# SDK-free depth capture in Isaac™ Sim
The ZED Camera extension can capture **RGB and depth** from a simulated ZED directly inside NVIDIA® Isaac™ Sim, using the simulator's renderer, with **no ZED SDK and no streaming**. This is useful for quick frame/depth capture, generating datasets, or working on a machine where the ZED SDK is not installed.
For how this compares to the streaming and Isaac™ Lab tensor paths, see [Choosing a data path](/docs/integrations/isaac-sim#choosing-a-data-path).
> The depth captured here is Isaac™ Sim's **ground-truth renderer depth** (`distance_to_image_plane`), not the ZED SDK's stereo-matched depth. For genuine ZED SDK depth, use the streaming path.
## ZED Depth OmniGraph node
The extension provides a **ZED Depth** node that captures RGB + depth each simulation tick. Add it to an Action Graph, connect an **On Playback Tick** node to its `ExecIn`, set its properties, and press **Play**. The ZED Depth node supports stereo camera models only; mono ZED X One cameras are not supported.
| Property             | Description        |
| **ZED Camera Prim**  | The ZED camera prim in the stage (e.g. `/World/ZED_X`).        |
| **Camera Model**     | Simulated **stereo** model: `ZED_X`, `ZED_XM`, `ZED_X_Nano`, `ZED_M`, or `ZED_2i`. Detected automatically from the connected ZED Camera Prim when possible. |
| **Lens Type**        | `Wide` or `Narrow` (options depend on the model). Detected automatically like the Camera Model.                                                             |
| **Resolution**       | Render resolution: `HD2K`, `HD1200`, `HD1080`, `HD720`, `SVGA`, or `VGA` (filtered per model).                                                              |
| **Enable Save**      | Save RGB (PNG) + depth (EXR) to disk each frame.        |
| **Output Directory** | Directory to save frames. Required when **Enable Save** is on.        |
## Standalone scripts
The extension also ships two capture scripts under [`exts/sl.sensor.camera/examples/isaac_sim/`](https://github.com/stereolabs/zed-isaac-sim/tree/main/exts/sl.sensor.camera/examples/isaac_sim), both driven by the `sl.sensor.camera.zed_depth.ZEDDepthCamera` helper.
### Standalone / headless (`zed_depth_standalone.py`)
Captures left RGB + depth for N frames, prints per-frame stats, and optionally saves PNG/EXR. It runs with **no arguments**: when no scene or camera is given, it builds a minimal ground + dome-light scene and spawns a ZED camera at a small default pose, so you get a usable depth capture out of the box.
The script is launched with the Python interpreter shipped with Isaac™ Sim (`python.sh` / `python.bat`, in the `_build/linux-x86_64/release` folder of your Isaac™ Sim build). That interpreter and the example live in two different repositories, so run `python.sh` from the Isaac™ Sim build directory and give the script an absolute path into your `zed-isaac-sim` clone:
# Linux, zero-config: minimal scene + auto-spawned ZED_X
cd <isaacsim>/_build/linux-x86_64/release
./python.sh <your_workspace>/zed-isaac-sim/exts/sl.sensor.camera/examples/isaac_sim/zed_depth_standalone.py
# Full control: load your own scene and/or use a camera already placed in it
./python.sh <your_workspace>/zed-isaac-sim/exts/sl.sensor.camera/examples/isaac_sim/zed_depth_standalone.py \
    --usd_path /path/to/scene.usd \
    --camera_prim /World/ZED_X \
    --camera_model ZED_X \
    --resolution HD1200 \
    --num_frames 10 \
    --output_dir /tmp/zed_depth
# Windows: use python.bat. Add --headless for no GUI.
Arguments (all optional): `--usd_path` (environment USD; omit to build a minimal scene), `--camera_prim` (an existing ZED camera prim; omit to spawn one), `--camera_model`, `--resolution`, `--num_frames`, `--output_dir`, `--headless`.
> Saving depth needs the **OpenEXR** codec, which is disabled by default in the OpenCV build shipped with Isaac™ Sim. Whenever you pass `--output_dir` (or enable **Enable Save** on the ZED Depth node), set `OPENCV_IO_ENABLE_OPENEXR=1` before launching, or the run aborts on the first frame with:
> cv2.error: OpenCV(4.13.0) ... (-213:The function/feature is not implemented)
> imgcodecs: OpenEXR codec is disabled. You can enable it via 'OPENCV_IO_ENABLE_OPENEXR' option.
> ```bash
> # Linux
> OPENCV_IO_ENABLE_OPENEXR=1 ./python.sh <...>/zed_depth_standalone.py --output_dir /tmp/zed_depth
> ```powershell
> # Windows (PowerShell; in cmd.exe use: set OPENCV_IO_ENABLE_OPENEXR=1)
> $env:OPENCV_IO_ENABLE_OPENEXR = "1"
> .\python.bat <...>\zed_depth_standalone.py --output_dir C:\zed_depth
> Capturing without `--output_dir` is unaffected: the depth arrays are produced normally and only the EXR *write* needs the codec.
### GUI Script Editor (`zed_depth_example.py`)
For interactive use inside the Isaac™ Sim GUI (extension enabled): load a scene with a ZED camera, paste the script into the **Script Editor**, edit the CONFIG block (`CAMERA_PRIM_PATH`, `CAMERA_MODEL`, `RESOLUTION`, `CAPTURE_INTERVAL`, `SAVE_DIR`), execute it, then press **Play**. RGB + depth are captured every `CAPTURE_INTERVAL` physics steps; press **Stop** to clean up.
## Output
* **Console**: per-capture shape and depth-range stats.
* **Files** (when a save path is set): `rgb_left_NNNNNN.png` (left RGB) and `depth_NNNNNN.exr` (float32 depth in meters, `0` = invalid). For stereo models, `rgb_right_NNNNNN.png` (right RGB) is saved too; depth stays left-referenced.
## See also
* **[Setting up the ZED in Isaac™ Sim](/docs/integrations/isaac-sim/setting-up-the-zed-in-isaac-sim)**: stream the simulated camera to the ZED SDK.
* **[Using the ZED in Isaac™ Lab](/docs/integrations/isaac-sim/using-the-zed-in-isaac-lab)**: read stereo RGB + depth as in-process tensors for learning.
* **[Examples on GitHub](https://github.com/stereolabs/zed-isaac-sim/tree/main/exts/sl.sensor.camera/examples/isaac_sim)**: the full capture scripts.
