# How to Build Applications with Unity and ZED
This section describes how to build apps in Unity using the ZED.
## Build Settings
To build an application with the ZED SDK, you need to make sure the target platform is set to x86\_64 in Unity build settings.
* Click on *File > Build Settings*
* Set **Target Platform** to Windows (or Linux) and **Architecture** to x86\_64.
* If there are no scenes listed under **"Scenes In Build"**, click **Add Open Scenes**.
* Click **Build And Run** to generate the executable and automatically launch it.
![image](/_fern-img/75ec161d31f3e8e8f84423770545c1258d6b5f4e5c8f6d814f228ad3546cf23d.webp)
## VR Support
To enable VR support, go to **Edit** -> **Project Settings** -> **XR Plug-in Management**, click **Install XR Plugin Management** if it is not installed yet, and enable the provider of your headset. The ZED Unity plugin is compatible with **OpenVR**, **Oculus** and **OpenXR**.
### Oculus Rift
To run your application on Oculus Rift, you must also allow apps from unknown sources to run:
* Launch the Oculus App
* Go to *Settings > General* and allow **Unknown Sources**.
![image](/_fern-img/a2c5134688395cb7e421aea97e4b00a5b14a38640c4bb4b46edc631fddcfed3d.webp)
### Windows Mixed Reality
The ZED Unity plugin supports WMR headsets via SteamVR only, which requires different settings than described in Unity's [WMR Quick Start Guide](https://docs.unity3d.com/Manual/wmr_quick_start.html). If you have trouble building the app, check the following:
* Your platform must be set to PC, Mac & Linux Standalone (not Universal Windows Platform)
* You must enable the OpenVR provider in **XR Plug-in Management**
* You must have [Windows Mixed Reality for SteamVR](https://store.steampowered.com/app/719950/Windows_Mixed_Reality_for_SteamVR/) installed
