# ZED Link Mono on Orin Nano
This tutorial will help you set up the **[ZED Link Mono](https://www.stereolabs.com/store/products/zed-link-capture-card-mono)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, and use the StereoLabs [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras with the NVIDIA® Jetson™ **Orin Nano** Developer Kit.
> NVIDIA® does not manufacture a development kit specifically for the Jetson™ **Orin NX** module. However, the carrier board of the Jetson™ **Orin Nano** Developer Kit is fully compatible with the **Orin NX** module. Therefore, you can use this setup to test the **Orin NX** module. Read more [about Jetson Orin NX/Nano series adaptation](https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonOrinNxNanoSeries.html).
## Prerequisites
* 1x NVIDIA® Jetson™ Orin Nano Developer Kit or NVIDIA® Jetson™ Orin Nano Developer Kit mounting an Orin NX module.
* 1x **[ZED Link Mono](https://www.stereolabs.com/store/products/zed-link-capture-card-mono)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card
* 1x NVIDIA® power supply to power the Development Kit (included with the devkit)
* 1x FPC Camera Cable 22-pin 0.5mm Pitch (included in the box)
* 9V-14V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (not included)
> MIPI cables transmit video signals. As the cable length increases, the video signal becomes noisier. The maximum recommended length is 12 cm.
![ZED Link Mono Orin Nano material](/_fern-img/fe7692d013974ff78a232eba372cb2b2ef0acac8dd95d9c759905e3913b35263.webp)
If you encounter any issues during the installation process, please refer to the [troubleshooting page](/docs/products/embedded/zed-link-capture-card/gmsl2/troubleshooting) or contact [support@stereolabs.com](mailto:support@stereolabs.com).
### Cabling the GMSL2 Capture Card
Connect the power adapter cable to the white **PWR J3** connector.
![ZED Link Mono Orin Nano power](/_fern-img/7a598927c14274be13b99f8ffe025c15b573c58a456e0b21e7aaac151889ddc0.webp)
Connect the CSI cable to the MIPI 22-pin port of the capture card. Make sure the correct side is plugged in.
![ZED Link Mono Orin Nano MIPI](/_fern-img/188ef843bb95e365e40951cd8485951353724cb7fd86b0c868d2294e4a6518d5.webp)
> Inverting the side might damage the carrier board or the capture card.
### Cabling the Carrier Board
![ZED Link Mono Orin Nano MIPI carrier board connection](/_fern-img/179dbac4572bf9a5ddc874f54bc6937e97752d123561c9841f89021017df72c5.webp)
### Connect the camera
Connect the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra cable **female** end to your [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) camera. When you hear a *click*, the cable is securely connected to the camera.
![ZED X camera with Fakra cable connected](/_fern-files/stereolabs.docs.buildwithfern.com/95694c2856777b637c70f659e0d336d588116951a7df4c1afb0648869ef4bcb6/docs/products/embedded/zed-link-capture-card/images/zed-x-with-fakra-cable.webp)
With the capture card still **powered off**, connect the **male** end of the cable to the capture card's [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) input. Again, a *click* informs you that the cable is **secured**.
![ZED Link Mono Fakra cable connection](/_fern-img/cbb0303d4779571affebc506c3287bbb65c0a05c479be0ce3979f0e66e258911.webp)
> Ideally, [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras should be plugged in before booting up. If this is not the case, you can restart the `zed_x_daemon` that will be installed by the driver in the next section.
Once the cables are connected, plug the power for the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (9V-14V) so that cameras will be powered through the FAKRA cable (PoC).
![Power adapter connection to ZED Link Mono](/_fern-img/d4a08d04f4ec846445b73534a2924442fa109e158e4b084fefc3d8bcc9413b39.webp)
Now that the Developer Kit has been correctly set up, we can install the **associated software** and **drivers** for the ZED [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras.
## Setting up the software
After setting up your ZED Link [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, please follow this guide to [Install the ZED Link Driver](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers/).
### Install the ZED SDK
## Camera configurations
The ZED Link Mono provides a single [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) port, so only one camera can be connected to the capture card.
| Camera Type | Camera Model | Max Resolution/FPS                                   |
| Monocular   | ZED X One GS | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One S  | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One 4K | 4K\@15fps QHDPLUS\@15fps HD1200\@60fps HD1080\@60fps |
| Stereo      | ZED X        | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Stereo      | ZED X Mini   | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Stereo      | ZED X Nano   | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
