# Using Zenoh as ROS 2 Middleware
[Zenoh](https://zenoh.io/) is a pub/sub/query protocol that can be used as an alternative ROS 2 middleware through the [`rmw_zenoh`](https://github.com/ros2/rmw_zenoh) implementation. Unlike the default DDS-based middleware, Zenoh communicates over **TCP** and relies on a lightweight **router** for discovery instead of UDP multicast.
This makes it a very good fit for the ZED ROS 2 nodes, which publish large messages such as high-resolution images and 3D point clouds:
* **No kernel buffer tuning required.** Because Zenoh uses TCP, large messages are not split into UDP/IP fragments, so the [`sysctl` network tuning](/docs/integrations/ros-2/dds-and-network-tuning#tuning-for-large-messages) that DDS needs to transfer point clouds and images is **not** required.
* **Discovery scales better.** Nodes connect to a router instead of flooding the network with multicast discovery traffic, which helps in large systems and on networks where multicast is unreliable (e.g. Wi-Fi).
* **Shared memory** can be enabled to move large messages between processes on the same machine without copying them over the network stack.
> This guide applies to **ROS 2 Humble**, **ROS 2 Jazzy**, and **ROS 2 Lyrical**. The commands are identical on all of them and use the `$ROS_DISTRO` environment variable, which is set automatically to `humble`, `jazzy`, or `lyrical` when you source your ROS 2 setup file, so you can run them as they are.
> ROS 2 messages include a *type hash* starting from Iron. `rmw_zenoh` embeds this hash in the Zenoh keys it uses to exchange data, so a **Humble** node and a **Jazzy** (or newer) node will discover each other but **silently fail to communicate**.
> Each distribution also ships a very different version of `rmw_zenoh` and of the underlying Zenoh protocol, so mixing distributions is not supported in general. Make sure every machine in your ROS 2 graph uses the **same ROS 2 distribution** when running over Zenoh.
## Step 1: Install rmw\_zenoh
Pre-built binaries are available for Humble, Jazzy, and Lyrical. Open a terminal console (`Ctrl + Alt + t`) and run:
sudo apt update
sudo apt install ros-$ROS_DISTRO-rmw-zenoh-cpp
> The configuration described in this guide **must be applied to every machine** involved in the ROS 2 infrastructure that needs to send or receive ZED ROS 2 messages over Zenoh.
### (Optional) Build from source
If you need the latest features or fixes, you can build `rmw_zenoh` from source instead:
mkdir -p ~/ws_rmw_zenoh/src && cd ~/ws_rmw_zenoh/src
git clone https://github.com/ros2/rmw_zenoh.git -b $ROS_DISTRO
cd ~/ws_rmw_zenoh
rosdep install --from-paths src --ignore-src --rosdistro $ROS_DISTRO -y
source /opt/ros/$ROS_DISTRO/setup.bash
colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
Remember to source the workspace (`source ~/ws_rmw_zenoh/install/setup.bash`) in every terminal where you want to use the source-built version.
## Step 2: Select Zenoh as the RMW implementation
ROS 2 chooses its middleware through the `RMW_IMPLEMENTATION` environment variable. Set it in **every terminal** where you launch a ROS 2 node (including the ZED node, the Zenoh router, and any subscriber such as RViz2):
export RMW_IMPLEMENTATION=rmw_zenoh_cpp
To apply it automatically to every new terminal, add the line to your `~/.bashrc` file:
echo 'export RMW_IMPLEMENTATION=rmw_zenoh_cpp' >> ~/.bashrc
You can confirm that the correct middleware is selected with:
ros2 doctor --report | grep middleware
## Step 3: Start the Zenoh router
Unlike DDS, Zenoh disables UDP multicast discovery by default. Nodes discover each other through a **Zenoh router** (`rmw_zenohd`). You must start **one router before launching any node** (for multi-machine setups, see [Running across multiple machines](#running-across-multiple-machines)).
Open a dedicated terminal and run:
ros2 run rmw_zenoh_cpp rmw_zenohd
Leave this terminal open: the router must stay alive for the whole session. By default it listens on TCP port **7447**.
> **Tip**
> By default, a node tries to reach the router only once at startup and continues even if it is not found. You can control this behavior with the `ZENOH_ROUTER_CHECK_ATTEMPTS` environment variable:
> * `0` → wait indefinitely until a router is found.
> * a positive number `N` → try `N` times, once per second, then continue.
> * a negative number → skip the check entirely.
> Setting `export ZENOH_ROUTER_CHECK_ATTEMPTS=0` is handy to make sure your ZED node never starts publishing before the router is ready.
## Step 4: Launch the ZED node and verify
With the router running and `RMW_IMPLEMENTATION` exported, launch the ZED node as usual. For a stereo camera:
Replace `<camera_model>` with your camera (e.g. `zed2i`, `zedx`, `zedxm`). See the [ZED Stereo Node](/docs/integrations/ros-2/zed-stereo-node) page for the full list of launch options.
In another terminal (with the same `RMW_IMPLEMENTATION` exported), check that the topics are available and that data flows:
ros2 topic list
ros2 topic hz /zed/zed_node/point_cloud/cloud_registered
### Quick sanity test
If you want to validate the Zenoh setup independently from the ZED node, use the standard ROS 2 demo nodes. With the router running, open two terminals:
# Terminal A
ros2 run demo_nodes_cpp talker
# Terminal B
ros2 run demo_nodes_cpp listener
The listener should print the messages published by the talker.
## Running across multiple machines
A typical robotics setup has the ZED node running on the robot (e.g. an NVIDIA® Jetson™) and the visualization tools running on a remote workstation. With Zenoh, the recommended approach is to run **one router per machine** and connect the routers to each other.
1. On **every** machine, make sure all terminals use Zenoh (`export RMW_IMPLEMENTATION=rmw_zenoh_cpp`).
2. Start a router on each machine (Step 3).
3. Tell the **workstation's** router to connect to the **robot's** router. The quickest way is to start the router with a configuration override pointing at the robot's IP address:
export ZENOH_CONFIG_OVERRIDE='connect/endpoints=["tcp/<ROBOT_IP>:7447"]'
Replace `<ROBOT_IP>` with the IP address of the machine running the ZED node. Once the two routers are linked, every node on either machine can see all the topics.
> Just like with DDS, all nodes that need to communicate must share the same [`ROS_DOMAIN_ID`](/docs/integrations/ros-2/dds-and-network-tuning#ros-domain). `rmw_zenoh` honors this variable to isolate independent ROS 2 graphs running on the same network.
> **Tip**
> For a permanent setup, copy the default configuration file shipped with the package and edit its `connect`/`listen` endpoints instead of using the override variable:
> ```bash
> cp $(ros2 pkg prefix rmw_zenoh_cpp)/share/rmw_zenoh_cpp/config/DEFAULT_RMW_ZENOH_ROUTER_CONFIG.json5 ~/zenoh_router_config.json5
> export ZENOH_ROUTER_CONFIG_URI=~/zenoh_router_config.json5
> When you point `ZENOH_ROUTER_CONFIG_URI` (router) or `ZENOH_SESSION_CONFIG_URI` (nodes) to a file, it **replaces** the default configuration, so always start from a copy of the default file to keep the recommended values.
## Tuning Zenoh for large messages
ZED cameras publish large messages: high-resolution images and dense point clouds can each be several MB to tens of MB. Zenoh handles these far better than DDS out of the box, but a few settings help on demanding setups (4K images, high-density point clouds, constrained or wireless links).
### No IP-fragmentation tuning needed
Because Zenoh transfers data over TCP, it is **not** affected by the UDP/IP fragmentation problems described in the [DDS and Network Tuning](/docs/integrations/ros-2/dds-and-network-tuning) page. You can skip the `net.ipv4.ipfrag_*` and `net.core.rmem_max` `sysctl` settings when using Zenoh. The default Zenoh configuration already accepts single messages up to **1 GiB** (`transport/link/rx/max_message_size`), which is well above any ZED message size.
### Prevent point clouds and images from being silently dropped
This is the **most common issue** when streaming ZED data over Zenoh, and it is worth understanding before anything else.
When network congestion occurs, Zenoh decides whether to *drop* a message or *block* the publisher until the message has been pushed out. Which behavior applies depends on the publisher's ROS 2 QoS:
* With **KEEP\_LAST** history (the [ZED nodes' default](/docs/integrations/ros-2/zed-stereo-node#qos-profiles): `RELIABLE` + `KEEP_LAST`, depth 10), Zenoh uses a **drop** strategy: if a message cannot be pushed to the network within `wait_before_drop` (**1 ms by default**), it is **silently dropped**. One millisecond is far too short for a multi-MB point cloud or a high-resolution image, so under load these messages can disappear without any error.
* With **RELIABLE + KEEP\_ALL** history, Zenoh uses a **block** strategy instead: the publisher waits until the message is fully sent, so nothing is dropped.
You have two ways to fix this (both confirmed by `rmw_zenoh` maintainers in [issue #696](https://github.com/ros2/rmw_zenoh/issues/696)):
**Option A: Increase the drop timeout (recommended, no QoS change).** Raise `wait_before_drop` (value in **microseconds**) in the terminal where you launch the ZED node, before starting it:
# Wait up to 1 second (1000000 µs) instead of 1 ms before dropping under congestion
export ZENOH_CONFIG_OVERRIDE='transport/link/tx/queue/congestion_control/drop/wait_before_drop=1000000'
This keeps the ZED nodes' default QoS and lets large messages use the full bandwidth of the link.
**Option B: Switch the publisher to RELIABLE + KEEP\_ALL.** Set the topic history to `KEEP_ALL` in the ZED node's YAML configuration so Zenoh switches to the *block* strategy. The trade-off is that a slow subscriber or link can throttle the publisher's rate. See the [QoS profiles](/docs/integrations/ros-2/zed-stereo-node#qos-profiles) section for how to change these settings.
> On **low-bandwidth or wireless links**, combining `RELIABLE` with `TRANSIENT_LOCAL` and a deep history can overwhelm the link when a late-joining subscriber requests the cached messages, eventually closing the transport (`Unable to push non droppable network message ... Closing transport!`). On such links, keep the history depth small and rely on the [data-reduction techniques](#reduce-the-amount-of-data-on-the-wire) below.
### Enable Shared Memory (SHM) for same-machine transfers
When the ZED node and its subscribers run on the **same machine**, shared memory lets Zenoh move large messages between processes without copying them through the network stack, a major win for point clouds and images.
SHM is **disabled by default**. To enable it, set the following override on **the router and every node** (publisher and subscribers):
export ZENOH_CONFIG_OVERRIDE='transport/shared_memory/enabled=true'
> Each `export ZENOH_CONFIG_OVERRIDE=...` replaces the previous value. To apply several overrides, for example SHM and the `wait_before_drop` timeout above, combine them in one variable separated by `;`:
> ```bash
> export ZENOH_CONFIG_OVERRIDE='transport/shared_memory/enabled=true;transport/link/tx/queue/congestion_control/drop/wait_before_drop=1000000'
A few things to keep in mind:
* The shared-memory segment defaults to **48 MiB** per process. Make sure your host's `/dev/shm` is large enough for all the processes involved.
* Inside **Docker**, shared memory is isolated by default. Run your containers with `--ipc=host` (or a large enough `--shm-size`) so that SHM transport works across containers and with the host.
* If a write to shared memory fails, Zenoh automatically falls back to the network transport, so enabling SHM is safe.
* On startup you may see `zenoh_shm::watchdog ... error setting scheduling priority` warnings. These are **benign** (they relate to real-time thread scheduling) and can be safely ignored under normal conditions.
### Increase the serialization buffer pool
`rmw_zenoh` recycles serialization buffers from a pool whose maximum size defaults to **8 MiB**. Messages larger than this still work (they are allocated outside the pool), but raising the limit reduces allocations when streaming many large messages. Set it on the publisher side:
export RMW_ZENOH_BUFFER_POOL_MAX_SIZE_BYTES=33554432   # 32 MiB
### Reduce the amount of data on the wire
The most effective tuning is often to **send less data**, especially over Wi-Fi. These techniques are middleware-agnostic and apply to Zenoh exactly as they do to DDS:
* **Use compressed image and point cloud topics**: see [Use compressed topics](/docs/integrations/ros-2/dds-and-network-tuning#use-compressed-topics).
* **Publish smaller and less frequent data for previews**: see [Use smaller and less frequent information for data preview](/docs/integrations/ros-2/dds-and-network-tuning#use-smaller-and-less-frequent-information-for-data-preview).
### Useful environment variables
| Variable                               | Purpose        |
| `RMW_IMPLEMENTATION`                   | Selects the middleware. Set to `rmw_zenoh_cpp`.        |
| `ZENOH_ROUTER_CHECK_ATTEMPTS`          | How many times a node checks for the router at startup (see Step 3).                                                            |
| `ZENOH_CONFIG_OVERRIDE`                | Override individual config keys, e.g. `key/path=value;key2/path=value2`. Used above to enable SHM and raise `wait_before_drop`. |
| `ZENOH_ROUTER_CONFIG_URI`              | Path to a custom **router** configuration file.        |
| `ZENOH_SESSION_CONFIG_URI`             | Path to a custom **node (session)** configuration file.        |
| `RMW_ZENOH_BUFFER_POOL_MAX_SIZE_BYTES` | Maximum serialization buffer pool size (default 8 MiB).        |
| `RUST_LOG`                             | Zenoh log verbosity, e.g. `RUST_LOG=zenoh=info` for troubleshooting.                                                            |
> Congestion control and shared-memory transport for very large payloads are actively being improved upstream (finer-grained policies are planned for newer Zenoh releases). If you still hit dropped messages after applying the settings above, reduce the published resolution/frequency and follow the open reports on the [`rmw_zenoh` issue tracker](https://github.com/ros2/rmw_zenoh/issues).
## Switching back to DDS
To go back to the default DDS middleware, simply change (or unset) the `RMW_IMPLEMENTATION` variable and stop the Zenoh router:
# Back to Fast DDS (the ROS 2 default)
unset RMW_IMPLEMENTATION
# or, to use Cyclone DDS
export RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
Remember to also remove the corresponding line from `~/.bashrc` if you added it. For DDS-specific tuning, refer to the [DDS and Network Tuning](/docs/integrations/ros-2/dds-and-network-tuning) page.
