# ZED Link Duo on Orin Nano
This tutorial will help you set up the **[ZED Link Duo](https://www.stereolabs.com/store/products/zed-link-capture-card)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, and use the StereoLabs [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras with the NVIDIA® Jetson™ **Orin Nano** Developer Kit.
> NVIDIA® does not manufacture a development kit specifically for the Jetson™ **Orin NX** module. However, the carrier board of the Jetson™ **Orin Nano** Developer Kit is fully compatible with the **Orin NX** module. Therefore, you can use this setup to test the **Orin NX** module. Read more [here](https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonOrinNxNanoSeries.html).
## Prerequisites
* 1x NVIDIA® Jetson™ Orin Nano Developer Kit or NVIDIA® Jetson™ Orin Nano Developer Kit mounting an Orin NX module.
* 1x [ZED Link Duo](https://www.stereolabs.com/store/products/zed-link-capture-card) [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card
* 1x 1-to-4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra Male to Female cable (included in the box)
* 1x NVIDIA® power supply to power the Development Kit (included with the devkit)
* 2x FPC Camera Cable 22-pin 0.5mm Pitch to 15-pin 1.0mm Pitch (not included)
* 9V-19V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (not included)
> FPC Camera Cables transmit video signals. If the cable length exceeds 12 cm, the video signal may become noisy or corrupted. We recommend keeping the cable length within this limit.
![Orin Devkit Material](/_fern-files/stereolabs.docs.buildwithfern.com/f4ea377da0479c0bcc739ad6e2a4f264bc3246057a97b0e2ecc601260442e4e1/docs/products/cameras/zedx/images/orin-devkit-material.webp)
If you encounter any issues during the installation process, please refer to the [troubleshooting page](/docs/products/embedded/zed-link-capture-card/gmsl2/troubleshooting) or contact [support@stereolabs.com](mailto:support@stereolabs.com).
### Cabling the GMSL2 Capture Card
Connect both CSI cables to the MIPI 15-pin ports of the capture card. Make sure the correct side is plugged in for each port.
![Orin Devkit Capture Card Cabling](/_fern-files/stereolabs.docs.buildwithfern.com/63e7bf599d98c76235387473c2be47e852ce0dcaaa3b4665d0655838d8d4363d/docs/products/cameras/zedx/images/orin-devkit-capture-card-cabling.webp)
> Inverting the side might damage the carrier board or the capture card.
Both MIPI cables must be connected to have access to 2x ZED X on the capture card.
### Cabling the Carrier Board
Make sure that `CAM1` is connected to the centered MIPI port of the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card.
`CAM0` must be connected to the MIPI port close to the edge.
![Orin Devkit Carrier Board Cabling](/_fern-files/stereolabs.docs.buildwithfern.com/194206b7cfae04495fe48927785cdf4d79e244bd03a48605d5a0be1091ae738d/docs/products/cameras/zedx/images/orin-devkit-carrier-board-cabling.webp)
Once connected, the setup should look like the following picture:
![Orin Devkit Cabled](/_fern-files/stereolabs.docs.buildwithfern.com/6ef02ee1aeee2132366b100c7e3048407f9543e9edbc5020ddb57d4d19e72062/docs/products/cameras/zedx/images/orin-devkit-cabled.webp)
### Connect the camera
Connect the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra cable **female** end to your ZED X. When you hear a *click*, the cable is securely connected to the camera.
![ZED X with Fakra Cable](/_fern-files/stereolabs.docs.buildwithfern.com/95694c2856777b637c70f659e0d336d588116951a7df4c1afb0648869ef4bcb6/docs/products/embedded/zed-link-capture-card/images/zed-x-with-fakra-cable.webp)
With the capture card still **powered off**, connect the **male** end of the cable to the capture card's [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) input. Again, a *click* informs you that the cable is **secured**.
> Ideally, [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras should be plugged in before booting up. If this is not the case, you can restart the `zed_x_daemon` that will be installed by the driver in the next section.
![Orin Devkit Plug Camera](/_fern-files/stereolabs.docs.buildwithfern.com/337454958a7874044b78bf1e25c8b2c3a58fb1dc0cf50b11dc232994cff21726/docs/products/cameras/zedx/images/orin-devkit-plug-camera.webp)
Once the cables are connected, plug the power for the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (9V-19V) so that cameras will be powered through the FAKRA cable (PoC).
Now that the Developer Kit has been correctly set up, we can install the **associated software** and **drivers** for the ZED [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras.
## Setting up the software
After setting up your ZED Link [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, please follow this guide to [Install the ZED Link Driver](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers/).
### Install the ZED SDK
The ZED Link Duo provides 4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ports organized in 2 Groups (**A**, **B**):
* Group **A**: port **#0** and port **#1**
* Group **B**: port **#2** and port **#3**
![ZED Link Duo Connections](/_fern-img/96d8c17b874582c443fc6d2099234b4a57fec3ef621b283765c739c467aec72b.webp)
| Camera Type | Camera Model                                           | Max number of cameras **per Group**  | Max Resolution/FPS **per Group**                     |
| Monocular   | ZED X One GS ZED X One S                               | Up to 2 cameras                      | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One 4K                                           | 1 camera *only to port #0, #2*       | 4K\@15fps QHDPLUS\@15fps HD1200\@60fps HD1080\@60fps |
| Stereo      | ZED X ZED X Mini ZED X Nano                            | 1 Camera                             | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Stereo      | ZED X ZED X Mini ZED X Nano                            | Up to 2 Cameras                      | HD1200\@30fps HD1080\@30fps SVGA\@60fps              |
| Mixed       | ZED X One GS/ZED X One S + ZED X/ZED X Mini/ZED X Nano | 1 ZED X One GS/S + 1 ZED X/Mini/Nano | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
> Maximum resolution and framerate require no more than 2 cameras per 4-wire [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra connector.
