# ZED Link Mono on Xavier NX
This tutorial will help you set up the **[ZED Link Mono](https://www.stereolabs.com/store/products/zed-link-capture-card-mono)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, and use the StereoLabs [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras with the NVIDIA® Jetson™ **Xavier NX** Developer Kit.
## Prerequisites
* 1x NVIDIA® Jetson™ Xavier NX Developer Kit.
* 1x **[ZED Link Mono](https://www.stereolabs.com/store/products/zed-link-capture-card-mono)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card
* 1x NVIDIA® power supply to power the Development Kit (included with the devkit)
* 1x FPC Camera Cable 22-pin 0.5mm Pitch to 15-pin 1.0mm Pitch (not included)\*
* 9V-14V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (not included)
\* You can find the FPC Camera Cable 22 pin 0.5 pitch to 15-pin 1mm pitch at [UCTRONICS](https://www.uctronics.com/arducam-15-pin-1-0mm-pitch-to-22-pin-0-5mm-camera-cable-for-raspberry-pi-zero-version-1-3-with-150mm-and-73mm-pack-of-2.html).
> MIPI cables carry high-speed video signals, and longer cables can introduce noise or signal degradation. For optimal performance, use cables no longer than 12 cm.
![ZED Link Mono Xavier NX material](/_fern-files/_img/388efbec3fa6711efbb7fc5618cfd029ca0adc268c6ce0121126bba4dd4c0f1d.webp)
If you encounter any issues during the installation process, please refer to the [troubleshooting page](/docs/products/embedded/zed-link-capture-card/gmsl2/troubleshooting) or contact [support@stereolabs.com](mailto:support@stereolabs.com).
### Cabling the GMSL2 Capture Card
Connect the power adapter cable to the white **PWR J3** connector.
![ZED Link Mono power connection](/_fern-files/_img/7a598927c14274be13b99f8ffe025c15b573c58a456e0b21e7aaac151889ddc0.webp)
Connect the CSI cable to the MIPI 22-pin port of the capture card. Make sure the correct side is plugged in.
![ZED Link Mono Xavier NX MIPI connection](/_fern-files/_img/807dcf03f677fc16951e2c6ecf34d7a2cdfe8373540d1102603ff37064ec3aae.webp)
> Inverting the side might damage the carrier board or the capture card.
### Cabling the Carrier Board
Connect the CSI cable to the carrier board 15-pin connector.
![ZED Link Mono Xavier NX MIPI carrier connection](/_fern-files/_img/87f28e3f0e951f6b8c992587a120fff10219de19a2c94f07cbcdf18d32254383.webp)![ZED Link Mono Xavier NX MIPI carrier both connections](/_fern-files/_img/fc2a919a8cbc06f308eb095dcad14568c94ef69884597277e472f9f75894988c.webp)
### Connect the camera
Connect the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra cable **female** end to your [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) camera. When you hear a *click*, the cable is securely connected to the camera.
![ZED X with FAKRA cable](/_fern-files/_img/95694c2856777b637c70f659e0d336d588116951a7df4c1afb0648869ef4bcb6.webp)
With the capture card still **powered off**, connect the **male** end of the cable to the capture card's [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) input. Again, a *click* informs you that the cable is **secured**.
![ZED Link Mono FAKRA connection](/_fern-files/_img/cbb0303d4779571affebc506c3287bbb65c0a05c479be0ce3979f0e66e258911.webp)
> Ideally, [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras should be plugged in before booting up. If this is not the case, you can restart the `zed_x_daemon` that will be installed by the driver in the next section.
Once the cables are connected, plug the power for the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (9V-14V) so that cameras will be powered through the FAKRA cable (PoC).
![Power adapter connection](/_fern-files/_img/d4a08d04f4ec846445b73534a2924442fa109e158e4b084fefc3d8bcc9413b39.webp)
Now that the Developer Kit has been correctly set up, we can install the **associated software** and **drivers** for the ZED [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras.
## Setting up the software
After setting up your ZED Link [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, please follow this guide to [Install the ZED Link Driver](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers/).
### Install the ZED SDK
## Camera configurations
The ZED Link Mono provides a single [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) port, so only one camera can be connected to the capture card.
| Camera Type | Camera Model                | Max Resolution/FPS                                   |
| Monocular   | ZED X One GS ZED X One S    | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One 4K                | 4K\@15fps QHDPLUS\@15fps HD1200\@60fps HD1080\@60fps |
| Stereo      | ZED X ZED X Mini ZED X Nano | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
