> For clean Markdown of any page, append .md to the page URL. > For a complete documentation index, see https://docs.stereolabs.com/docs/integrations/isaac-ros/april-tag-detection/llms.txt. > For AI client integration (Claude Code, Cursor, etc.), connect to the MCP server at https://docs.stereolabs.com/_mcp/server. # Tutorial - AprilTag Detection with ZED and Isaac™ ROS This tutorial demonstrates how to create an Isaac™ ROS application using AprilTag detection as example. It assumes you have already set up the ZED camera and are publishing its data using the `zed-ros2-wrapper` packages as described in the [Setting up Isaac™ ROS to work with ZED Cameras in ROS 2](/docs/integrations/isaac-ros/setup-and-installation/) section. The application will subscribe to the ZED camera's image stream, convert the ZED images to a supported format, and finally process the images to detect AprilTags, and publish the detected tags' information. ![image](/_fern-img/4fa74ef2071cdfe1792ee3353812067fb27127496be85a3822084b5d09df68de.webp) The example leverages the [NITROS communication framework](/docs/integrations/isaac-ros/#nitros-support) for efficient data exchange between the ZED camera and the AprilTag detection module through the GPU memory without unnecessary data copies on CPU. > **Note** > > It is not required to rectify the images for AprilTag detection, because the ZED Wrapper component handles any necessary image preprocessing in the GPU memory through the ZED SDK. Please refer to the official NVIDIA® documentation for more details on the [Image Format Converter](https://nvidia-isaac-ros.github.io/v/release-3.2/repositories_and_packages/isaac_ros_image_pipeline/isaac_ros_image_proc/index.html#imageformatconverternode) and [AprilTag](https://nvidia-isaac-ros.github.io/v/release-3.2/repositories_and_packages/isaac_ros_apriltag/index.html) Isaac™ ROS nodes. ![image](/_fern-img/3a89c8e580fd59eeec2c9674d2a45b98eba7baca29d3a8737d9a046f37d55e79.webp) ## Setup the example If you haven't done so already, set up your development environment by following our [NVIDIA® Isaac™ ROS installation guide](/docs/integrations/isaac-ros/setup-and-installation/). Install the `ZED ROS2 Examples` packages in the workspace: ```bash cd ${ISAAC_ROS_WS}/src && \ git clone https://github.com/stereolabs/zed-ros2-examples.git ``` If you are using Docker, start the Isaac™ ROS environment with ZED support: ```bash cd ${ISAAC_ROS_WS}/src/isaac_ros_common && \ ./scripts/run_dev.sh -i ros2_humble.zed \ -a "-v /usr/local/zed/settings:/usr/local/zed/settings \ -v /usr/local/zed/resources:/usr/local/zed/resources" ``` Install the Isaac™ ROS AprilTag and Image Process packages in the workspace: ```bash sudo apt-get update && \ sudo apt-get install -y ros-humble-isaac-ros-apriltag ros-humble-isaac-ros-image-proc ``` Build the AprilTag detection application: ```bash cd ${ISAAC_ROS_WS} && \ colcon build --symlink-install --packages-above zed_isaac_ros_april_tag ``` ## Run the AprilTag detection application Before running the AprilTag detection application you must configure the example. ```bash cd ${ISAAC_ROS_WS}/src/zed-ros2-examples/isaac_ros/zed_isaac_ros_april_tag/config ``` Modify the `zed_isaac_ros_april_tag.yaml` file to configure the AprilTag detection parameters: ```yaml /**: ros__parameters: size: 0.155 max_tags: 64 tile_size: 4 tag_family: 'tag36h11' # Tag family to detect. CUDA backend only supports tag36h11. CPU and PVA backends support tag36h11, tag16h5, tag25h9, tag36h10, tag36h11, circle21h7, circle49h12, custom48h12, standard41h12, standard52h13 backends: 'CUDA' # Backend to perform detection with. Options include CPU, CUDA, PVA ``` * `size`: The size of the AprilTag in meters (e.g., 0.155). * `max_tags`: The maximum number of tags to detect (e.g., 64). * `tile_size`: The tile/window size for adaptive thresholding in pixels (e.g., 4). * `tag_family`: The family of AprilTags to detect. CUDA backend only supports `tag36h11`. CPU and PVA backends support `tag36h11`, `tag16h5`, `tag25h9`, `tag36h10`, `circle21h7`, `circle49h12`, `custom48h12`, `standard41h12`, and `standard52h13`. * `backends`: The backend to use for detection. Options include `CPU`, `CUDA`, `PVA`. You can generate the AprilTags using the tool at [this page](https://chaitanyantr.github.io/apriltag.html). Modify the `zed_params.yaml` file to configure the ZED camera parameters: ```yaml /**: ros__parameters: general: grab_resolution: 'HD1080' grab_frame_rate: 30 pub_resolution: 'CUSTOM' pub_downscale_factor: 2.0 pub_frame_rate: 30.0 ``` * `grab_resolution`: The native camera grab resolution. Options include `HD2K`, `HD1200`, `HD1080`, `HD720`, `SVGA`, `AUTO`. * `grab_frame_rate`: The ZED SDK internal grabbing rate. Options include `60`, `30`, `15` for `HD1200`/`HD1080` and `120`, `60`, `30`, `15` for `SVGA`. * `pub_resolution`: The resolution used for image and depth map publishing. Options include `NATIVE` and `CUSTOM`. Set `NATIVE` to use the same `general.grab_resolution`; set `CUSTOM` to apply the `general.pub_downscale_factor` downscale factor to reduce bandwidth in data transmission. * `pub_downscale_factor`: The rescale factor used to rescale the image before publishing when `pub_resolution` is `CUSTOM`. * `pub_frame_rate`: The data publishing frame rate. ### Visualize Results First, make sure you compiled and built the example as described in the [Setup](#setup-the-example) section. > **Note** > > If you are using Docker, make sure to start the Isaac™ ROS environment with ZED support: > > ```bash > cd ${ISAAC_ROS_WS}/src/isaac_ros_common && \ > ./scripts/run_dev.sh -i ros2_humble.zed \ > -a "-v /usr/local/zed/settings:/usr/local/zed/settings \ > -v /usr/local/zed/resources:/usr/local/zed/resources" > ``` Start the processing by using the command: ```bash ros2 launch zed_isaac_ros_april_tag zed_isaac_ros_april_tag.launch.py camera_model:= ``` where `` is the model of the ZED camera you are using (e.g., `zedx`, `zed2i`, etc.). Point the camera to an AprilTag target and observe the AprilTag detection output `/tag_detections` on a separate terminal with the command: ```bash ros2 topic echo /tag_detections ``` > **Note** > > The AprilTag detection does not use the ZED depth information, so you can use this tutorial with either a ZED stereo or a ZED monocular camera. You can visualize the full ROS 2 topic graph with: ```bash ros2 run rqt_graph rqt_graph ``` ![image](/_fern-img/19a9cadff1c51d00b2397442a5b90b96fc2a822c2480f40588750cea9bd2df53.webp) ## The launch file explained The launch file `launch/zed_isaac_ros_april_tag.launch.py` is responsible for starting all the necessary nodes and configurations for the AprilTag detection application. It sets up the parameters, including the ZED camera settings and the AprilTag detection parameters, and launches the required nodes in a ROS 2 component container. Retrieve the configuration parameters from the relative path `config/zed_isaac_ros_april_tag.yaml` and `config/zed_params.yaml`: **`Python`** ```python Python # Get the path to the camera configuration file camera_config_override_path = os.path.join( get_package_share_directory('zed_isaac_ros_april_tag'), 'config', 'zed_params.yaml' ) # Get the path to the AprilTag configuration file apriltag_config_path = os.path.join( get_package_share_directory('zed_isaac_ros_april_tag'), 'config', 'zed_isaac_ros_april_tag.yaml' ) ``` Create a ROS 2 component container: **`Python`** ```python Python # ROS 2 Component Container container_name = 'zed_container' info = '* Starting Composable node container: ' + namespace_val + '/' + container_name actions.append(LogInfo(msg=TextSubstitution(text=info))) # Note: It is crucial that the 'executable' field is set to be 'component_container_mt' # so that the created nodes can be started and communicated correctly within the same process. zed_container = ComposableNodeContainer( name=container_name, namespace=namespace_val, package='rclcpp_components', executable='component_container_mt', arguments=['--ros-args', '--log-level', 'info'], output='screen', ) actions.append(zed_container) ``` Create a ZED Component and automatically load it into the `container_name` container previously created: **`Python`** ```python Python # ZED Wrapper launch file zed_wrapper_launch = IncludeLaunchDescription( launch_description_source=PythonLaunchDescriptionSource([ get_package_share_directory('zed_wrapper'), '/launch/zed_camera.launch.py' ]), launch_arguments={ 'camera_model': camera_model, 'container_name': container_name, 'namespace': namespace_val, 'enable_ipc': 'false', 'ros_params_override_path': camera_config_override_path }.items() ) actions.append(zed_wrapper_launch) ``` Setup the Image Format converter resolution by retrieving the information from the camera configuration: **`Python`** ```python Python # Read the resolution from the ZED parameters file with open(camera_config_override_path, 'r') as f: configuration = yaml.safe_load(f) print(f'Loaded configuration: {configuration}') resolution = configuration["/**"]["ros__parameters"]["general"]["grab_resolution"] pub_resolution = configuration["/**"]["ros__parameters"]["general"]["pub_resolution"] pub_downscale_factor = configuration["/**"]["ros__parameters"]["general"]["pub_downscale_factor"] if pub_resolution == 'CUSTOM': rescale = pub_downscale_factor else: rescale = 1.0 if resolution == 'HD2K': image_width = 2208 image_height = 1242 elif resolution == 'HD1200': image_width = 1920 image_height = 1200 elif resolution == 'HD1080': image_width = 1920 image_height = 1080 elif resolution == 'HD720': image_width = 1280 image_height = 720 elif resolution == 'SVGA': image_width = 960 image_height = 600 elif resolution == 'VGA': image_width = 672 image_height = 376 ``` Create the Image Format Converter component and set the resolution parameter and the required topic name remappings: **`Python`** ```python Python # Isaac ROS Node to convert from ZED BGRA8 image to BGR8 required by AprilTag isaac_converter_node = ComposableNode( package='isaac_ros_image_proc', plugin='nvidia::isaac_ros::image_proc::ImageFormatConverterNode', name='zed_image_converter', namespace=namespace_val, parameters=[ { 'image_width': int(image_width / rescale), 'image_height': int(image_height / rescale), 'encoding_desired': 'bgr8', 'num_blocks': 40 } ], remappings=[ ('image_raw', 'zed/rgb/color/rect/image'), ('image', 'zed/rgb/color/rect/image_bgr8') ] ) ``` Create the AprilTag component with the required topic name remappings: **`Python`** ```python Python # AprilTag detection node isac_apriltag_node = ComposableNode( package='isaac_ros_apriltag', plugin='nvidia::isaac_ros::apriltag::AprilTagNode', name='apriltag', namespace=namespace_val, remappings=[ ('image', 'zed/rgb/color/rect/image_bgr8'), ('camera_info', 'zed/rgb/color/rect/camera_info') ], parameters=[apriltag_config_path] ) ``` Load the Image Converter and AprilTag components into the container: **`Python`** ```python Python container_full_name = namespace_val + '/' + container_name # Load the Converter node into the container load_converter_node = LoadComposableNodes( composable_node_descriptions=[isaac_converter_node], target_container=container_full_name ) actions.append(load_converter_node) # Load the AprilTag node into the container load_april_tag_node = LoadComposableNodes( composable_node_descriptions=[isac_apriltag_node], target_container=container_full_name ) actions.append(load_april_tag_node) ``` The launch file accepts two arguments: 1. `camera_model`: The model of the camera being used (e.g., `zed2i`, `zedx`, etc.). 2. `disable_tf`: If `True` disable TF broadcasting for all the cameras in order to fuse visual odometry information externally. These arguments can be passed when launching the file to customize the behavior of the nodes. ## Fix the TF issue (optional) If you notice that the TF of the detected AprilTags is not correctly propagated, you must download the patched version of the `isaac_ros_apriltag` package and build it from the source. Clone the repository into your workspace: ```bash cd ${ISAAC_ROS_WS}/src git clone https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_apriltag.git ``` Fetch the specific [Pull Request](https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_apriltag/pull/64) that contains the fix: ```bash cd isaac_ros_apriltag git fetch origin pull/64/head:fix_tf git checkout fix_tf ``` Build the package: ```bash cd ${ISAAC_ROS_WS} colcon build --symlink-install --packages-up-to isaac_ros_apriltag ``` Now you can run the launch file again, and the TF of the detected AprilTags should be correctly propagated.
