# ROS 2 Composition and ZED ROS 2 Wrapper
ROS 2 expanded the concept of nodelet from ROS 1 replacing nodelets with components and introducing the new concept of ["Composition"](https://docs.ros.org/en/humble/Concepts/Intermediate/About-Composition.html).
Each node can be written as a "Component" which is a shared library loaded at runtime.
This tutorial explains how to:
* run multiple nodes in **separate processes** with the benefits of process/fault isolation as well as easier debugging of individual nodes
* run multiple nodes in a **single process** with lower overhead and optionally more efficient communication (see [Intra Process Communication](https://docs.ros.org/en/humble/Tutorials/Demos/Intra-Process-Communication.html)).
The launch file of the `zed_wrapper` package is designed to take advantage of both.
## Run one ZED camera component in a single process
You can run a ZED Node in a single process by using the default launch command [`zed_camera.launch.py`](https://github.com/stereolabs/zed-ros2-wrapper/blob/master/zed_wrapper/launch/zed_camera.launch.py) as it is:
the launch file creates a ROS 2 Container process called `zed_container` (unless an existing container is passed with the `container_name` launch argument):
**`Python`**
```python Python
    # ROS 2 Component Container
    if (container_name_val == ''):
        container_name_val = 'zed_container'
        distro = os.environ['ROS_DISTRO']
        if distro == 'foxy':
            # Foxy does not support the isolated mode
            container_exec = 'component_container'
            arguments_val = ['--ros-args', '--log-level', 'info']
        else:
            container_exec = 'component_container_isolated'
            arguments_val = ['--use_multi_threaded_executor',
            name=container_name_val,
            namespace=namespace_val,
            package='rclcpp_components',
            executable=container_exec,
            arguments=arguments_val,
            output=node_log_effective,
            composable_node_descriptions=[]
        return_array.append(zed_container)
then it loads a `stereolabs::ZedCamera` (stereo models) or a `stereolabs::ZedCameraOne` (monocular models) component into it. Intra-process communication is enabled according to the `enable_ipc` launch argument (default `true`):
**`Python`**
```python Python
    # ZED Wrapper component
    if is_stereo_model:
        zed_wrapper_component = ComposableNode(
            package='zed_components',
            plugin='stereolabs::ZedCamera',
            name=node_name_val,
            parameters=node_parameters,
            extra_arguments=[{'use_intra_process_comms': enable_ipc_effective}]
    else:  # monocular models
            plugin='stereolabs::ZedCameraOne',
            name=node_name_val,
    full_container_name = '/' + namespace_val + '/' + container_name_val
    info = 'Loading ZED node `' + node_name_val +\
        '` in container `' + full_container_name + '`'
    return_array.append(LogInfo(msg=TextSubstitution(text=info)))
    load_composable_node = LoadComposableNodes(
        target_container=full_container_name,
        composable_node_descriptions=[zed_wrapper_component]
> When the NVIDIA® Isaac™ ROS NITROS package is installed and `debug.disable_nitros` is `false`, the launch file forces `enable_ipc:=false` to avoid a conflict with NITROS. See [NVIDIA® Isaac ROS Nitros](/docs/integrations/ros-2/zed-stereo-node#nvidia-isaac-ros-nitros).
## Compose multiple node components in a single process to leverage IPC
**I**ntra **P**rocess **C**ommunication (**IPC**) is an advanced concept of ROS 2 that allows you to optimize the performance of
nodes running on the same machine.
### The ZED IPC tutorial
The [ZED IPC tutorial](https://github.com/stereolabs/zed-ros2-examples/tree/master/tutorials/zed_ipc) demonstrates how to leverage [ROS 2 Composition](https://docs.ros.org/en/humble/Concepts/Intermediate/About-Composition.html) and [Intra-Process Communication](https://docs.ros.org/en/humble/Tutorials/Demos/Intra-Process-Communication.html) to create a new node component that subscribes to point cloud topics published by all ZED Camera node components running within the same process.
The tutorial guides you through the creation of a new launch file. This launch file utilizes the launch file of the [ZED Multi-Camera tutorial](/docs/integrations/ros-2/multi-camera-setup) to:
1. **Start multiple ZED nodes within a single process.**
2. **Load a new node component that subscribes to the point cloud topics.**
3. **Achieve zero-copy data transfer for efficient data exchange.**
This approach enhances performance and reduces resource consumption by minimizing data copying between nodes within the same process.
#### The `zed_ipc.launch.py` launch File
The [`zed_ipc.launch.py`](https://github.com/stereolabs/zed-ros2-examples/blob/master/tutorials/zed_ipc/launch/zed_ipc.launch.py) launch file is designed to facilitate the setup of multiple ZED Camera nodes within a single process, along with a custom node component that subscribes to their point cloud topics. This launch file ensures efficient intra-process communication by leveraging zero-copy data transfer.
##### Key Features
* **Multiple ZED Nodes**: Initializes and manages multiple ZED Camera nodes within the same process to capture point cloud data.
* **Custom Subscriber Node**: Loads a custom node component that subscribes to the point cloud topics published by the ZED Camera nodes.
* **Zero-Copy Data Transfer**: Utilizes ROS 2's intra-process communication capabilities to achieve zero-copy data transfer, enhancing performance and reducing resource usage.
##### Usage
To use the `zed_ipc.launch.py` launch file, execute the following command:
ros2 launch zed_ipc zed_ipc.launch.py cam_names:=[<camera_name_array>] cam_models:=[<camera_model_array>] cam_serials:=[<camera_serial_array>]
This command will start the launch file, initializing the ZED Camera nodes and the custom subscriber node within the same process.
##### The code explained
**First step**: create a ROS 2 Container and load the two ZED camera components nodes inside it. Here we use the multi-camera launch file described in the [multi-camera tutorial](/docs/integrations/ros-2/multi-camera-setup).
**`Python`**
```python Python
    # Call the multi-camera launch file
    multi_camera_launch_file = os.path.join(
        get_package_share_directory('zed_multi_camera'),
        'launch',
        'zed_multi_camera.launch.py'
    zed_multi_camera = IncludeLaunchDescription(
        launch_description_source=PythonLaunchDescriptionSource(multi_camera_launch_file),
        launch_arguments={
            'cam_names': names,
            'cam_models': models,
            'cam_serials': serials,
            'disable_tf': disable_tf
        }.items()
    actions.append(zed_multi_camera)
**Second step**: remap the topic names. The demo node that receives the Point Cloud messages subscribes to generic `pointcloud_X` topic names.
The launch file must create a correct remapping between `pointcloud_X` and each ZED node Point Cloud topic name `/zed_multi/<camera_name>/point_cloud/cloud_registered`.
**`Python`**
```python Python
    # Create topic remappings for the point cloud node
    remappings = []
    name_array = parse_array_param(names.perform(context))
    for i in range(cam_count):
        base_topic = 'pointcloud_' + str(i)
        remap = '/zed_multi/' + name_array[i] + '/point_cloud/cloud_registered'
        remapping = (base_topic, remap)
        remappings.append(remapping)
**Third step**: create the demo component node that subscribes to the Point Cloud topics and processes the relative messages.
**`Python`**
```python Python
    pc_node = ComposableNode(
        package='zed_ipc',
        plugin='stereolabs::PointCloudComponent',
        name='ipc_point_cloud',
        namespace='zed_multi',
        parameters=[{
            'cam_count': cam_count
        remappings=remappings,
        extra_arguments=[{'use_intra_process_comms': True}]
**Final step**: load the Point Cloud component node in the existing ZED Container process to leverage Intra Process Communication.
**`Python`**
```python Python
    load_pc_node = LoadComposableNodes(
        composable_node_descriptions=[pc_node],
        target_container='/zed_multi/zed_multi_container'
    actions.append(load_pc_node)
You can verify that all the nodes are now running into the same container process by using the command `ros2 component list`.
#### Example
Here's an example for two ZED X cameras named `zedx_front` and `zedx_rear`:
* Launch command:
ros2 launch zed_ipc zed_ipc.launch.py cam_names:=[zedx_front,zedx_rear] cam_models:=[zedx,zedx] cam_serials:=[xxxxxxxxx,yyyyyyyy]
* Running check:
ros2 component list
  1  /zed_multi/zedx_front
  2  /zed_multi/zedx_rear
  3  /zed_multi/ipc_point_cloud
