# Setting up the ZED X One Core for Monocular Vision
This guide explains how to set up a **[ZED X One Core](/docs/products/cameras/zedxone-core/)** camera for monocular vision on an NVIDIA® Jetson™ platform and use it to retrieve image and inertial data.
> The ZED X One Core streams **MIPI CSI-2** and requires a [ZED Link MIPI](/docs/products/embedded/zed-link-capture-card/mipi) capture card. If you are using a [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ZED X One GS or ZED X One 4K, follow [Setting up the ZED X One for Monocular Vision](/docs/products/cameras/zedxone/monocular-vision/) instead.
## Install the ZED Link MIPI driver
> **Important**: This procedure is valid only for an NVIDIA® Jetson AGX Orin™ Developer Kit equipped with a [ZED Link MIPI Quad](/docs/products/embedded/zed-link-capture-card/mipi/zed-link-mipi-quad/jetson-orin-agx-devkit-setup) capture card. Support for the NVIDIA® Jetson AGX Thor™ with Holoscan Sensor Bridge is currently in **beta**: refer to the [dedicated setup guide](/docs/products/embedded/zed-link-capture-card/mipi/zed-link-mipi-quad/jetson-agx-thor-devkit-setup).
The ZED X One Core requires a **ZED Link MIPI driver** to operate correctly. This driver configures the MIPI capture pipeline of the card and of the connected cameras, and it is **distributed separately** from the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ZED Link driver.
> The GMSL2 ZED Link driver and the ZED Link MIPI driver are **not interchangeable**. Installing the wrong one leaves the capture pipeline unconfigured and no camera is detected.
Download the package matching your capture card and your Jetson™ Linux (L4T) version from the [ZED X Camera Drivers](https://www.stereolabs.com/developers/drivers) page, install it with `dpkg`, and **reboot** the Developer Kit.
> If the ZED Link MIPI package is not yet listed on the drivers page for your L4T version, please contact [support@stereolabs.com](mailto:support@stereolabs.com).
The full assembly and driver installation procedure is described in the [ZED Link MIPI Quad on AGX Orin](/docs/products/embedded/zed-link-capture-card/mipi/zed-link-mipi-quad/jetson-orin-agx-devkit-setup) setup guide.
> The ZED X One Core does **not** support hot-plugging. Cameras must be connected and disconnected **only when the host is powered off**, and any change to the hardware configuration requires a **full reboot** of the host to take effect.
For troubleshooting, refer to the [MIPI Troubleshooting](/docs/products/embedded/zed-link-capture-card/mipi/troubleshooting) guide.
## Focus the lens (custom optics only)
> A ZED X One Core purchased **with optics** is **factory focused**, so this step can be skipped: the camera is ready to use as it is.
Focusing is only required on a camera purchased **without optics**, on which you mount your own lens. Mount the camera in its final position, open a live preview with `ZED_Explorer` or `ZED_Studio`, and adjust the lens until the image is sharp at the working distance of your application. Lock the lens in place once focus is correct: any later movement of the optics invalidates the calibration.
## Use the ZED X One Core with the ZED SDK
Once the capture card driver is installed, the ZED X One Core is handled by the ZED SDK like any other ZED X One camera. The SDK includes built-in support for data acquisition from a single camera through the `sl::CameraOne` class, allowing you to open and manage the camera directly without relying on external tools.
### Install the ZED SDK
The [ZED SDK](/docs/development/zed-sdk/) enables processing of image data from the ZED X One Core in monocular mode. The `sl::CameraOne` class provides the core functionality to retrieve raw and rectified images, as well as inertial data from the integrated BMI088 IMU.
To get started, [download and install the ZED SDK on your NVIDIA® Jetson™ platform](/docs/development/zed-sdk/linux/work-with-nvidia-jetson/).
Verify that the cameras are enumerated, with `ZED_Explorer` or `ZED_Studio`:
ZED_Explorer --all
ZED_Studio --list
### Sample code to open and use the ZED X One Core for monocular vision
**`C++`**
```cpp C++
#include <sl/CameraOne.hpp>
using namespace sl;
InitParametersOne init_parameters;
// Set any InitParametersOne as needed to configure the camera settings
sl::CameraOne zed_one;
// Open the camera
ERROR_CODE err = zed_one.open(init_parameters);
    exit(-1);
Mat bgra;
while (!exit_app) {
    if (zed_one.grab() == ERROR_CODE::SUCCESS) {
        zed_one.retrieveImage(bgra); // Retrieve the BGRA image (default format)
        // Any processing
// Close the camera
zed_one.close();
**`Python`**
```python Python
import pyzed.sl as sl
zed_one = sl.CameraOne()
init = sl.InitParametersOne()
# Set any InitParametersOne as needed to configure the camera settings
# Open the camera
err = zed_one.open(init)
    exit(1)
bgra = sl.Mat()
while not exit_app:
    if zed_one.grab() == sl.ERROR_CODE.SUCCESS:
        zed_one.retrieve_image(bgra)  # Retrieve the BGRA image (default format)
        # Any processing
# Close the camera
zed_one.close()
For more details on using the ZED SDK with monocular cameras, refer to the [ZED SDK API documentation](https://www.stereolabs.com/docs/api/).
## Use the ZED X One Core with NVIDIA® Libargus Camera API
The camera can be opened using the [Libargus Camera API](https://docs.nvidia.com/jetson/l4t-multimedia/group__LibargusAPI.html), the API provided by NVIDIA® on Jetson™ to open cameras connected via CSI.
Make sure the multimedia API is installed:
sudo apt install nvidia-l4t-jetson-multimedia-api
Then compile the camera sample:
cp -r /usr/src/jetson_multimedia_api/* ./
sudo apt install libgtk-3-dev
cd argus
mkdir build && cd build && cmake .. && make
cp apps/camera/ui/camera/argus_camera ./
./argus_camera
## Use the ZED X One Core with ROS 2
The [ZED ROS 2 wrapper](/docs/integrations/ros-2/) supports monocular ZED X One Core data publishing.
When launching the ZED ROS 2 node, set the `camera_model` parameter to `zedxonecore`:
ros2 launch zed_wrapper zed_camera.launch.py camera_model:=zedxonecore
For more details on using the ZED ROS 2 wrapper, refer to the [ZED ROS 2 documentation](/docs/integrations/ros-2/).
## Calibrate the ZED X One Core for monocular vision
ZED X One Core cameras purchased with optics are **factory calibrated**, and no further action is required to retrieve undistorted, metrically accurate images. You need to calibrate the camera yourself only in custom configurations:
* the camera was purchased **without optics** and you install your own custom lens;
* the lens is replaced, refocused, or moved in any way;
* the camera is used in conditions that alter its optical behavior, such as underwater or behind a glass that acts as an additional lens.
In these cases, you can calibrate the camera with the open source [`zed-opencv-calibration`](https://github.com/stereolabs/zed-opencv-calibration) tools. The `zed_mono_calibration` tool computes the camera's intrinsic parameters (focal length, principal point, and distortion coefficients) from multiple views of a checkerboard pattern.
### Prerequisites
* [ZED SDK](#install-the-zed-sdk) v5.5 or later
* OpenCV 4.x
* CUDA (compatible with your ZED SDK version)
* OpenGL libraries (GLEW, FreeGLUT)
* CMake 3.5+ and a C++17 compiler
* A printed checkerboard pattern with known square size and inner-edge counts
* A **focused and mechanically locked** lens
### Build the calibration tools
git clone https://github.com/stereolabs/zed-opencv-calibration.git
cd zed-opencv-calibration
cmake ..
make -j$(nproc)
### Run the calibration
If you don't know the serial number or ID of your camera, list the connected devices with:
ZED_Explorer --all
Then launch the calibration tool:
cd build/monocular_calibration/
./zed_mono_calibration
![image](/_fern-img/a1bebf1166b4de0b3456c5d97b8c81ad6b5ec1e8cbae1200b2c0e25c2ab4e8f9.webp)
The tool accepts the following parameters:
| Parameter               | Description                                       |
| `--h_edges <value>`     | Horizontal inner edges of the checkerboard        |
| `--v_edges <value>`     | Vertical inner edges of the checkerboard          |
| `--square_size <value>` | Square size in millimeters                        |
| `--svo <file>`          | Path to an SVO file to calibrate from a recording |
| `--fisheye`             | Use the fisheye lens model                        |
| `--id <id>`             | Camera ID of the ZED X One Core                   |
| `--sn <sn>`             | Serial number of the ZED X One Core               |
| `--help`, `-h`          | Display the help message                          |
Use `--fisheye` with the **fisheye lens option** of the ZED X One Core. The wide and narrow lens options use the default pinhole model.
For example, to calibrate a fisheye lens using a 12×9 checkerboard with 30 mm squares:
./zed_mono_calibration --fisheye --h_edges 12 --v_edges 9 --square_size 30.0
The calibration runs in two phases:
1. **Data acquisition**: Move the checkerboard in front of the camera and press **Spacebar** or **S** to capture each frame. The tool enforces quality checks (sharpness, diversity) and provides real-time feedback on X/Y coverage, size range, and skew.
2. **Calibration computation**: Computation triggers automatically once all metrics reach 100% with the minimum number of samples, or when the maximum sample count is reached.
When complete, the tool writes two files:
* `mono_calibration_SN<serial_number>.yml`: OpenCV format containing the camera matrix (K) and distortion coefficients.
* `SN<serial_number>_mono.conf`: ZED-compatible format covering all supported resolutions.
> To let the ZED SDK use your calibration automatically for the corresponding camera, copy the generated `.conf` file into the `settings` folder of your ZED SDK installation:
> * **Linux**: `/usr/local/zed/settings/`
> The file must be renamed to follow the `SNxxxxxxxx.conf` convention, where `xxxxxxxx` is the camera serial number (for example, `SN10025660.conf`).
> On **Windows**, a ZED X One Core camera cannot be connected and used directly, since the MIPI CSI-2 interface requires an NVIDIA® Jetson™ platform. You can still work with ZED X One Core data on Windows by playing back **SVO2 recordings** or by receiving a **local network stream** from a Jetson™ device. The streaming workflow, which applies to a single camera as well as to a stereo rig, is described in [Developing with ZED X One Core on a PC](/docs/products/cameras/zedxone-core/zed-x-one-core-on-a-pc). In these cases the `.conf` calibration file must be copied manually into the `C:\ProgramData\StereoLabs\settings\` folder, following the `SNxxxxxxxx.conf` naming convention described above.
### Validate the calibration with `zed_mono_checker`
After calibrating, use the `zed_mono_checker` tool to verify the result. It measures the reprojection error in real time against the detected checkerboard corners, giving you immediate feedback on calibration quality.
cd build/monocular_checker/
./zed_mono_checker
![image](/_fern-img/c2debde65a28285c3cc8bc958538879e539c47e1df346b0b5d9e3e233a294a21.webp)
By default, the checker uses the camera's internal calibration. To validate a specific calibration file, pass it with `--calib_opencv`:
./zed_mono_checker --calib_opencv mono_calibration_SN12345678.yml
The checker accepts the same camera, checkerboard, and lens parameters as the calibration tool, plus:
| `--calib_opencv <file>` | Path to a custom calibration YAML file to validate |
The reprojection error is displayed and color-coded:
* **Green**: below 0.5 px (good)
* **Orange**: 0.5–1.0 px (acceptable)
* **Red**: above 1.0 px (poor; recalibration recommended)
If the error is consistently in the red range, check that the lens is still firmly locked, then run `zed_mono_calibration` again, taking care to cover the full field of view with diverse checkerboard poses.
