# ZED Box 2
Congratulations on being the owner of a brand-new [ZED Box 2](https://www.stereolabs.com/store/products/zed-box-2) embedded PC!
![ZED Box 2](/_fern-files/_img/579c82d274a36264e0f3fa361fe2f39bc2dc4e32fb250f7032cec2ca3fc6b661.webp)
StereoLabs' [ZED Box 2](https://www.stereolabs.com/store/products/zed-box-2) is a compact, rugged edge AI computer powered by [NVIDIA® Jetson™ Orin™ NX](https://www.nvidia.com/en-us/autonomous-machines/embedded-systems/jetson-orin/) modules with native support for NVIDIA® **Super Mode**. It is designed for large-scale, multi-camera vision and robotics deployments: it aggregates up to **8 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras**, and its CAN, Ethernet, and digital I/O interfaces integrate it directly into robotic, automotive, and industrial automation systems.
## Main features
The **ZED Box 2** is a ready-to-use edge AI system: an **NVIDIA® Jetson™ Orin™ NX** compute module running in Super Mode, **8 native [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) camera inputs**, and industrial-grade I/O in a passively cooled aluminum enclosure, with an optional fan.
### Compute module
The ZED Box 2 is available with two [NVIDIA® Jetson™ Orin™ NX compute modules](https://www.nvidia.com/en-us/autonomous-machines/embedded-systems/jetson-orin/), so you can match the computing power to the requirements of your application:
| Model                            | ZED Box 2 NX 8GB                                         | ZED Box 2 NX 16GB                                        |
| AI module                        | Jetson Orin™ NX 8GB                                      | Jetson Orin™ NX 16GB                                     |
| AI performance (Super Mode)      | 117 TOPS                                                 | 157 TOPS                                                 |
| AI performance (non-Super modes) | 70 TOPS                                                  | 100 TOPS                                                 |
| CPU                              | 6-core Arm® Cortex®-A78AE, up to 2.0 GHz                 | 8-core Arm® Cortex®-A78AE, up to 2.0 GHz                 |
| GPU                              | 1024-core NVIDIA Ampere, 32 Tensor Cores, up to 1173 MHz | 1024-core NVIDIA Ampere, 32 Tensor Cores, up to 1173 MHz |
| Memory                           | 8 GB LPDDR5, 102 GB/s                                    | 16 GB LPDDR5, 102 GB/s                                   |
| Power modes                      | 10W, 15W, 20W, 40W, MAXN SUPER                           | 10W, 15W, 25W, 40W, MAXN SUPER                           |
**Super Mode** raises the maximum GPU and DLA frequencies of the Orin NX module, delivering up to 67% more AI performance than the standard power modes. Read the [Power Modes](/docs/products/embedded/zed-box-series/zed-box-2/power-modes) guide to select the mode that fits your application.
### GMSL2 camera connectivity
**[GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2)** connectivity is a **standard feature** of the ZED Box 2. It enables high-speed, low-latency, hardware-synchronized data transfer between the processing unit and your **ZED GMSL2 cameras**.
* **8 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ports** on two Quad FAKRA-Z connectors, 4 ports each.
* Compatible with all the **ZED X** and **ZED X One** camera models: ZED X, ZED X Mini, ZED X Nano, ZED X One GS, ZED X One S, and ZED X One 4K.
* Up to 8 stereo cameras at HD1200 30 FPS, or 4 at HD1200 60 FPS; up to 8 monocular cameras at HD1200 60 FPS; up to 4 ZED X One 4K at 4K 15 FPS.
* The **GMSL2 driver is pre-installed**. Connect the cameras before powering on the device: GMSL2 cameras are not hot-pluggable.
The [Using GMSL](/docs/products/embedded/zed-box-series/zed-box-2/using-gmsl) guide describes the supported multi-camera configurations, and how to synchronize the cameras with each other and with other devices.
### Connectivity
The connection ports are available on the front and rear panels, described in the [Connectivity guide](/docs/products/embedded/zed-box-series/zed-box-2/connectivity):
* 2x Quad [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) FAKRA-Z camera connectors
* 2x Gigabit Ethernet RJ45 (10/100/1000 Base-T)
* 2x CAN bus (DB9 connectors)
* 1x Sync + IO connector (DB9) for camera frame-sync trigger input/output and 1x configurable digital I/O
* 2x USB 3.1 Gen 1 Type-A
* 1x HDMI 2.1
* 1x Micro USB 2.0 Type-B for system flashing, OTG, and [serial console](/docs/products/embedded/zed-box-series/zed-box-2/serial-console) access
* **WiFi 6** (Intel AX210 module) with 2x external antennas
* 1x 12V fan power header
* Recovery and Reset buttons, power LED
### Storage memory
An internal **M.2 NVMe SSD** hosts the operating system and your data. Three capacities are available:
* 256 GB
* 1 TB
* 2 TB
### Power supply
The ZED Box 2 is powered through a screwable 2-pin terminal block DC input, accepting **10V to 32V**, with a maximum power consumption of **80W** (55W typical). The wide input range allows direct connection to 12V and 24V vehicle and robot power rails. See the [Connectivity guide](/docs/products/embedded/zed-box-series/zed-box-2/connectivity#power-input) for the pinout.
### Cooling
The ZED Box 2 features a **passively cooled aluminum enclosure** with an integrated heatsink and no moving parts. For sustained high-power workloads, an **optional fan kit** can be mounted on the heatsink and connected to the 12V fan header, as described in the [installation guide](/docs/products/embedded/zed-box-series/zed-box-2/installation#install-the-optional-fan).
### Software
The ZED Box 2 is shipped with a **pre-configured operating system**, including the NVIDIA® JetPack™ software stack, the **ZED SDK**, and the **GMSL2 drivers**, so it is operational out of the box. Flashing is only required to change the JetPack version or to recover the device. The [flashing guide](/docs/products/embedded/zed-box-series/zed-box-2/reset-update), with updated flash scripts, will be available soon.
## Specifications
| Category              | Specification                                              |
| Video encode          | 1x 4K60, 3x 4K30, 6x 1080p60, 12x 1080p30 (H.265)          |
| Video decode          | 1x 8K30, 2x 4K60, 4x 4K30, 9x 1080p60, 18x 1080p30 (H.265) |
| Dimensions            | 234.4 × 176.3 × 54.0 mm (9.23 × 6.94 × 2.13 in), L × W × H |
| Weight                | 2278 g (5.02 lbs) with fan                                 |
| Operating temperature | -20 °C to +50 °C (-4 °F to 122 °F)                         |
| Storage temperature   | -40 °C to +85 °C (-40 °F to 185 °F)                        |
| Humidity              | 10% to 90%, non-condensing                                 |
| Certifications        | CE, REACH, RoHS, EMC, FCC, IEC 62368-1                     |
| Warranty              | 2 years                                                    |
### Part numbers
| Model             | 256 GB SSD | 1 TB SSD   | 2 TB SSD   |
| ZED Box 2 NX 8GB  | ZBX-810110 | ZBX-810120 | ZBX-810130 |
| ZED Box 2 NX 16GB | ZBX-820110 | ZBX-820120 | ZBX-820130 |
## Hardware reference
* [Datasheets](https://www.stereolabs.com/datasheets) - the ZED Box 2 datasheet, with the technical drawings of the enclosure.
* [CAD Files](https://www.stereolabs.com/3dmodels) - the most up-to-date CAD files of all our products.
