# Remote access via Serial Console
The ZED Box 2 provides a Serial Console interface for low-level access to the system, via the Micro USB 2.0 Type-B port. This is useful when no display is connected to the HDMI port.
> The Serial Console is available only when the device is:
> * Booting up
> * Booted into Normal Mode (not Recovery Mode)
## Connecting to the Serial Console
* Connect a Micro USB cable from your host computer to the [Micro USB 2.0 - OTG](/docs/products/embedded/zed-box-series/zed-box-2/connectivity#micro-usb-20---otg) port on the rear panel of the ZED Box 2.
* Power on the ZED Box 2.
* On the host computer, open a terminal (`Ctrl+Alt+T`) and install `gtkterm` if not already installed:
  sudo apt-get install gtkterm
* Launch `gtkterm` from the terminal with the appropriate device path (usually `/dev/ttyACM0`):
  sudo gtkterm -p /dev/ttyACM0
  > **Info**
  > You can use other terminal emulators such as `minicom` or `screen` if you prefer.
* If the cable is connected before the device is powered on, the terminal will display the boot messages as the device starts up. When the boot is complete, you will see a login prompt.
  > If the cable is connected after the boot is complete, the terminal will not display any boot messages; you may need to press `Enter` a couple of times to see the login prompt.
  ![image](/_fern-files/_img/f9bb7b4d49f005a6ac57f697dec63ad1cc34e78110d75ba0e741e2bf0548d0fa.webp)
* Log in with your credentials (default credentials: `user`/`admin`).
  ![image](/_fern-files/_img/358f21e1b52b2ce6b0dfca7a6fe7779f3779350025e4daf3405d1786024c9e65.webp)
* You can now execute commands on the device via the Serial Console in the same way as you would via SSH.
