# ZED Topic Benchmark Tool
The **ZED Benchmark tool** measures the real performance of the topics published by the ZED ROS 2 nodes: how many messages per second actually reach a subscriber, how much bandwidth they consume, how long they take to arrive, and how much CPU the transport costs. It is the recommended way to verify that a machine, a network, and a [DDS configuration](/docs/integrations/ros-2/dds-and-network-tuning) are able to deliver the camera data at the rate the node is configured to publish it, and to measure what [Composition and Intra Process Communication](/docs/integrations/ros-2/composition-and-ipc) actually buy.
The tool is distributed in the [`tools/benchmark`](https://github.com/stereolabs/zed-ros2-examples/tree/master/tools/benchmark) folder of the [zed-ros2-examples](https://github.com/stereolabs/zed-ros2-examples) repository.
For each received message the following information is available:
* Topic type
* Instantaneous frequency
* Windowed average frequency
* Message size
* Instantaneous topic bandwidth
* Windowed average topic bandwidth
* End-to-end latency, from the publisher-side `header.stamp` to the arrival in the benchmark callback
* CPU time consumed by the subscribing process
The values are printed on the console in real time and published on a dedicated topic, so they can be plotted with tools like [PlotJuggler](https://plotjuggler.io/) or [rqt_plot](https://index.ros.org/p/rqt_plot/). When the test ends, a **final report** with the aggregated statistics of the whole session is printed and, optionally, saved to a file.
> By default the benchmark subscribes to the topic with a *generic subscription*, so it works with **any** ROS 2 topic, not only with the topics published by the ZED nodes. Measuring latency, and measuring Intra Process Communication, requires instead a *typed* subscription, which supports a specific list of message types. See [Measuring Intra Process Communication](#measuring-intra-process-communication).
> The tool is available for **ROS 2 Humble Hawksbill, Jazzy Jalisco, Lyrical Luth, and newer** distributions. It is **not available for ROS 2 Foxy** and older releases, because they lack the generic subscription API required to subscribe to topics of an arbitrary type. On those distributions the three packages are still registered in the ament index, so the workspace build succeeds, but nothing is produced: no message, no component library, and no `zed_topic_benchmark` executable. A warning is printed by CMake during the build.
## The packages
| Package                          | Description        |
| `zed_topic_benchmark`            | Provides the `zed_topic_benchmark` executable (a standalone process wrapping the component), the `zed_test_ipc.launch.py` multi-camera launch file, and the `zed_check_ros2_config.sh` helper script.                                   |
| `zed_topic_benchmark_component`  | The `stereolabs::TopicBenchmarkComponent` ROS 2 component that implements the measurement engine. It can be loaded into any component container to measure [Intra Process Communication](/docs/integrations/ros-2/composition-and-ipc). |
| `zed_topic_benchmark_interfaces` | The custom message `BenchmarkStatsStamped` used to publish the statistics.        |
## Installation
The benchmark packages are built together with the other packages of the `zed-ros2-examples` repository:
cd ~/ros2_ws/src/ # use your current ROS 2 workspace folder
cd ..
sudo apt update
rosdep update
rosdep install --from-paths src --ignore-src -r -y --skip-keys scout_description
source ~/.bashrc
If you only need the benchmark tool, you can restrict the build to its packages:
colcon build --symlink-install --cmake-args=-DCMAKE_BUILD_TYPE=Release \
  --packages-up-to zed_topic_benchmark
> **Tip**
> The benchmark packages do not require CUDA or the ZED SDK, so they can also be installed on a remote workstation that only receives the data over the network. This is the best way to measure what a client machine really receives.
### Optional dependencies
Some capabilities are compiled in only if the corresponding package is found at build time. Everything is optional: what is missing is simply not available, and the build never fails because of it. CMake prints which tiers it enabled, for example:
```text
-- * zed_topic_benchmark_component: extra transport types ENABLED for theora_image_transport;point_cloud_interfaces
-- * zed_topic_benchmark_component: ZED type-adapted zero-copy path ENABLED
| Package                       | Enables        |
| `zed_components` + ZED SDK    | The **true zero-copy** type-adapted subscription for image topics. Without it the benchmark still measures the plain typed intra-process path. |
| `theora_image_transport`      | Typed subscription to `<base>/theora` sub-topics.        |
| `ffmpeg_image_transport_msgs` | Typed subscription to `<base>/ffmpeg` sub-topics.        |
| `point_cloud_interfaces`      | Typed subscription to the compressed point cloud sub-topics (`draco`, `zlib`, `zstd`, `cloudini`).                                             |
A message type that was not compiled in falls back to a generic subscription, with a warning that says so.
## Usage
Start the ZED node, then open a new terminal console and run the benchmark node on the topic you want to measure:
ros2 run zed_topic_benchmark zed_topic_benchmark --ros-args -p topic_name:=<name_of_the_topic_to_test>
For example:
ros2 run zed_topic_benchmark zed_topic_benchmark --ros-args \
  -p topic_name:=/zed/zed_node/rgb/color/rect/image
The node prints the benchmark configuration, waits for the topic to be advertised (it polls the graph every 500 msec), and then starts measuring:
```text
[INFO] [1785241970.884210068] [topic_benchmark]: ***** Benchmark parameters *****
[INFO] [1785241970.884321975] [topic_benchmark]: * Topic name: /zed/zed_node/rgb/color/rect/image
[INFO] [1785241970.884340522] [topic_benchmark]: Average window size: 500
[INFO] [1785241970.884354757] [topic_benchmark]: ROS Log: 0
[INFO] [1785241970.884372336] [topic_benchmark]: Subscription mode: auto
[INFO] [1785241970.884383482] [topic_benchmark]: QoS reliability: best_effort
[INFO] [1785241970.884393418] [topic_benchmark]: QoS durability: volatile
[INFO] [1785241970.884408203] [topic_benchmark]: QoS history: keep_last
[INFO] [1785241970.884419323] [topic_benchmark]: QoS depth: 1
[INFO] [1785241970.884441591] [topic_benchmark]: Test duration [sec] (0 = infinite): 0
[INFO] [1785241970.884452406] [topic_benchmark]: Test sample count [#] (0 = infinite): 0
[INFO] [1785241970.884463700] [topic_benchmark]: Report log file:
[INFO] [1785241970.884469253] [topic_benchmark]: *** START BENCHMARK ***
[INFO] [1785241970.884877359] [topic_benchmark]: Advertised on topic: /zed/zed_node/rgb/color/rect/image_stats
[INFO] [1785241971.384685705] [topic_benchmark]: Found topic: '/zed/zed_node/rgb/color/rect/image' of type: 'sensor_msgs/msg/Image'
[INFO] [1785241971.385701248] [topic_benchmark]: Subscriber QoS: Best Effort, Volatile, KEEP_LAST, depth 1
#1      | Freq   62.10/  62.10 Hz | BW 1746.47/1746.47 Mbps |   3.52 MB
#2      | Freq   68.00/  64.91 Hz | BW 1912.48/1825.71 Mbps |   3.52 MB
The lines starting with `#` are the live statistics line, which is updated in place: only one such line is visible while the test runs. The counter is the number of processed messages, and frequency and bandwidth are reported as `instant/average`. The layout is fixed-width and stays within 80 columns so that it does not wrap on a default terminal.
The example above was captured with a ZED 2i publishing rectified color images at HD720 and 60 FPS.
By default the benchmark runs until you stop it with `Ctrl+C`. You can also limit it by time or by number of messages, and save the [final report](#final-report) to a file.
Run for 30 seconds, then stop and print the report:
  -p topic_name:=/zed/zed_node/rgb/color/rect/image \
  -p test_duration_sec:=30.0
Run until 1000 messages are received, then stop:
  -p test_sample_count:=1000
Run for 60 seconds and also save the report to a log file:
  -p topic_name:=/zed/zed_node/point_cloud/cloud_registered \
  -p test_duration_sec:=60.0 \
  -p log_file_path:=/tmp/zed_benchmark_report.txt
## Parameters
| Parameter           | Description        | Default       |
| `topic_name`        | Name of the topic to benchmark.        | `topic_name`  |
| `avg_win_size`      | Size of the moving window used to compute the average statistics, in number of messages.        | `500`         |
| `test_duration_sec` | Duration of the test in seconds, counted from the first received message. When it elapses, the test stops and the report is generated. `0.0` means "run until interrupted".        | `0.0`         |
| `test_sample_count` | Number of messages to receive before stopping the test and generating the report. `0` means "run until interrupted".        | `0`           |
| `log_file_path`     | Path of the file where the final report is written, in addition to the console. An existing file is overwritten. An empty string disables file logging.        | `""`          |
| `use_ros_log`       | If `true`, the live statistics and the report are printed through the ROS 2 logging system instead of the standard output. Useful when the node runs inside a launch file or a component container, where the in-place console update is not usable. | `false`       |
| `subscription_mode` | Which subscription path to use: `generic`, `typed`, or `auto`. See [Measuring Intra Process Communication](#measuring-intra-process-communication).        | `auto`        |
| `qos.reliability`   | Subscriber QoS reliability: `best_effort` or `reliable`. See [QoS](#qos).        | `best_effort` |
| `qos.durability`    | Subscriber QoS durability: `volatile` or `transient_local`.        | `volatile`    |
| `qos.history`       | Subscriber QoS history: `keep_last` or `keep_all`.        | `keep_last`   |
| `qos.depth`         | Subscriber QoS queue depth, used by `keep_last`. Must be at least `1`.        | `1`           |
> All the parameters are **read-only**: they must be set when the node is started and cannot be modified at runtime.
> When both `test_duration_sec` and `test_sample_count` are set, the test stops as soon as the **first** of the two limits is reached.
> **Tip**
> The value of `avg_win_size` defines how reactive the average is. A large window (e.g. `500`) gives a very stable value, useful to characterize a steady stream; a small window (e.g. `30`) reacts quickly and makes throughput drops easier to spot.
## Final report
The report is generated when a test limit is reached **or** when the node is stopped with `Ctrl+C`. It is printed to the console and, if `log_file_path` is set, written to that file:
```text
================ ZED TOPIC BENCHMARK REPORT ================
Topic type:        sensor_msgs/msg/Image
Subscription:      generic (runtime-typed)
Delivery path:     inter-process (middleware) - a generic subscription can never take the intra-process path
Size semantics:    serialized wire bytes
Subscriber QoS:    Best Effort, Volatile, KEEP_LAST, depth 10
Stop reason:       test completed (sample count reached)
Test duration:     1.65 s
Messages received: 100
Frequency [Hz]   - mean: 60.05 | min: 60.05 | max: 60.05
Msg size         - mean: 3.52 MB | min: 3.52 MB | max: 3.52 MB
Bandwidth [Mbps] - mean: 1705.99 | min: 1705.99 | max: 1705.99
Total data:        351.57 MB
Latency [ms]     - not available on this subscription path
Process CPU:       0.120 s (7.28% of one core)
                   whole process, including any other component loaded in it
The report contains:
* **Topic name** and **topic type** as discovered on the ROS 2 graph.
* **Subscription**: the subscription path actually used, `generic (runtime-typed)`, `typed (<message type>)`, or `type-adapted (zero-copy, sl::Mat by pointer)`. A topic that was never seen reports `none - the topic was never seen`.
* **Delivery path**: how the messages were delivered, see [What the report claims](#what-the-report-claims-and-what-it-does-not).
* **Size semantics**: whether the sizes are `serialized wire bytes` (generic path) or `message content bytes` (typed paths). The two are **not comparable**, so a stored report can no longer be misread.
* **Subscriber QoS**: the QoS the middleware actually granted, read back from the subscription rather than echoing what was requested.
* **Stop reason**: `test completed (duration reached)`, `test completed (sample count reached)`, or `interrupted by the user (Ctrl+C)`.
* **Test duration**: time between the first and the last received message.
* **Messages received** and **total data** received during the test.
* **Mean / min / max** of frequency, message size, bandwidth, and latency.
* **Process CPU**: CPU time consumed by the process the benchmark runs in, and its percentage of one core. See [Reading the CPU figure](#reading-the-cpu-figure).
If no message is received at all, the report says so explicitly instead of printing meaningless statistics, while still reporting the subscription path and the QoS so the cause is visible.
The same topic measured by the component composed in the camera container, on the type-adapted zero-copy path:
```text
Subscription:      type-adapted (zero-copy, sl::Mat by pointer)
Delivery path:     intra-process, zero-copy - CONFIRMED (publisher's buffer received by pointer)
Size semantics:    message content bytes (no CDR framing) - NOT comparable to wire bytes
Stop reason:       test completed (duration reached)
Test duration:     15.02 s
Messages received: 899
Frequency [Hz]   - mean: 59.80 | min: 59.72 | max: 59.89
Bandwidth [Mbps] - mean: 1683.89 | min: 1679.49 | max: 1684.54
Total data:        3.09 GB
Latency [ms]     - mean: 17.97 | min: 17.32 | max: 23.72 (899 samples)
Process CPU:       13.070 s (87.04% of one core)
Both reports come from the same ZED 2i at HD720 and 60 FPS. Note that the composed `Process CPU` is much larger simply because that process *is* the ZED node.
## Understanding the statistics
* The **instantaneous** frequency and bandwidth are computed from the last inter-arrival interval, measured with a monotonic clock (`steady_clock`), so the measurement is not affected by host clock adjustments (NTP/PTP).
* The **average** frequency and bandwidth are computed on the message *periods* and *sizes*, i.e. as `1/mean(Δt)` and `mean(size)/mean(Δt)`. This is the unbiased windowed rate also used by `ros2 topic hz`. Averaging the instantaneous rates directly would systematically overestimate the real frequency, increasingly so on jittery topics.
* In the final report, the **mean** frequency and bandwidth are computed over the whole test (total messages over total time and total data over total time).
* The report **min/max** are tracked on the *windowed average* rate, and only after the averaging window has been filled. Tracking them on the raw instantaneous rate would report meaningless extremes caused by a single very short inter-arrival interval, e.g. two messages delivered back-to-back by the executor or a publisher burst. If the test is too short for the window to fill, min and max fall back to the overall mean values.
* The **message size** is printed with adaptive units (B / KB / MB / GB), so small messages such as IMU samples are not rounded to `0.00 MB`. On the generic path it is the exact size of the serialized message, i.e. the wire bytes; on the typed paths it is the size of the message content, without the CDR framing. The report always states which of the two it is.
* Bandwidth values are expressed in **Mbps** computed on binary multiples (1 Mb = 1024 × 1024 bits). On the intra-process path no bytes are transported at all, so the bandwidth there is a notional payload figure and must not be compared with an inter-process one.
* The **latency** is the time between the publisher-side `header.stamp` and the arrival in the benchmark callback. It requires a publisher that fills the stamp and is available only on the typed paths, because a generic subscription receives an opaque serialized buffer. See [Reading the latency correctly](#reading-the-latency-correctly), it is easy to misinterpret on ZED topics.
* The very first received message only initializes the time reference: no frequency can be derived from a single message.
> Frequencies measured by the benchmark tool can be lower than the publishing frequencies reported by the [node diagnostic](/docs/integrations/ros-2/zed-stereo-node/#node-diagnostic). The diagnostic measures the rate at which the node *publishes*, while the benchmark measures the rate at which a subscriber *receives*. A difference between the two means that messages are being lost or delayed by the middleware, by the network, or by the receiving machine; see [DDS and Network Tuning](/docs/integrations/ros-2/dds-and-network-tuning).
## Plotting the statistics
The node publishes the statistics on the topic `<name_of_the_benchmarked_topic>_stats`, e.g. `/zed/zed_node/rgb/color/rect/image_stats`, so they can be recorded with `ros2 bag` or plotted in real time.
The message is a custom type, `zed_topic_benchmark_interfaces/msg/BenchmarkStatsStamped`, defined as:
# Standard Header
std_msgs/Header header
# Instant Frequency
float32 topic_freq
# Average Frequency
float32 topic_avg_freq
# Instant Bandwidth
float32 topic_bw
# Average Bandwidth
float32 topic_avg_bw
# Instant end-to-end latency [msec], 0.0 when unavailable
float32 topic_latency
# Average end-to-end latency [msec], 0.0 when unavailable
float32 topic_avg_latency
The two latency fields are `0.0` on the `generic` path, which has no directly usable publisher timestamp.
For example, to plot the average frequency and latency with `rqt_plot`:
ros2 run rqt_plot rqt_plot \
  /zed/zed_node/rgb/color/rect/image_stats/topic_avg_freq \
  /zed/zed_node/rgb/color/rect/image_stats/topic_avg_latency
## QoS
The subscriber QoS is fully configurable through four parameters, and they are effective on **every** subscription path:
| Parameter         | Values                                     | Default       |
| `qos.reliability` | `best_effort`, `reliable`                  | `best_effort` |
| `qos.durability`  | `volatile`, `transient_local`              | `volatile`    |
| `qos.history`     | `keep_last`, `keep_all`                    | `keep_last`   |
| `qos.depth`       | integer, at least `1`, used by `keep_last` | `1`           |
The defaults reproduce the historical behavior of the tool. A `Best Effort` subscriber is compatible with both `Reliable` and `Best Effort` publishers, so the benchmark connects out of the box to any topic.
  -p qos.reliability:=reliable \
  -p qos.durability:=volatile \
  -p qos.history:=keep_last \
  -p qos.depth:=10
An unrecognized value is replaced by the default **and reported as a warning**, never applied silently, and a `qos.depth` below `1` is clamped to `1`, also with a warning. Every report states the QoS the middleware actually granted, read back from the subscription instead of echoing the request, e.g. `Subscriber QoS: Reliable, Volatile, KEEP_LAST, depth 1`. You can cross-check it from another terminal while the benchmark runs:
ros2 topic info -v <name_of_the_topic_to_test>
> The default shallow queue (depth `1`) is intentional: it makes the tool measure the data that is actually delivered in time, instead of hiding losses behind a large buffer. Increase `qos.depth` when you want to measure how much data arrives in total rather than how much arrives on time.
> **An incompatible QoS request yields no messages at all.** DDS delivers only when the subscriber's request is no stronger than what the publisher offers. The ZED nodes publish their topics `Reliable`, `Volatile`, `KEEP_LAST` (depth 10) by [default](/docs/integrations/ros-2/zed-stereo-node#qos-profiles), which means:
> * `qos.reliability:=reliable` **works** on ZED topics. It yields nothing only against a `Best Effort` publisher, so keep the default when benchmarking a topic from another node whose reliability you have not checked.
> * `qos.durability:=transient_local` is **incompatible** with a `Volatile` publisher, so it delivers nothing on ZED topics. The ZED node logs `requesting incompatible QoS ... Last incompatible policy: DURABILITY_QOS_POLICY`.
> The benchmark logs the caveat up front whenever `reliable` or `transient_local` is selected, and the report pairs the requested QoS with `No message received`, so the cause is visible rather than mysterious. Use `ros2 topic info -v <topic>` to check the publisher's side.
### Why not the standard `qos_overrides`?
The usual ROS 2 mechanism, `-p qos_overrides.<topic>.subscription.reliability:=reliable`, **does not work on the default `generic` path**: `rclcpp::create_generic_subscription()` forwards the subscription options but never calls `declare_qos_parameters()`, so no `qos_overrides.*` parameter is ever declared and the requested policy never reaches the endpoint. This is true on the `humble`, `jazzy`, `lyrical` and `rolling` branches of rclcpp alike.
The `qos.*` parameters above avoid the problem entirely, because they set the QoS *argument* of the subscription, which every path honors. If you pass a `qos_overrides.*` anyway, the benchmark **warns** that it is being ignored and points you at `qos.*` instead of dropping it in silence:
```text
[WARN] [topic_benchmark]: The QoS override(s) qos_overrides./zed/zed_node/rgb/color/rect/image.subscription.reliability
will be IGNORED on this subscription path: rclcpp's create_generic_subscription() does not honour
qos_overriding_options. Use this node's own parameters instead - qos.reliability, qos.durability,
qos.history and qos.depth - which are applied on every subscription path.
> On the `typed` path `qos_overrides.*` does work, because there rclcpp does declare the parameters, and it is applied on top of `qos.*`. Prefer `qos.*` regardless: it behaves identically on both paths.
> The same limitation affects the ROS 2 CLI: `ros2 topic hz` and `ros2 topic bw` expose no QoS options and hard-code the sensor-data profile. Among the subscribing verbs, `ros2 topic echo` is the only one that accepts `--qos-*` options.
## Measuring Intra Process Communication
The `zed_topic_benchmark_component` package provides the ROS 2 component `stereolabs::TopicBenchmarkComponent`, so the benchmark can be loaded into the same [component container](/docs/integrations/ros-2/composition-and-ipc) as the ZED node instead of running in its own process. Composing it is what makes [Intra Process Communication](/docs/integrations/ros-2/composition-and-ipc) measurable, but it is **not sufficient on its own**.
### Why a generic subscription can never measure IPC
Subscribing to a topic whose type is only discovered at runtime requires an `rclcpp::GenericSubscription`. In rclcpp, a subscription is registered with the `IntraProcessManager` **only** from the constructor of the templated `rclcpp::Subscription<T>`, and `GenericSubscription` derives directly from `SubscriptionBase` and never does that. This is the case on every distribution from Humble to Rolling, and there is no serialized intra-process path to opt into either.
A generic subscription therefore always receives through the middleware, even inside the publisher's own container with `use_intra_process_comms:=true`. This is genuinely confusing to observe, because the ZED node can correctly log `[IPC type-adapted zero-copy]` while the benchmark measures the inter-process path: with IPC enabled the publisher feeds *both* paths, and only a real intra-process subscriber benefits.
### The `subscription_mode` parameter
| Mode             | Subscription        | Can take the intra-process path | Message size reported           |
| `generic`        | `rclcpp::GenericSubscription`, any message type        | Never                           | Exact serialized **wire bytes** |
| `typed`          | `rclcpp::Subscription<T>`, supported types only        | Yes                             | **Message content bytes**       |
| `auto` (default) | `typed` when intra-process comms are enabled on the node **and** the message type is supported, `generic` otherwise | When it resolves to `typed`     | Depends on the resolved path    |
`auto` keeps an ordinary separate-process run on the historical generic subscription, so its wire-accurate bandwidth figures are unchanged, while a composed run with IPC enabled automatically gets a subscription that can actually use it. If a typed subscription is requested for an unsupported type, the benchmark falls back to `generic` **with a warning** rather than silently measuring something else.
### Supported message types
`image_transport` and `point_cloud_transport` publish the same image or cloud once per transport plugin, each on its own sub-topic and with its own message type. All of them can be measured on the typed path:
| Transport                                              | Topic                    | Message type                                       | Reported size           |
| `image_transport` raw                                  | `<base>`                 | `sensor_msgs/msg/Image`                            | `data`                  |
| `image_transport` compressed                           | `<base>/compressed`      | `sensor_msgs/msg/CompressedImage`                  | `data`                  |
| `image_transport` compressedDepth                      | `<base>/compressedDepth` | `sensor_msgs/msg/CompressedImage`                  | `data`                  |
| `image_transport` zstd                                 | `<base>/zstd`            | `sensor_msgs/msg/CompressedImage`                  | `data`                  |
| `image_transport` theora                               | `<base>/theora`          | `theora_image_transport/msg/Packet`                | `data`                  |
| `image_transport` ffmpeg                               | `<base>/ffmpeg`          | `ffmpeg_image_transport_msgs/msg/FFMPEGPacket`     | `data`                  |
| `point_cloud_transport` raw                            | `<base>`                 | `sensor_msgs/msg/PointCloud2`                      | `data`                  |
| `point_cloud_transport` draco / zlib / zstd / cloudini | `<base>/<transport>`     | `point_cloud_interfaces/msg/CompressedPointCloud2` | `compressed_data`       |
|                                                        |                          | `sensor_msgs/msg/CameraInfo`                       | matrices and distortion |
|                                                        |                          | `sensor_msgs/msg/Imu`                              | fixed fields            |
For a compressed cloud the **compressed** payload is reported, not the uncompressed geometry, which would overstate the transported volume by the whole compression ratio. Some of these types require an [optional dependency](#optional-dependencies) at build time.
### Two tiers of typed delivery
Not all intra-process delivery is zero-copy, and the difference is large:
* **Plain typed subscription**: skips serialization and the middleware entirely, but rclcpp still copies the message into the subscription's buffer. When the publisher is type-adapted, rclcpp first calls `convert_to_ros_message()` and then copies the result, i.e. *two* full copies of the image.
* **ZED type-adapted subscription**: built on the very same `TypeAdapter<StampedSlMat, sensor_msgs::msg::Image>` the ZED node publishes with, so the publisher's `sl::Mat` arrives **by pointer**, with no serialization, no conversion and no copy. This is genuine zero-copy, and it is selected automatically for `sensor_msgs/msg/Image` topics when intra-process comms are enabled and the [optional](#optional-dependencies) `zed_components` dependency was available at build time.
### Composing the benchmark
Start the ZED node with IPC enabled:
ros2 launch zed_wrapper zed_camera.launch.py camera_model:=<camera_model> enable_ipc:=true
then load the benchmark component into the ZED container:
ros2 component load /zed/zed_container \
  zed_topic_benchmark_component stereolabs::TopicBenchmarkComponent \
  -e use_intra_process_comms:=true \
  -p subscription_mode:=typed \
  -p use_ros_log:=true
You can verify that the benchmark node is running in the same process as the ZED node with `ros2 component list`:
ros2 component list
/zed/zed_container
  1  /zed/zed_node
  2  /topic_benchmark
> Set `use_ros_log:=true` when the component runs inside a container: the in-place console update of the live statistics line is not usable when the output is multiplexed with the logs of the other nodes.
> When the benchmark component reaches a `test_duration_sec` or `test_sample_count` limit, it requests the shutdown of the process it is running in. In a shared container this stops **the whole container**, including the ZED node and any other composed node. The reports are still generated before the shutdown. To benchmark composed nodes for an arbitrary time, leave both limits at their default (infinite) and stop the container with `Ctrl+C`.
### What to compare, and it is not bandwidth
On the intra-process path no bytes are transported, so a bandwidth figure there is notional payload throughput and is **not** comparable with an inter-process one. The frequency is set by the publisher and barely moves either. The metrics that show the gain are **latency** and **CPU**.
Measured on a **ZED 2i**, `rgb/color/rect/image` (3.52 MB per frame, about 1.7 Gbps) at 60 FPS with `NEURAL_LIGHT` depth running, on an RTX 4070 desktop, both runs with `subscription_mode:=typed`:
|                             | Composed, zero-copy   | Separate process                     |
| Latency, mean               | **18.06 ms**          | **20.17 ms**                         |
| Total CPU, all processes    | **89.4%** of one core | **93.6%** (87.4 ZED + 6.2 benchmark) |
| ZED node with no subscriber | 70.0%                 | 70.0%                                |
| Frequency                   | 59.87 Hz              | 59.76 Hz                             |
On that desktop, zero-copy saves about 2 ms of latency and 4 points of CPU on a 1.7 Gbps stream. The gain looks modest because both figures are dominated by work that is not the transport: 70 of those CPU points are capture plus depth, and most of the latency is the camera pipeline. Isolating the transport with a synthetic type-adapted publisher that stamps at publish time and does no camera work, the same code reports **0.02 ms against 3.32 ms**, and 0.34% against 2.04% of one core.
**The gain is far larger on an embedded target**, where the CPU is weaker relative to the data rate. On a **Jetson AGX Orin** (JetPack 6, L4T R36.5) with a GMSL2 **ZED X Mini** at HD1200, `rgb/color/rect/image` is 8.79 MB at 30 FPS, about 2.1 Gbps:
| Latency, mean                     | **48.25 ms**          | **54.17 ms**     |
| Total CPU, all processes          | **44.2%** of one core | **69.5%**        |
| ZED node with no subscriber       | 29.5%                 | 31.2%            |
| Transport cost (total minus idle) | **14.8%**             | **38.3%**        |
| Frequency                         | 30.01 Hz              | 29.84 Hz         |
Zero-copy costs **2.6 times less CPU** for the transport there, and saves about 6 ms of latency. With **four GMSL2 cameras** (two ZED X Mini and two ZED X) in a single container, all four confirming zero-copy at 8.79 MB per frame, roughly 8 Gbps aggregate:
|                          | Composed, zero-copy          | Separate processes           |
| Per-camera rate          | 29.9 / 27.8 / 29.5 / 29.1 Hz | 25.0 / 20.4 / 24.5 / 26.0 Hz |
| Aggregate rate           | **116.3 Hz**                 | **95.9 Hz**                  |
| Latency, mean            | 54 to 65 ms                  | 64 to 72 ms                  |
| Total CPU, all processes | **161%** of one core         | **287%**                     |
Composed, the cameras nearly hold their nominal 30 FPS. As separate processes the middleware cannot keep up, every camera drops frames, and it costs 78% more CPU.
#### Reading the latency correctly
> The ZED node stamps images and clouds with the frame **acquisition** time (`sl::TIME_REFERENCE::IMAGE`), not the publish time. The reported latency therefore covers the *whole* pipeline, i.e. capture, transfer, SDK retrieve, rectification and depth, publish and deliver, and the transport is only a small part of it. On a ZED 2i at 60 FPS the rectified RGB image reports about 18 to 20 ms in **both** modes, of which only around 2 ms is the transport. Compare the *difference* between the two modes, not the absolute value.
This applies to **every** topic of the node, `camera_info` included: they are all stamped from the frame timestamp, so none of them isolates the transport on its own. A compressing transport adds its own work on top of that, which is why `depth/depth_registered/compressedDepth` reports **53.9 ms** on a ZED 2i and **253 ms** on a Jetson AGX Orin: the stamp predates the compression that the plugin then performs.
To time the transport alone, set the wrapper's `use_pub_timestamps` parameter to `true`, which stamps at publish time instead. That is the only reliable way to obtain a transport-only figure from this tool.
Latency is reported as *not available* on the `generic` path, which receives a serialized buffer with no directly usable timestamp.
#### Reading the CPU figure
The report's `Process CPU` covers the **whole process**. Composed, that process *is* the ZED node, so the figure also includes capture, depth and publishing, and it is therefore **not comparable** with the separate-process figure, which covers the benchmark alone. On a ZED 2i this reads 6.2% separate against 89.4% composed, which naively suggests that IPC is far worse, while the totals say the opposite.
The fair comparison is the total across every process involved, which is what [`zed_check_ros2_config.sh`](#testing-your-ros-2-configuration) reports in its `CPU_TOT` column, alongside a `CPU_IDLE` baseline measured with no subscriber at all, so the transport cost of a mode is `CPU_TOT - CPU_IDLE`.
### What the report claims, and what it does not
A typed subscription on a node with IPC enabled takes the intra-process path *only* for publishers that live in the same process, and that cannot be checked from inside a callback. The report therefore distinguishes three cases:
* `intra-process, zero-copy - CONFIRMED`: only the type-adapted path can prove this, because the custom C++ type it receives has no wire representation and so cannot have come through the middleware.
* `intra-process capable, NOT confirmed`: typed subscription with IPC enabled, but delivery is not verifiable per message. Compare the latency against an inter-process run to see which path you got.
* `inter-process (middleware)`: with the reason, including the case where a generic subscription makes the intra-process path impossible by construction.
## Benchmarking a multi-camera setup
The `zed_test_ipc.launch.py` launch file of the `zed_topic_benchmark` package starts a [multi-camera setup](/docs/integrations/ros-2/multi-camera-setup) and one benchmark node per camera, either composed in the camera container using IPC or as separate processes:
ros2 launch zed_topic_benchmark zed_test_ipc.launch.py \
  cam_names:=[zed_front,zed_back] \
  cam_models:=[zed2i,zed2] \
  cam_serials:=[12345678,87654321]
The available launch arguments are:
| Argument            | Description        | Default                         |
| `cam_names`         | Array with the names of the cameras, e.g. `[zed_front,zed_back]`.        | *required*                      |
| `cam_models`        | Array with the models of the cameras, e.g. `[zed2i,zed2]`.        | *required*                      |
| `cam_serials`       | Array with the serial numbers of the cameras, e.g. `[35199186,23154724]`.        | *required*                      |
| `disable_tf`        | Disable TF broadcasting for all the cameras, to fuse the visual odometry information externally.        | `False`                         |
| `use_ipc`           | If `True`, the benchmark nodes are loaded as components in the ZED camera container, with intra-process comms enabled. If `False`, each benchmark runs in a separate process.                                                          | `True`                          |
| `subscription_mode` | Subscription path used by the benchmark nodes: `auto`, `generic` or `typed`. Applied to **both** branches, so that `use_ipc:=True` and `use_ipc:=False` are directly comparable.                                                       | `typed`                         |
| `qos_reliability`   | Subscriber QoS reliability: `best_effort` or `reliable`.        | `best_effort`                   |
| `qos_durability`    | Subscriber QoS durability: `volatile` or `transient_local`.        | `volatile`                      |
| `qos_history`       | Subscriber QoS history: `keep_last` or `keep_all`.        | `keep_last`                     |
| `qos_depth`         | Subscriber QoS depth, used by `keep_last`.        | `1`                             |
| `avg_win_size`      | Window size of the running averages, applied to both branches.        | `500`                           |
| `topic_name`        | Topic to benchmark, without the `/zed_multi/<cam_name>` prefix.        | `/point_cloud/cloud_registered` |
| `test_duration_sec` | Duration of the test in seconds. `0.0` runs until `Ctrl+C`.        | `0.0`                           |
| `test_sample_count` | Number of messages to acquire before stopping. `0` runs until `Ctrl+C`.        | `0`                             |
| `log_file_path`     | File where the report is saved. The camera name is appended to the file name, e.g. `report.txt` becomes `report_zed_front.txt`, so that concurrent benchmark nodes do not overwrite each other. An empty string disables file logging. | `""`                            |
For each camera the launch file benchmarks the topic `/zed_multi/<cam_name><topic_name>` with a node named `benchmark_<index>` in the `zed_multi` namespace, and all the benchmark nodes use the ROS logging system (`use_ros_log` is forced to `true`).
> Both branches now share a single parameter set, so a `use_ipc:=True` run and a `use_ipc:=False` run are directly comparable. This matters for `avg_win_size` in particular: the report min/max are tracked on the windowed average, so an asymmetric window alone would make the two runs incomparable.
> As explained in [Composing the benchmark](#composing-the-benchmark), with `use_ipc:=True` all the benchmark nodes share the camera container: a finite `test_duration_sec`/`test_sample_count` stops the whole container as soon as the first node reaches its limit. Keep the limits at their defaults and stop the launch with `Ctrl+C` to benchmark a composed multi-camera setup for an arbitrary time.
## Testing your ROS 2 configuration
The `zed_topic_benchmark` package ships a helper script, `zed_check_ros2_config.sh`, that automates a fixed set of benchmarks against a **real ZED camera** and prints a report for each one. Its purpose is to **verify that your ROS 2, DDS, and system configuration is able to deliver the camera data at the expected rate and bandwidth**, a quick way to validate a new setup or to investigate performance problems.
The script measures each of the following topics **twice**, once with the benchmark in a separate process (`interprocess`) and once composed in the camera container with intra-process comms enabled (`ipc`):
| Topic                                        | Depth mode     |
| `/zed/zed_node/rgb/color/rect/image`         | `NONE`         |
| `/zed/zed_node/depth/depth_registered`       | `NEURAL_LIGHT` |
| `/zed/zed_node/point_cloud/cloud_registered` | `NEURAL_LIGHT` |
The RGB image is measured with depth disabled (`NONE`) to isolate the image throughput, while depth and point cloud are measured with the default depth mode (`NEURAL_LIGHT`).
Both runs use `subscription_mode:=typed`, so the size and latency accounting is identical and the two really are comparable, and the ZED node keeps `enable_ipc:=true` in both, so the publisher is the same and the only variable is where the subscriber lives.
For each of the six tests, the script starts the ZED node with the required `depth.depth_mode`, waits for the topic to be advertised, waits `WARMUP` seconds for the node to reach steady state, measures a no-subscriber CPU baseline, runs the measurement, saves the report as `report_<mode>_<topic>.txt`, and then stops the node to release the camera.
> The script drops the ROS 2 CLI daemon cache at start-up, and retries the component load once after dropping it again. A stale graph cache can otherwise make `ros2 component load` fail with *"Unable to find container node"*, or make `ros2 topic list` return an incomplete graph so that every test is skipped as *"topic not available"*.
### Usage
ros2 run zed_topic_benchmark zed_check_ros2_config.sh <camera_model> [duration_sec]
For example, for a ZED 2i with 20 seconds of measurement per test:
ros2 run zed_topic_benchmark zed_check_ros2_config.sh zed2i 20
The first argument is the camera model (`zed`, `zedm`, `zed2`, `zed2i`, `zedx`, `zedxm`, ...) and defaults to `zed2i`; the second one is the duration in seconds of each measurement and defaults to `15`. The behavior can be further tuned with environment variables:
| Variable        | Description        | Default                            |
| `CAMERA_MODEL`  | ZED camera model. Overridden by the first positional argument.        | `zed2i`                            |
| `CAMERA_SN`     | Serial number of the camera to use. Optional with a single camera, **strongly recommended on a multi-camera rig**: with several cameras attached and no serial given, the wrapper has to pick one itself and may open none, which shows up as a skipped test. | empty                              |
| `DURATION`      | Seconds of measurement per test. Overridden by the second positional argument.        | `15`                               |
| `WARMUP`        | Seconds to let the node reach steady state before the no-subscriber CPU baseline is taken. Too short and the baseline lands in the neural depth warm-up, which yields a `CPU_IDLE` above `CPU_TOT`.                                                           | `25`                               |
| `WIN_SIZE`      | Averaging window size of the benchmark node.        | `100`                              |
| `TOPIC_TIMEOUT` | Maximum seconds to wait for a topic to appear before skipping the test.        | `120`                              |
| `SETTLE`        | Seconds to wait between two tests, to let the camera be released.        | `5`                                |
| `OUTPUT_DIR`    | Directory where the reports are stored.        | `./zed_config_reports/<timestamp>` |
> The script starts and stops the ZED node itself, so **no other node must be using the camera** when you run it. Make sure that no ZED node is already running and that the camera is free.
> The script must be run in a terminal where the ROS 2 and workspace environments are sourced (it checks that the `ros2` command is available). Plan for a few minutes of execution: six tests, each including the start-up of the ZED node, the measurement, and the settle time.
### Reading the results
A full [report](#final-report) is saved for each test in the output directory, together with the log of the ZED node, useful if a test fails or if a topic never appears. At the end, a summary table is printed. Its layout is the following; the values are placeholders: the actual numbers depend entirely on your camera, resolution, middleware and machine.
```text
############################# SUMMARY #############################
TOPIC   MODE          MSGS    FREQ[Hz]   LATENCY[ms]  CPU_TOT[%]  CPU_IDLE[%]
image   interprocess  <n>     <freq>     <lat>        <total>     <idle>
image   ipc           <n>     <freq>     <lat>        <total>     <idle>
depth   interprocess  <n>     <freq>     <lat>        <total>     <idle>
depth   ipc           <n>     <freq>     <lat>        <total>     <idle>
cloud   interprocess  <n>     <freq>     <lat>        <total>     <idle>
cloud   ipc           <n>     <freq>     <lat>        <total>     <idle>
* `CPU_TOT` is the total across **every** process involved, i.e. the ZED node plus the benchmark for `interprocess`, and the ZED node alone for `ipc`, where the benchmark runs inside it. This is the only CPU figure that is comparable between the two modes, see [Reading the CPU figure](#reading-the-cpu-figure).
* `CPU_IDLE` is the ZED node with no subscriber at all, so the transport cost of a mode is `CPU_TOT - CPU_IDLE`. A `CPU_IDLE` **above** `CPU_TOT` means the baseline was sampled while the node was still warming up: re-run with a larger `WARMUP`.
* A `NO DATA` row means that no report was produced for that test: the topic was not published within `TOPIC_TIMEOUT`, or the ZED node failed to start. Check the corresponding `zed_<mode>_<topic>.log` file in the output directory.
Read the table like this:
1. Compare the measured **frequencies** with the values configured through `general.pub_frame_rate` and `depth.point_cloud_freq` (see [Node Frequency Tuning](/docs/integrations/ros-2/node-frequency-tuning)). Values well below them mean the data is not being delivered.
2. Expect the two `FREQ` values of a topic to be close, because the publisher sets the rate.
3. Compare **`LATENCY` and `CPU_TOT`** between the two modes: those are what the intra-process path changes. Do not compare bandwidth, which is not reported here for exactly that reason. For measured examples see [What to compare](#what-to-compare-and-it-is-not-bandwidth).
### When the results are not as expected
If the measured frequencies are significantly lower than the configured publishing frequencies, or the `interprocess` latency is high, your ROS 2 middleware or your system is likely not tuned for high-throughput data. The following pages describe how to fix it:
* [DDS and Network Tuning for ROS 2](/docs/integrations/ros-2/dds-and-network-tuning): the DDS and kernel settings required to reliably transport large messages such as images and point clouds.
* [Using Zenoh as Middleware](/docs/integrations/ros-2/using-zenoh-as-middleware): an alternative middleware, recommended for distributed and Wi-Fi based setups.
* [Node Frequency Tuning](/docs/integrations/ros-2/node-frequency-tuning): how to configure the publishing frequency of each module to match the available computational power and bandwidth.
* [Composition and IPC](/docs/integrations/ros-2/composition-and-ipc): how to remove the middleware overhead entirely when publisher and subscriber run on the same machine.
## Testing the packages
The statistics engine, i.e. the sliding-window averages and the frequency/bandwidth math, is covered by C++ unit tests; the end-to-end behavior, i.e. report generation and self-termination on a sample-count limit, is covered by a `launch_testing` integration test that runs the node against a synthetic publisher.
> Always run `colcon` from the root of your ROS 2 workspace (the folder containing `src/`, `build/`, and `install/`). Running it from another directory makes `colcon` scan that directory recursively, which can pull in unrelated `setup.py` files and abort with package-identification errors.
cd ~/ros2_ws   # your workspace root
# Unit tests (statistics engine)
colcon build --packages-select zed_topic_benchmark_component --cmake-args -DBUILD_TESTING=ON
colcon test --packages-select zed_topic_benchmark_component --ctest-args -R "test_winavg|test_statistics"
# Integration test (node + synthetic publisher)
colcon build --packages-select zed_topic_benchmark --cmake-args -DBUILD_TESTING=ON
colcon test --packages-select zed_topic_benchmark --ctest-args -R "test_benchmark_integration"
# Show detailed results
colcon test-result --all --verbose
The integration test can also be run directly with `launch_test`:
launch_test src/zed-ros2-examples/tools/benchmark/zed_benchmark/test/test_benchmark_integration.py
