# Accessing Raw NV12 Buffers
This guide explains how to access raw NV12 image buffers directly from the ZED SDK using the **RawBuffer API**. This is an advanced, zero-copy interface designed for performance-critical applications.
> This is an advanced low-level API. Improper use can crash the Argus stack responsible for camera operations or destabilize the system. Use this API only if you understand NVIDIA® multimedia buffer handling.
> This API is only available starting from ZED SDK version 5.2. It is supported on NVIDIA® Jetson™ platforms with [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras. It is not available on x86 platforms, with USB cameras, or using SVO and Network streaming as input sources.
## Overview
The RawBuffer API provides direct access to native **NvBufSurface** buffers from the ZED X One camera capture pipeline. Instead of copying image data, this API gives you a pointer to the underlying buffer, enabling **zero-copy integration** with NVIDIA multimedia frameworks.
### Use Cases
This API is particularly useful for:
* **GStreamer pipelines** – Feed camera frames directly into GStreamer without memory copies
* **NVIDIA DeepStream** – Low-latency inference pipelines for real-time object detection
* **Custom CUDA processing** – Direct GPU access to camera buffers
* **Hardware video encoding** – Direct integration with NVENC
## Enabling the API
The RawBuffer API is disabled by default. To enable it, define `SL_ENABLE_ADVANCED_CAPTURE_API` **before** including the ZED SDK header:
**`C++`**
```cpp C++
#define SL_ENABLE_ADVANCED_CAPTURE_API
#include <sl/CameraOne.hpp>
## Code Example
**`C++`**
```cpp C++
#include <nvbufsurface.h>  // NVIDIA buffer surface API
using namespace sl;
int main() {
    CameraOne zed;
    InitParametersOne init_params;
    init_params.camera_fps = 30;
    if (zed.open(init_params) != ERROR_CODE::SUCCESS) {
        return -1;
    while (true) {
            RawBuffer raw;
            if (zed.retrieveImage(raw) == ERROR_CODE::SUCCESS) {
                if (raw.isValid()) {
                    // Get NvBufSurface pointers (zero-copy)
                    void* nvbuf = raw.getRawBuffer();
                    // Cast to NvBufSurface* for use with NVIDIA APIs
                    NvBufSurface* surf = static_cast<NvBufSurface*>(nvbuf);
                    // Access buffer properties
                    uint64_t timestamp = raw.getTimestamp();
                    unsigned int width = raw.getWidth();
                    unsigned int height = raw.getHeight();
                    // Process the NV12 buffer with your pipeline...
                    // Example: feed to GStreamer, DeepStream, or custom CUDA kernel
                    // Buffer is automatically released when 'raw' goes out of scope
    zed.close();
    return 0;
## Integration with DeepStream
For NVIDIA® DeepStream integration, you can pass the `NvBufSurface` object directly to your inference pipeline:
**`C++`**
```cpp C++
#include <sl/Camera.hpp>
#include <nvds_meta.h>
// In your DeepStream pipeline loop:
RawBuffer raw;
if (zed.retrieveImage(raw) == ERROR_CODE::SUCCESS && raw.isValid()) {
    NvBufSurface* surface = static_cast<NvBufSurface*>(raw.getRawBuffer());
    // Feed surface to DeepStream batch
    // surface->surfaceList[0] contains the NV12 frame data
    // Process with nvinfer, nvtracker, etc.
## Important Warnings
> **DO NOT manually destroy the NvBufSurface** (e.g., do not call `NvBufSurfaceDestroy`, `NvBufSurfaceUnMap`, etc.). The buffers are owned and managed by the SDK. Manual destruction will cause crashes or undefined behavior.
* The SDK manages the buffer memory – you only have **read access**
* Hold the `RawBuffer` for as short a time as possible to avoid blocking the capture pipeline
* Currently, only `RAW_BUFFER_TYPE::NVBUFSURFACE` (NVIDIA® Argus native buffers) is supported
* This API is available only on **NVIDIA Jetson platforms** with [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras
## Buffer Format
The raw buffers contain **NV12** formatted image data:
* **Y plane**: Full-resolution luminance data
* **UV plane**: Half-resolution (2x2 subsampled) chrominance data
This is the native output format of the ZED X One capture pipeline (after the NVIDIA® ISP), providing maximum performance for pipelines that work with NV12 directly.
