# Using GMSL with ZED Box
The ZED Box comes with an embedded GMSL2 capture card, so you can use a **ZED X** or any other GMSL camera.
## GMSL driver
The ZED X requires a GMSL driver. It comes already installed with the ZED Box.
You may need to install it manually, especially if you upgraded your system version. Go to [our website](https://www.stereolabs.com/developers/drivers#a840b02b2603) and download the driver version that fits with your L4T version.
To find your Jetson Linux (L4T) version, run
cat /etc/nv_tegra_release
You will obtain an output like this:
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug  1 19:57:35 UTC 2023
In this example, the L4T version is 35.4.1.
Then, open a terminal in the folder that contains the downloaded driver and run
sudo dpkg -i <the deb file path>
and reboot.
### ZED Box with 4-wire GMSL2 connectivity
The ZED Box provides 4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ports organized in 2 Groups (**A**, **B**):
* Group **A**: port **#0** and port **#1**
* Group **B**: port **#2** and port **#3**
![ZED Box GMSL2 port groups](/_fern-files/_img/96d8c17b874582c443fc6d2099234b4a57fec3ef621b283765c739c467aec72b.webp)
| Camera Type | Camera Model                                           | Max number of cameras **per Group**  | Max Resolution/FPS **per Group**                     |
| Monocular   | ZED X One GS ZED X One S                               | Up to 2 cameras                      | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One 4K                                           | 1 camera *only to port #0, #2*       | 4K\@15fps QHDPLUS\@15fps HD1200\@60fps HD1080\@60fps |
| Stereo      | ZED X ZED X Mini ZED X Nano                            | 1 Camera                             | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Stereo      | ZED X ZED X Mini ZED X Nano                            | Up to 2 Cameras                      | HD1200\@30fps HD1080\@30fps SVGA\@60fps              |
| Mixed\*     | ZED X One GS/ZED X One S + ZED X/ZED X Mini/ZED X Nano | 1 ZED X One GS/S + 1 ZED X/Mini/Nano | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
\* *Mixed configurations are not available with older versions of the ZED Box powered by Jetson Xavier NX modules.*
> Maximum resolution and framerate require no more than 2 cameras per 4-wire [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra connector.
### ZED Box with mono GMSL2 port *(out of production)*
This out of production version of the ZED Box provides a single [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) port, so only one camera can be connected.
| Camera Type | Camera Model                | Max Resolution/FPS                                   |
| Monocular   | ZED X One GS ZED X One S    | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One 4K                | 4K\@15fps QHDPLUS\@15fps HD1200\@60fps HD1080\@60fps |
| Stereo      | ZED X ZED X Mini ZED X Nano | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
## Developing your own driver
If you intend to use a GMSL device alongside a StereoLabs ZED X camera, a custom driver is required for compatibility.
In such cases, we recommend reaching out to our support team at [support@stereolabs.com](mailto:support@stereolabs.com) for more information and assistance.
