# ROS 2 - ZED Mono Node
The easiest way to start a ZED ROS 2 node for a monocular camera is by using the command line:
ros2 launch zed_wrapper zed_camera.launch.py camera_model:=<camera model>
where `<camera model>` must be replaced with one of `zedxonegs`, `zedxone4k`, or `zedxonecore`.
## Published Topics
* **Status**
  * `~/status/heartbeat`: heartbeat signal to monitor if the node is alive from other nodes ([custom message](/docs/integrations/ros-2/custom-msgs/#node-heartbeat)).
  * `~/status/svo`: status of the SVO playback (only advertised when an SVO file is used as input).
* **Image streams**
  The image topic names are created using the following naming convention:
  `~/<sensor_type>/<color_model>/<rect_type>/image`
  > Starting from version 5.1.0 of the ROS 2 Wrapper the new convention replaces the previous formats such as `~/<sensor_type>/image_<rect_type>_<color_model>` and `~/<sensor_type>_<rect_type>/image_<rect_type>_<color_model>` (e.g., `~/left/image_rect_color`, `~/rgb_raw/image_raw_gray`). Please update your launch files and scripts to use the new topic names.
  * **RGB channel**
    * `~/rgb/color/rect/image`: Color rectified image.
    * `~/rgb/color/rect/camera_info`: Color camera calibration data.
    * `~/rgb/gray/rect/image`: Grayscale rectified image.
    * `~/rgb/gray/rect/camera_info`: Grayscale camera calibration data.
    * `~/rgb/color/raw/image`: Color unrectified image.
    * `~/rgb/color/raw/camera_info`: Color raw calibration data.
    * `~/rgb/gray/raw/image`: Grayscale unrectified image.
    * `~/rgb/gray/raw/camera_info`: Grayscale raw calibration data.
> Since v5.5.0 of the ROS 2 Wrapper the `distortion_model` and the distortion coefficients published in the `camera_info` topics are read from the ZED SDK (>= 5.4) instead of a hard-coded per-model table that the lens does not always follow: a fisheye ZED X One now reports `equidistant` instead of `rational_polynomial`. Rectified parameters are reported as `plumb_bob` with zero coefficients.
* **Sensors data**
  * `~/imu/data`
  * `~/imu/data_raw`
  * `~/temperature`
  * `~/left_cam_imu_transform`
### Image Transport
The ROS 2 wrapper supports the stack [image_transport](https://docs.ros.org/en/humble/p/image_transport/#) introduced with ROS 2 Crystal Clemmys.
Starting from version 5.3 of the ROS 2 Wrapper, image messages are published through `rclcpp::TypeAdapter` for more efficient handling:
* The base `raw` topic is handled by a `TypeAdapter` publisher. **Intra-process** subscribers (e.g., other nodes running in the same component container) receive a `StampedSlMat` object (a wrapper around the native `sl::Mat`) directly, without any serialization overhead. **Inter-process** subscribers transparently receive a standard `sensor_msgs/msg/Image` message thanks to the automatic `TypeAdapter` conversion.
* The transport-specific variants are handled by an `image_transport` publisher. Its `raw` transport is disabled to avoid publishing duplicate messages, since the `raw` stream is already provided by the `TypeAdapter` publisher described above.
To prevent silent data corruption caused by incompatible plugin/encoding combinations, the advertised image transports are filtered by topic type. Visual image topics (color and grayscale images) advertise only:
* `compressed`: JPEG or PNG compressed image
* `theora`: Ogg Theora compressed image
* `zstd`: lossless Zstandard-compressed image (available starting with ROS 2 Jazzy Jalisco)
For proper association between images and their corresponding camera information, the ZED ROS 2 Wrapper also publishes `camera_info` topics for all compressed image streams:
* `~/rgb/color/rect/image/camera_info`
* `~/rgb/gray/rect/image/camera_info`
* `~/rgb/color/raw/image/camera_info`
* `~/rgb/gray/raw/image/camera_info`
> When the `isaac_ros_nitros` package is installed and NITROS is not disabled via the `debug.disable_nitros` parameter, NITROS publishers take priority and neither the `TypeAdapter` nor the `image_transport` publishers are created. Please refer to the dedicated section about [NVIDIA® Isaac ROS Nitros](#nvidia-isaac-ros-nitros) for more details.
### NVIDIA® Isaac ROS Nitros
The ZED ROS 2 Wrapper supports the NVIDIA® Isaac™ ROS Nitros package for zero-copy transport of ROS messages using NVIDIA® GPUDirect® RDMA.
NVIDIA® Isaac ROS Nitros integration is enabled and used only if the required packages are manually installed. They are not added as a dependency because this is an optional feature.
Starting from version 5.3 of the ROS 2 Wrapper, Intra-Process Communication (IPC) is handled automatically: it is disabled when NITROS is enabled and enabled when NITROS is disabled. You can use the `debug.disable_nitros` parameter to disable NITROS and force IPC to be enabled if needed. See the [ZED Stereo Node](/docs/integrations/ros-2/zed-stereo-node#nvidia-isaac-ros-nitros) page for how the `enable_ipc` launch argument interacts with NITROS.
For more information about the installation and usage of the NVIDIA® Isaac™ ROS packages, please refer to the dedicated section of the documentation: [ZED Isaac™ ROS Integration Overview](/docs/integrations/isaac-ros/).
### QoS profiles
All the topics are configured by default to use the following ROS 2 [QoS profile](http://design.ros2.org/articles/qos.html):
* **Reliability**: RELIABLE
* **History** (Depth): KEEP_LAST (10)
* **Durability**: VOLATILE
* **Lifespan**: Infinite
* **Deadline**: Infinite
* **Liveliness**: AUTOMATIC
* **Liveliness lease duration**: Infinite
> Read the official [ROS 2 documentation](https://docs.ros.org/en/humble/Concepts/Intermediate/About-Quality-of-Service-Settings.html) about the QoS and the related settings for details.
The QoS settings can be modified by changing the relative parameters in the YAML files, as described in this official [ROS 2 design document](https://design.ros2.org/articles/qos_configurability.html).
When creating a subscriber, be sure to use a compatible QoS profile according to the following tables:
*Compatibility of QoS durability profiles:*
| Publisher       | Subscriber          | Connection | Result          |
| Volatile        | Volatile            | Yes        | Volatile        |
| **Volatile**    | **Transient local** | **No**     | **-**           |
| Transient local | Volatile            | Yes        | Volatile        |
| Transient local | Transient local     | Yes        | Transient local |
*Compatibility of QoS reliability profiles:*
| Best effort     | Best effort  | Yes        | Best effort |
| **Best effort** | **Reliable** | **No**     | **-**       |
| Reliable        | Best effort  | Yes        | Best effort |
| Reliable        | Reliable     | Yes        | Reliable    |
In order for a connection to be made, *all* of the policies that affect compatibility must be compatible. For instance, if a publisher-subscriber pair has compatible reliability QoS profiles, but incompatible durability QoS profiles, the connection will not be made.
> For a detailed list of all the compatibility settings, please refer to the [official ROS 2 documentation](https://docs.ros.org/en/humble/Concepts/Intermediate/About-Quality-of-Service-Settings.html#qos-compatibilities).
## Configuration parameters
Specify your launch parameters in the `common_mono.yaml`, `zedxonegs.yaml`, `zedxone4k.yaml`, and `zedxonecore.yaml` files available in the folder [zed_wrapper/config](https://github.com/stereolabs/zed-ros2-wrapper/tree/master/zed_wrapper/config).
### General parameters
Namespace: `general`
**common_mono.yaml**
| Parameter                        | Description        | Value        |
| serial_number                    | Select a ZED X One camera by its Serial Number        | int        |
| camera_id                        | Select a ZED X One camera by its ID (0 for first, 1 for second...)        | int        |
| bus_type                         | Bus searched when the camera is selected with `camera_id`. `AUTO` searches any bus, `USB` and `GMSL` restrict the search to that transport, `MIPI` targets a camera on a MIPI capture card (e.g. a ZED X One Core) and `HOLOSCAN` a camera reached over Camera-over-Ethernet through a Holoscan sensor bridge. The ZED SDK matches the bus type exactly, so a value other than `AUTO` hides the cameras reached over another bus. Ignored when the camera is selected with `serial_number`        | string, 'AUTO', 'USB', 'GMSL', 'MIPI' \[ZED SDK >= 5.5], 'HOLOSCAN' \[ZED SDK >= 5.5] |
| pub_resolution                   | The resolution used for output. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factor to reduce bandwidth in transmission        | string, 'NATIVE', 'CUSTOM'                                                            |
| pub_downscale_factor             | Rescale factor used to rescale image before publishing when 'pub_resolution' is 'CUSTOM'        | double        |
| gpu_id                           | Select a GPU device for image processing        | int        |
| optional_opencv_calibration_file | Optional path where the ZED SDK can find a file containing the calibration information of the camera computed with OpenCV.        | string        |
| publish_status                   | Enable publishing of the node status topics        | `true`, `false`        |
| sdk_timestamp_clock              | \[ZED SDK >= 5.3] Clock source behind every SDK timestamp (images and sensors). `SYSTEM_CLOCK` is the wall clock and is affected by NTP/PTP, `MONOTONIC_CLOCK` is immune to clock steps but still frequency-slewed by NTP/PTP, `MONOTONIC_RAW_CLOCK` \[ZED SDK >= 5.4] is immune to both steps and slewing. Process-wide: the first node in a composition wins        | string, 'SYSTEM_CLOCK', 'MONOTONIC_CLOCK', 'MONOTONIC_RAW_CLOCK'                      |
| max_system_clock_step_ms         | \[ZED SDK >= 5.3] Largest backward host clock adjustment (NTP/PTP step, manual date change) that the SDK applies to a single sample, in milliseconds. It therefore sets how fast the SDK catches up with a clock step: `4.0` is the ZED SDK default and suits slew-only setups, a negative value makes step corrections land instantly, as PTP deployments expect, and `0.0` freezes the offset captured on first use. It is applied only when `sdk_timestamp_clock` is `SYSTEM_CLOCK`, and it is always overridden by the `ZED_SDK_MAX_SYSTEM_CLOCK_STEP_MS` environment variable | double        |
| timestamp_reference              | \[ZED SDK >= 5.5] Time reference used to stamp the published data. `IMAGE` is the start of the sensor readout; `IMAGE_CENTER_OF_EXPOSURE` is the middle of the frame exposure, half an exposure earlier, which aligns the frames with sensors that are timestamped at the instant they measure, such as a LiDAR or the joints of a robot        | string, 'IMAGE', 'IMAGE_CENTER_OF_EXPOSURE'                                           |
| sdk_use_monotonic_clock          | **\[DEPRECATED]** Use `sdk_timestamp_clock` instead. Still read for backward compatibility: when `true` and `sdk_timestamp_clock` is left at `SYSTEM_CLOCK`, the SDK clock is set to `MONOTONIC_CLOCK`. The node logs a deprecation warning        | `true`, `false`        |
> `timestamp_reference: 'IMAGE_CENTER_OF_EXPOSURE'` requires an input that carries a per-frame exposure, that is a ZED X One GS or a ZED X One 4K, live, from an SVO or from a stream. On any other camera the node warns once and falls back to `IMAGE`. It is not applied to the sensors data, to the SVO `/clock` topic, nor in simulation.
**zedxonegs.yaml**, **zedxone4k.yaml**, and **zedxonecore.yaml**
| camera_model    | Type of StereoLabs camera        | string, `zedxonegs`, `zedxone4k`, `zedxonecore` |
| camera_name     | User name for the camera, can be different from camera model        | string                                          |
| grab_resolution | The native camera grab resolution. The valid values depend on the camera model, see the table below. An invalid value is rejected with a warning and replaced by 'AUTO' | string                                          |
| grab_frame_rate | ZED SDK internal grabbing rate        | int, '15','30','60','120'                       |
Valid `grab_resolution` values per camera model:
| Camera model               | Valid values                                  |
| `zedxonegs`, `zedxonecore` | 'HD1200', 'HD1080', 'SVGA', 'AUTO'            |
| `zedxone4k`                | 'HD4K', 'QHDPLUS', 'HD1200', 'HD1080', 'AUTO' |
A `grab_frame_rate` of 120 FPS requires the `SVGA` resolution, so it is not available with the ZED X One 4K. On the ZED X One 4K, `HD4K` and `QHDPLUS` run at 15 FPS, and `HD1200` and `HD1080` at up to 60 FPS.
### Simulation input parameters
Namespace: `simulation`
| sim_enabled | Enable simulation input          | `true`, `false` |
| sim_address | Address of the simulation server | string          |
| sim_port    | Port of the simulation server    | int             |
> Simulation support for the ZED X One monocular cameras is available starting from v5.5.0 of the ROS 2 Wrapper. Launch the node with `sim_mode:=true` plus the optional `sim_address`, `sim_port` and `use_sim_time` arguments to publish images and IMU data from the simulated camera. With `use_sim_time:=true` the node waits for a valid `/clock` and stamps every topic with the simulation time.
### Streaming input parameters
Namespace: `stream`
| stream_address | Address of the local streaming server                           | string |
| stream_port    | Port of the local streaming server (only even values are valid) | int    |
### SVO input parameters
Namespace: `svo`
| svo_path            | Specify SVO filename        | string, relative file paths are not allowed              |
| svo_encoding_preset | \[ZED SDK >= 5.3] SVO encoder speed/quality preset used by the `start_svo_rec` service        | string, 'DEFAULT', 'ULTRAFAST', 'FAST', 'MEDIUM', 'SLOW' |
| encryption_key      | \[ZED SDK >= 5.3] Optional key/passphrase used to encrypt the SVO files created by the `start_svo_rec` service (AES-256-CTR). Accepted as a path to a 32-byte key file, a 64-character hex key, or a passphrase. Empty disables encryption | string                                                   |
| decryption_key      | \[ZED SDK >= 5.3] Optional decryption key/passphrase used when opening encrypted SVO files        | string                                                   |
| use_svo_timestamps  | Use the SVO timestamps to publish data. If false, data will be published at the system time        | `true`, `false`                                          |
| publish_svo_clock   | When `use_svo_timestamps` is true allows you to publish the SVO clock to the `/clock` topic. This is useful for synchronous rosbag playback        | `true`, `false`                                          |
| svo_loop            | Restart the SVO if the end of the file is reached        | `true`, `false`                                          |
| svo_realtime        | if true SVO will be played trying to respect the original framerate eventually skipping frames, otherwise every frame will be processed        | `true`, `false`                                          |
| play_from_frame     | Start playing the SVO from a specific frame ID        | int                                                      |
> SVO encryption requires OpenSSL (`libcrypto`) at runtime. The value of `svo.encryption_key` is never written to the log, and the same value must be set as `svo.decryption_key` to play the recording back: **if the key is lost the recorded data is unrecoverable**.
### Streaming server parameters
Namespace: `stream_server`
| stream_enabled     | enable the streaming server when the camera is open        | `true`, `false`      |
| codec              | Different encoding types for image streaming: 'H264', 'H265'        | string               |
| port               | Port used for streaming. Port must be an even number. Any odd number will be rejected.        | int                  |
| bitrate            | Streaming bitrate (in Kbits/s) used for streaming. See [doc](https://www.stereolabs.com/docs/api/structsl_1_1StreamingParameters.html#a873ba9440e3e9786eb1476a3bfa536d0)        | int, \[1000 - 60000] |
| gop_size           | The GOP size determines the maximum distance between IDR/I-frames. Very high GOP size will result in slightly more efficient compression, especially on static scenes. But latency will increase.        | int, \[max 256]      |
| adaptative_bitrate | Bitrate will be adjusted depending on the number of packets dropped during streaming. If activated, the bitrate can vary between \[bitrate/4, bitrate].        | `true`, `false`      |
| chunk_size         | Stream buffers are divided into X number of chunks where each chunk is chunk_size bytes long. You can lower chunk_size value if network generates a lot of packet lost: this will generate more chunks for a single image, but each chunk sent will be lighter to avoid inside-chunk corruption. Increasing this value can decrease latency. | int, \[1024 - 65000] |
| target_framerate   | Framerate for the streaming output. This framerate must be below or equal to the camera framerate. Allowed framerates are 15, 30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken.        | int                  |
### Video parameters
Namespace: `video`
| saturation\*                   | Image saturation        | int, \[0,8]                        |
| sharpness\*                    | Image sharpness        | int, \[0,8]                        |
| gamma\*                        | Image gamma        | int, \[0,8]                        |
| auto_whitebalance\*            | Enable the auto white balance        | `true`, `false`                    |
| whitebalance_temperature\*     | White balance temperature        | int \[28,65]                       |
| auto_exposure\*                | Enable or disable auto exposure control (false: manual, true: auto)                                                              | `true`, `false`                    |
| exposure_time\*                | Defines the real exposure time in microseconds. Recommended to control manual exposure                                           | int, \[28,30000]                   |
| auto_exposure_time_range_min\* | Defines the minimum range of exposure auto control in micro seconds                                                              | int                                |
| auto_exposure_time_range_max\* | Defines the maximum range of exposure auto control in micro seconds                                                              | int                                |
| exposure_compensation\*        | Defines the Exposure-target compensation made after auto exposure. Reduces the overall illumination target by factor of F-stops. | int, \[0 - 100]                    |
| auto_analog_gain\*             | Enable or disable auto analog gain control (false: manual, true: auto)                                                           | `true`, `false`                    |
| analog_gain\*                  | Defines the real analog gain (sensor) in mDB. Recommended to control manual sensor gain                                          | int, \[1000-16000].                |
| auto_analog_gain_range_min\*   | Defines the minimum range of sensor gain in automatic control        | int                                |
| auto_analog_gain_range_max\*   | Defines the maximum range of sensor gain in automatic control        | int                                |
| auto_digital_gain\*            | Enable or disable auto digital gain control (false: manual, true: auto)                                                          | `true`, `false`                    |
| digital_gain\*                 | Defines the real digital gain (ISP) as a factor. Recommended to control manual ISP gain                                          | int, \[1-256]                      |
| auto_digital_gain_range_min\*  | Defines the minimum range of digital ISP gain in automatic control                                                               | int                                |
| auto_digital_gain_range_max\*  | Defines the maximum range of digital ISP gain in automatic control                                                               | int                                |
| denoising\*                    | Defines the level of denoising applied on the image        | int, \[0-100]                      |
| ae_antibanding\*               | \[ZED SDK >= 5.3] Auto-exposure anti-banding mode        | int, 0=OFF, 1=AUTO, 2=50Hz, 3=60Hz |
| enable_24bit_output            | Enable BGR 24-bit output for images (instead of 32-bit)        | `true`, `false`                    |
| publish_rgb                    | Enable publishing of RGB image streams        | `true`, `false`                    |
| publish_raw                    | Enable publishing of raw (unrectified) image streams        | `true`, `false`                    |
| publish_gray                   | Enable publishing of grayscale image streams        | `true`, `false`                    |
\* *Dynamic parameter*
**zedxone4k.yaml**
| enable_hdr | When set to true, the camera will be set in HDR mode if the camera model and resolution allows it | `true`, `false` |
### Sensors parameters
Namespace: `sensors`
| publish_imu_tf         | Enable/disable the IMU TF broadcasting                                                          | `true`, `false` |
| sensors_pub_rate\*     | Frequency of publishing of sensors data                                                         | double          |
| publish_imu            | Advertise the IMU topic that is published only if a node subscribes to it                       | `true`, `false` |
| publish_imu_raw        | Advertise the raw IMU topic that is published only if a node subscribes to it                   | `true`, `false` |
| publish_cam_imu_transf | Advertise the CAMERA-IMU transformation topic that is published only if a node subscribes to it | `true`, `false` |
| publish_temp           | Advertise the temperature topics that are published only if a node subscribes to them           | `true`, `false` |
> Starting from v5.5.0 of the ROS 2 Wrapper the sensors stream is read independently of `grab()`, so the IMU publishing delay no longer depends on `general.grab_frame_rate`. The node polls the sensors well above the hardware ODR, so no sample is lost.
> `sensors.sensors_pub_rate` is now decimated against the *measured* sample interval instead of the rate the ZED SDK advertises, so it is honored on cameras whose IMU does not run at the advertised rate: a ZED X One GS advertises 400 Hz but delivers 200 Hz, and `sensors_pub_rate: 100` used to produce a steady 50 Hz.
> Two consequences of the reduced CPU usage of the sensors thread: a new subscriber to a sensors topic can wait up to 250 ms for its first message, and a subscriber whose QoS is incompatible with the publisher no longer triggers publishing (it could never receive the data anyway).
### Advanced parameters
Namespace: `advanced`
> These are advanced threading parameters. Do not modify them unless you are confident of what you are doing. The `SCHED_FIFO` and `SCHED_RR` scheduling policies require running with `sudo`. Reference: [sched(7)](https://man7.org/linux/man-pages/man7/sched.7.html).
| change_thread_priority | Master switch for the other `advanced` parameters: the thread scheduling policy and the priorities below are applied only when this is `true` | `true`, `false`                                                |
| thread_sched_policy    | Thread scheduling policy        | string, 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' |
| thread_grab_priority   | Priority of the grab thread (only with 'SCHED_FIFO' and 'SCHED_RR')        | int, \[1 (LOW) - 99 (HIGH)]                                    |
| thread_sensor_priority | Priority of the sensors thread (only with 'SCHED_FIFO' and 'SCHED_RR')        | int, \[1 (LOW) - 99 (HIGH)]                                    |
### Debug parameters
Namespace: `debug`
| sdk_verbose           | Set the verbose level of the ZED SDK        | int, `0` -> disable |
| sdk_verbose_log_file  | Path to the file where the ZED SDK will log its messages. If empty, no file will be created. The log level can be set using the `sdk_verbose` parameter. | string              |
| use_pub_timestamps    | Use the current ROS time for the message timestamp instead of the camera timestamp. This is useful to test data communication latency.                   | `true`, `false`     |
| debug_common          | Enable general debug log outputs        | `true`, `false`     |
| debug_dyn_params      | Enable dynamic parameters update debug log outputs        | `true`, `false`     |
| debug_video_depth     | Enable video debug log outputs        | `true`, `false`     |
| debug_camera_controls | Enable camera controls debug log outputs        | `true`, `false`     |
| debug_sensors         | Enable sensors debug log outputs        | `true`, `false`     |
| debug_sim             | Enable simulation mode debug log outputs        | `true`, `false`     |
| debug_tf              | Enable TF broadcasting debug log outputs        | `true`, `false`     |
| debug_streaming       | Enable streaming debug log outputs        | `true`, `false`     |
| debug_advanced        | Enable advanced debug log outputs        | `true`, `false`     |
| debug_nitros          | Enable Nitros debug log outputs        | `true`, `false`     |
| disable_nitros        | If available, disable NITROS usage for debugging and testing purposes        | `true`, `false`     |
> Up to v5.4 the `sdk_use_monotonic_clock` parameter was declared in the `debug` namespace of `common_mono.yaml`, while the node reads it from the `general` namespace, so it was silently ignored. It is now declared in the right namespace, and it is superseded by `general.sdk_timestamp_clock`.
## Dynamic parameters
The ZED node lets you reconfigure many parameters dynamically during the execution of the node. All the dynamic parameters are indicated with a \* in the list above and with the tag `[DYNAMIC]` in the comments of the `YAML` files.
You can set the parameters using the [CLI](https://docs.ros.org/en/humble/Tutorials/Beginner-CLI-Tools/Understanding-ROS2-Parameters/Understanding-ROS2-Parameters.html) command `ros2 param set`, e.g.:
ros2 param set /zed/zed_node video.exposure_time 5000
If the parameter is set successfully, you will get a confirmation message:
Set parameter successful
In the case you tried to set a parameter that's not dynamically reconfigurable, or you specified an invalid value, you will get this type of error:
ros2 param set /zed/zed_node video.exposure_time 0
Setting parameter failed: Parameter {video.exposure_time} doesn't comply with integer range.
You can also use the `Configuration` -> `Dynamic Reconfigure` plugin of the `rqt` tool to dynamically set parameters by using a graphic interface.
![image](/_fern-files/_img/c23cda6698679c6a6f733bab077e97c622cd7d9849894d3e758cf45c0bc39f52.webp)
## Transform frames
The ZED ROS 2 wrapper broadcasts multiple coordinate frames that each provides information about the camera's position and orientation. If needed, the reference frames can be changed in the launch file.
* `<camera_name>_camera_link` is the camera mounting point. It corresponds to the threaded fixing hole at the bottom of the camera.
* `<camera_name>_camera_center` is the center of the camera body.
* `<camera_name>_camera_frame` is the position and orientation of the camera CMOS sensor.
* `<camera_name>_camera_frame_optical` is the position and orientation of the camera optical frame.
* `<camera_name>_imu_link` is the origin of the inertial data frame.
![Frames](/_fern-files/_img/b4a60638aaf9e005cdeafdbabe142d833df5b74c174771785de8f302d195b55f.webp)
## Services
* `~/enable_streaming` (`std_srvs/srv/SetBool`): enable/disable a local streaming server.
* `~/start_svo_rec` (`zed_msgs/srv/StartSvoRec`): Start recording an SVO file. If no filename is provided the default `zed_one.svo2` is used. A filename without a path is saved in the working directory of the node process.
* `~/stop_svo_rec` (`std_srvs/srv/Trigger`): Stop an active SVO recording.
* `~/pause_svo_rec` (`std_srvs/srv/SetBool`): Pause (`data: true`) and resume (`data: false`) an active SVO recording without closing the file. It returns `success: false` when no recording is active, and the diagnostic reports `SVO Recording: PAUSED` while paused.
* `~/toggle_svo_pause` (`std_srvs/srv/Trigger`): set/reset SVO playing pause. Only available if `svo.svo_realtime` is false and if an SVO has been chosen as input source.
* `~/set_svo_frame` (`zed_msgs/srv/SetSvoFrame`): Set the SVO playback frame to the specified value. Only available if an SVO has been chosen as input source.
Services can be called using the `rqt` graphical tool by enabling the plugin `Plugins` -> `Services` -> `Service caller`.
It is possible to call a service also by using the CLI command `ros2 service call`.
For example, to start the local streaming server:
ros2 service call /zed/zed_node/enable_streaming std_srvs/srv/SetBool "{data: True}"
requester: making request: std_srvs.srv.SetBool_Request(data=True)
response:
std_srvs.srv.SetBool_Response(success=True, message='Streaming Server started')
## Assigning a GPU to a camera
To improve performance, you can specify the `gpu_id` of the graphic card that will be used for the image processing in the `common_mono.yaml` configuration file. The default value (-1) will select the GPU with the highest number of CUDA cores. When using multiple cameras, you can assign each camera to a GPU to increase performance.
## Node Diagnostic
The ZED ROS 2 node publishes useful diagnostic information aggregated into the `/diagnostics` topic using the [diagnostic_updater](https://index.ros.org/p/diagnostic_updater/) package.
Diagnostic information can be analyzed and parsed by using ROS 2 tools, like for example the **Runtime Monitor** plugin of **rqt**.
Available information:
* Uptime
* Grab frequency and processing time
* Frame drop rate
* Input mode
* Image publishing rate and processing time
* IMU TF broadcasting rate
* IMU data publishing rate
* Camera internal temperature
* Scene Illuminance
* SVO playback status
* SVO recording status, including the `PAUSED` state
* Streaming server status
