# ZED Link Duo on Xavier NX
This tutorial will help you set up the **[ZED Link Duo](https://www.stereolabs.com/store/products/zed-link-capture-card)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, and use the StereoLabs [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras with the NVIDIA® Jetson™ **Xavier NX** Developer Kit.
## Prerequisites
* 1x NVIDIA® Jetson™ Xavier NX Developer Kit.
* 1x [ZED Link Duo](https://www.stereolabs.com/store/products/zed-link-capture-card) [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card
* 1x 1-to-4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra Male to Female cable (included in the box)
* 1x NVIDIA® power supply to power the Development Kit (included with the devkit)
* 2x FPC Camera Cable 15-pin 1.0mm (not included)
* 9V-19V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (not included)
> The 15-pin CSI cable must not be mistaken for a DSI cable, where the active pin connection is on the same side.
> On CSI, the 15 pins are on the opposite side when looking at the flat cable. The cable can be purchased at [UCTRONICS](https://www.uctronics.com/ribbon-fpc-15-pin-flat-cable-15cm-for-raspberry-pi-camera-p-1839l.html).
> MIPI cables carry high-speed video signals, and longer cables can introduce noise or signal degradation. For optimal performance, use cables no longer than 12 cm.
![Xavier NX material](/_fern-img/57ee72326012524c3a72468fbdef5bba9b9cf8c65a97e39b2f1849cb8e04830b.webp)
If you encounter any issues during the installation process, please refer to the [troubleshooting page](/docs/products/embedded/zed-link-capture-card/gmsl2/troubleshooting) or contact [support@stereolabs.com](mailto:support@stereolabs.com).
### Cabling the GMSL2 Capture Card
Connect the CSI cables to the MIPI 15-pin ports of the capture card. Make sure the correct side is plugged in for each port.
![Xavier NX capture card cabling](/_fern-img/4d5e35e1e9de12469a109e4f634e910d805aac39640e39233d60ea0735244a11.webp)
> Inverting the side might damage the carrier board or the capture card.
Both MIPI cables must be connected to have access to 2x ZED [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras on the capture card.
### Cabling the Carrier Board
Connect the CSI cables to the carrier board 15-pin connectors.
Make sure that `J9`/`CAM0` is connected to the centered MIPI port of the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card.
`J1`/`CAM1` must be connected to the MIPI port close to the edge.
![Xavier NX capture card cabling orientation](/_fern-img/4df8799f424cd70dd9b1c4b6bd50bbfd1524461fe4079f1adc3f9c98d62a3cb9.webp)
Once connected, the setup should look like the following picture:
![Xavier NX cabled](/_fern-img/de8626b7b57e740b579077bc0848f04dc1c6718b7f2b8ec1dab9c302237101b2.webp)
### Connect the camera
Connect the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra cable **female** end to your ZED X. When you hear a *click*, the cable is securely connected to the camera.
![ZED X with Fakra cable](/_fern-img/95694c2856777b637c70f659e0d336d588116951a7df4c1afb0648869ef4bcb6.webp)
With the capture card still **powered off**, connect the **male** end of the cable to the capture card's [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) input. Again, a *click* informs you that the cable is **secured**.
> Ideally, [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras should be plugged in before booting up. If this is not the case, you can restart the `zed_x_daemon` that will be installed by the driver in the next section.
![Xavier NX plug camera](/_fern-img/0c1c69d6f89f8902377d7174d5169ca670a20060cd69e880415033fc61210d4e.webp)
Once the cables are connected, plug the power for the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (9V-19V) so that cameras will be powered through the FAKRA cable (PoC).
Now that the Developer Kit has been correctly set up, we can install the **associated software** and **drivers** for the ZED [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras.
## Setting up the software
After setting up your ZED Link [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, please follow this guide to [Install the ZED Link Driver](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers/).
### Install the ZED SDK
The ZED Link Duo provides 4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ports organized in 2 Groups (**A**, **B**):
* Group **A**: port **#0** and port **#1**
* Group **B**: port **#2** and port **#3**
![ZED Link Duo connections](/_fern-img/96d8c17b874582c443fc6d2099234b4a57fec3ef621b283765c739c467aec72b.webp)
| Camera Type | Camera Model                | Max number of cameras **per Group** | Max Resolution/FPS **per Group**                     |
| Monocular   | ZED X One GS ZED X One S    | Up to 2 cameras                     | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One 4K                | 1 camera *only to port #0, #2*      | 4K\@15fps QHDPLUS\@15fps HD1200\@60fps HD1080\@60fps |
| Stereo      | ZED X ZED X Mini ZED X Nano | 1 Camera                            | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Stereo      | ZED X ZED X Mini ZED X Nano | Up to 2 Cameras                     | HD1200\@30fps HD1080\@30fps SVGA\@60fps              |
> Maximum resolution and framerate require no more than 2 cameras per 4-wire [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra connector.
