# ZED Link Duo on AGX Orin
This tutorial will help you set up the **[ZED Link Duo](https://www.stereolabs.com/store/products/zed-link-capture-card)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, and use the StereoLabs [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras with the NVIDIA® Jetson™ **AGX Orin** Developer Kit.
## Prerequisites
* 1x [NVIDIA® Jetson™ AGX Orin Developer Kit](https://store.stereolabs.com/products/nvidia-jetson-agx-orin-developer-kit)
* 1x [ZED Link Duo](https://www.stereolabs.com/store/products/zed-link-capture-card) [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card
* 1x 1-to-4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra Male to Female cable (included in the box)
* 1x NVIDIA® power supply to power the DevKit (included with the devkit)
> The ZED Link Duo card does not need external power when connected to an NVIDIA® Jetson™ AGX devkit.
If you encounter any issues during the installation process, please refer to the [GMSL2 troubleshooting page](/docs/products/embedded/zed-link-capture-card/gmsl2/troubleshooting), or contact [support@stereolabs.com](mailto:support@stereolabs.com).
Please make sure the AGX DevKit is **powered off** and not connected to a power source before installing the capture card.
Plug the capture card into the 'Camera connector' slot and secure it using the three provided screws, as shown in the following diagrams:
![AGX Orin bottom view](/_fern-img/368517e103e1d6d16a6378f1b5fc9cbef5fbde072e7e6f679b3fc64ee44f7a6b.webp)
> It's important to **use the provided spacers and screws** to ensure a secure fit and avoid damaging the ZED Link device and the NVIDIA® Jetson™ AGX Developer Kit carrier board. StereoLabs is not responsible for any damage caused by improper installation and will not provide support for issues arising from incorrect installation procedures.
![AGX Orin capture card installation](/_fern-img/e4dd8c7c31714fdefbb0ffa7a246579fbb1fe78be7f3db61243e2422561f6042.webp)
> The capture card is powered by the Dev Kit, therefore **you do not need** to use an additional power supply for the card.
![Capture card on AGX](/_fern-img/9891fb5df41ee997a6f4f0a9183ea134278d981c89aa2d957a2f1773e7428c8b.webp)
### Connect the camera
Connect the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra cable **female** end to your [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) camera. When you hear a *click*, the cable is securely connected to the camera.
![ZED X with Fakra cable](/_fern-img/95694c2856777b637c70f659e0d336d588116951a7df4c1afb0648869ef4bcb6.webp)
With the DevKit still **powered off**, connect the **male** end of the cable to the capture card's [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) input. Again, a *click* informs you that the cable is **secured**.
### AGX Orin Developer Kit Enclosure
If you are using an **AGX Orin Developer Kit**, we recommend you use the [Enclosure for the AGX Orin Developer Kit](https://store.stereolabs.com/products/enclosure-for-orin-agx-devkit) available for purchase on the StereoLabs store, to **securely integrate** our [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Capture Card while keeping the electronics safe. It also allows you to mount the Dev Kit on any surface using **VESA 75x75**, and gives the possibility to add **WiFi antennas** to boost your AGX Orin wireless transmissions.
![AGX Orin with enclosure](/_fern-img/4098c22836b4d970ae6eb8d41a3ad50356a9adf4ea4b3fcaa42e36dfd41c4a22.webp)
#### Installing the AGX Orin Enclosure
With the capture card **already installed** (as shown above) on the Dev Kit, place the enclosure and screw it in as shown below:
![AGX Orin enclosure installation](/_fern-img/60733fee2506f072532c98b5ceabdd716ead1135aa4f1efdb63ed12dd1d92aae.webp)
Now that the Developer Kit has been correctly set up, we can install the **associated software** and **drivers** for the ZED [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras.
## Setting up the software
After setting up your ZED Link [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, please follow this guide to [Install the ZED Link Driver](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers/).
### Install the ZED SDK
The ZED Link Duo provides 4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ports organized in 2 Groups (**A**, **B**):
* Group **A**: port **#0** and port **#1**
* Group **B**: port **#2** and port **#3**
![ZED Link Duo connections](/_fern-img/96d8c17b874582c443fc6d2099234b4a57fec3ef621b283765c739c467aec72b.webp)
| Camera Type | Camera Model                                             | Max number of cameras **per Group**  | Max Resolution/FPS **per Group**                           |
| Monocular   | ZED X One GS / ZED X One S                               | Up to 2 cameras                      | HD1200\@60fps / HD1080\@60fps / SVGA\@120fps               |
| Monocular   | ZED X One 4K                                             | 1 camera (only to port #0, #2)       | 4K\@15fps / QHDPLUS\@15fps / HD1200\@60fps / HD1080\@60fps |
| Stereo      | ZED X / ZED X Mini / ZED X Nano                          | 1 Camera                             | HD1200\@60fps / HD1080\@60fps / SVGA\@120fps               |
| Stereo      | ZED X / ZED X Mini / ZED X Nano                          | Up to 2 Cameras                      | HD1200\@30fps / HD1080\@30fps / SVGA\@60fps                |
| Mixed       | ZED X One GS/ZED X One S + ZED X/ZED X Mini / ZED X Nano | 1 ZED X One GS/S + 1 ZED X/Mini/Nano | HD1200\@60fps / HD1080\@60fps / SVGA\@120fps               |
> Maximum resolution and framerate require no more than 2 cameras per 4-wire [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra connector.
