# Body Tracking with ROS 2
The ROS 2 wrapper offers full support for the Body Tracking module of the ZED SDK.
The Body Tracking module can be [configured](/docs/integrations/ros-2/zed-stereo-node/#body-tracking-parameters) to use one of the available detection models:
| MODEL                 | Description        |
| `HUMAN_BODY_FAST`     | Keypoints based, specific to human skeleton, real time performance even on NVIDIA® Jetson™ or low-end GPU cards |
| `HUMAN_BODY_MEDIUM`   | Keypoints based, specific to human skeleton, compromise between accuracy and speed                              |
| `HUMAN_BODY_ACCURATE` | Keypoints based, specific to human skeleton, state of the art accuracy, requires powerful GPU                   |
The Body Tracking module can be [configured](/docs/integrations/ros-2/zed-stereo-node/#body-tracking-parameters) to use one of the available body formats:
| FORMAT    | Description        |
| `BODY_18` | 18 keypoints model. Basic Body model                                        |
| `BODY_34` | 34 keypoints model (**default**). Body model, requires body fitting enabled |
| `BODY_38` | 38 keypoints model. Body model, including feet, simplified face, and hands  |
Starting from ZED SDK 5.5 the module can also be [configured](/docs/integrations/ros-2/zed-stereo-node/#body-tracking-parameters) to select the network generation with the `body_tracking.model_gen` parameter:
| GENERATION | Description        |
| `GEN_1`    | The network used up to ZED SDK 5.4        |
| `GEN_2`    | **Default**. Bottom-up network: more robust in crowded scenes and to unusual body orientations, detects people further from the camera, and is up to 18% faster and 14% more accurate than `GEN_1`. It always runs in FP16, so `body_tracking.allow_reduced_precision_inference` has no effect on it |
> Only `BODY_18` and `BODY_34` have a `GEN_2` network: with `BODY_38` the ZED SDK falls back to `GEN_1`.
> Since v5.5.0 of the ROS 2 Wrapper the default body format is `BODY_34` instead of `BODY_38`, and `body_tracking.enable_body_fitting` defaults to `true`, so that the default configuration actually runs `GEN_2`. Skeletons published on `~/body_trk/skeletons` now carry 34 keypoints instead of 38: set `body_format` back to `BODY_38` to keep the previous topology, at the cost of running `GEN_1`.
The result of the detection is published using a custom message of type [zed\_msgs/ObjectsStamped](/docs/integrations/ros-2/custom-msgs/#object-detection-and-body-tracking-results) defined in the package [zed\_msgs](https://github.com/stereolabs/zed-ros2-interfaces).
## Enable Body Tracking
Body Tracking can be started automatically when the ZED Wrapper node starts by setting the parameter `body_tracking.bt_enabled` to `true` in the file `common_stereo.yaml`.
It is also possible to start the Body Tracking processing manually by calling the service `~/enable_body_trk` with the parameter `True`.
In both cases, the Body Tracking processing can be stopped by calling the service `~/enable_body_trk` with the parameter `False`.
See the [services](/docs/integrations/ros-2/zed-stereo-node/#services) documentation for more info.
## Body Tracking results in RViz 2
To visualize the results of the Body Tracking processing in RViz 2, the `ZedOdDisplay` plugin is required. The plugin is available in the [zed-ros2-examples](https://github.com/stereolabs/zed-ros2-examples) GitHub repository and can be installed following the [online instructions](https://github.com/stereolabs/zed-ros2-examples#build-the-package).
> [The source code of the plugin](https://github.com/stereolabs/zed-ros2-examples/tree/master/rviz-plugin-zed-od) is a valid example of how to process the data of the topics of type [zed\_msgs/ObjectsStamped](/docs/integrations/ros-2/custom-msgs/#object-detection-and-body-tracking-results).
![image](/_fern-img/bb95433a7b36e2430e5913e9e2cdbda0bf79832ed6159537a248441734aeacda.webp)
Parameters:
* `Topic`: Selects the body tracking topic to visualize from the list of available topics in the combo box.
* `Depth`: The depth of the incoming message queue.
* `History policy`: Set the QoS history policy. `Keep Last` is suggested for performance and compatibility.
* `Reliability Policy`: Set the QoS reliability policy. `Best Effort` is suggested for performance and compatibility.
* `Durability Policy`: Set the QoS durability policy. `Volatile` is suggested for compatibility.
* `Transparency`: the transparency level of the structures composing the detected bodies.
* `Show skeleton`: enable/disable the visualization of the skeleton of the detected persons.
* `Show Labels`: enable/disable the visualization of the label.
* `Show Bounding Boxes`: enable/disable the visualization of the bounding boxes of the detected bodies.
* `Link Size`: the size of the bounding boxes' corner lines and skeleton link lines.
* `Joint Radius`: the radius of the spheres placed on the corners of the bounding boxes and on the skeleton joint points.
* `Label Scale`: the scale of the label of the bodies.
![image](https://cdn.sanity.io/images/s18ewfw4/production/31b4c39404ab1c3c499bebbafc3b1b917cbab2a3-1877x1055.webp)
