                        Enum "GstZedXOneSrcResol" Default: 2, "HD1200"
                           (4): 4K               - 3840x2160 (only ZED X One 4K)
                           (3): QHDPLUS          - 3200x1800 (only ZED X One 4K)
                           (2): HD1200           - 1920x1200
                           (1): HD1080           - 1920x1080
                           (0): SVGA             - 960x600 (only ZED X One GS)
  camera-sn           : Select camera from the serial number
                        Integer64. Range: 0 - 999999999 Default: 0
  camera-timeout      : Connection opening timeout in seconds
                        Float. Range:             0.5 -           86400 Default:               5
  coordinate-system   : SDK Coordinate System
                        Enum "GstZedXOneSrcCoordSys" Default: 0, "IMAGE"
                           (0): IMAGE            - Standard image (0,0) at top left corner
                           (1): LEFT_HANDED_Y_UP - Left handed, Y up and Z forward
                           (2): RIGHT_HANDED_Y_UP - Right handed, Y up and Z backward
                           (3): RIGHT_HANDED_Z_UP - Right handed, Z up and Y forward
                           (4): LEFT_HANDED_Z_UP - Left handed, Z up and Y forward
                           (5): RIGHT_HANDED_Z_UP_X_FWD - Right handed, Z up and X forward
  coordinate-units    : SDK Coordinate Units
                        Enum "GstZedXOneSrcUnit" Default: 0, "MILLIMETER"
                           (0): MILLIMETER       - Millimeter
                           (1): CENTIMETER       - Centimeter
                           (2): METER            - Meter
                           (3): INCH             - Inch
                           (4): FOOT             - Foot
  ctrl-analog-gain    : Camera control: Analog Gain value
                        Integer. Range: 1000 - 30000 Default: 30000
  ctrl-auto-analog-gain: Enable Automatic Analog Gain
                        Boolean. Default: true
  ctrl-auto-analog-gain-range-max: Maximum Analog Gain for the automatic analog gain setting
  ctrl-auto-analog-gain-range-min: Minimum Analog Gain for the automatic analog gain setting
                        Integer. Range: 1000 - 30000 Default: 1000
  ctrl-auto-digital-gain: Enable Automatic Digital Gain
  ctrl-auto-digital-gain-range-max: Maximum Digital Gain for the automatic digital gain setting
                        Integer. Range: 1 - 256 Default: 256
  ctrl-auto-digital-gain-range-min: Minimum Digital Gain for the automatic digital gain setting
                        Integer. Range: 1 - 256 Default: 1
  ctrl-auto-exposure  : Enable Automatic Exposure
  ctrl-auto-exposure-range-max: Maximum exposure time in microseconds for the automatic exposure setting
                        Integer. Range: 28 - 66666 Default: 66666
  ctrl-auto-exposure-range-min: Minimum exposure time in microseconds for the automatic exposure setting
                        Integer. Range: 28 - 66666 Default: 1024
  ctrl-denoising      : Denoising factor
                        Integer. Range: 0 - 100 Default: 50
  ctrl-digital-gain   : Digital Gain value
                        Integer. Range: 1 - 256 Default: 3
  ctrl-exposure-compensation: Exposure Compensation
  ctrl-exposure-time  : Exposure time in microseconds
                        Integer. Range: 28 - 66666 Default: 10000
  ctrl-gamma          : Image gamma
                        Integer. Range: 1 - 9 Default: 2
  ctrl-saturation     : Image saturation
                        Integer. Range: 0 - 8 Default: 4
  ctrl-sharpness      : Image sharpness
                        Integer. Range: 0 - 8 Default: 1
  ctrl-whitebalance-auto: Image automatic white balance
  ctrl-whitebalance-temperature: Image white balance temperature
                        Integer. Range: 2800 - 6500 Default: 4200
  do-timestamp        : Apply current stream time to buffers
  enable-hdr          : Enable HDR if supported by resolution and frame rate.
  input-stream-ip     : Specify IP address when using streaming input
                        String. Default: ""
  input-stream-port   : Specify port when using streaming input
                        Integer. Range: 1 - 65535 Default: 30000
  name                : The name of the object
                        String. Default: "zedxonesrc0"
  num-buffers         : Number of buffers to output before sending EOS (-1 = unlimited)
                        Integer. Range: -1 - 2147483647 Default: -1
  opencv-calibration-file: Optional OpenCV Calibration File
                        String. Default: ""
  optional-settings-path: Optional Settings Path
                        String. Default: ""
  output-rectified-image: Enable image rectification (disable for custom optics without calibration)
  parent              : The parent of the object
                        Object of type "GstObject"
  sdk-verbose-log-file: SDK Verbose Log File
                        String. Default: ""
  stream-type         : Image stream type
                        Enum "GstZedXOneSrcStreamType" Default: -1, "Auto [prefer NV12 zero-copy]"
                           (-1): Auto [prefer NV12 zero-copy] - Auto-negotiate format based on downstream (prefer NV12 zero-copy)
                           (0): Image [BGRA]     - 8 bits- 4 channels image
  svo-file-path       : Input from SVO file
                        String. Default: ""
  svo-real-time-mode  : SVO Real Time Mode
  svo-recording-compression: Compression mode for SVO recording
                        Enum "GstZedXOneSrcSvoCompression" Default: 2, "H265"
                           (0): LOSSLESS         - Lossless (PNG/ZSTD, CPU)
                           (1): H264             - H264 (GPU)
                           (2): H265             - H265/HEVC (GPU)
                           (3): H264_LOSSLESS    - H264 Lossless (GPU)
                           (4): H265_LOSSLESS    - H265 Lossless (GPU)
  svo-recording-enable: Start/stop SVO recording at runtime (requires svo-recording-filename to be set)
  svo-recording-filename: Output filename for SVO recording (.svo2 extension recommended)
                        String. Default: ""
  typefind            : Run typefind before negotiating (deprecated, non-functional)
                        flags: readable, writable, deprecated
  verbose-level       : ZED SDK Verbose level
                        Integer. Range: 0 - 999 Default: 1
### Zero-copy NV12 stream type
When the plugin is built against ZED SDK v5.2 or newer, `stream-type` exposes an additional value `(1)`, `Raw NV12 zero-copy [NV12]`, that pushes NV12 buffers in `memory:NVMM` without any CPU copy, for direct consumption by the Jetson hardware encoders.
The default value `(-1)`, `Auto [prefer NV12 zero-copy]`, negotiates the format with the downstream element and selects the zero-copy NV12 path when it is available, falling back to `Image [BGRA]` otherwise.
## Example pipelines
### Display the color stream on the screen with FPS information
This simple pipeline starts the ZED X One grabbing using the default parameters of the `zedxonesrc` element and automatically converts ([autovideoconvert](https://gstreamer.freedesktop.org/documentation/autoconvert/autovideoconvert.html?gi-language=c)) the frames to the correct format for the `fpsdisplaysink` element in order to be displayed on the screen with FPS information.
gst-launch-1.0 zedxonesrc ! queue ! autovideoconvert ! queue ! fpsdisplaysink
The [queue](https://gstreamer.freedesktop.org/documentation/coreelements/queue.html?gi-language=c) element is used to decouple frames in a different queue thread, useful for data synchronization for more complex pipelines.
When using the **ZED X One 4K** model, you can leverage the *full 4K* resolution (3840x2160) by selecting `camera-resolution=4`:
gst-launch-1.0 zedxonesrc camera-resolution=4 camera-fps=15 ! queue ! autovideoconvert ! queue ! fpsdisplaysink
The intermediate *QHD+* resolution (3200x1800), also exclusive to the ZED X One 4K, is selected with `camera-resolution=3`:
gst-launch-1.0 zedxonesrc camera-resolution=3 camera-fps=30 ! queue ! autovideoconvert ! queue ! fpsdisplaysink
When using the **ZED X One GS** model, you can stream frames at *1200p* resolution (`camera-resolution=2`, the default) with *60 Hz* frequency:
gst-launch-1.0 zedxonesrc camera-resolution=2 camera-fps=60 ! queue ! autovideoconvert ! queue ! fpsdisplaysink
