# ZED Link Quad on AGX Orin
This tutorial will help you set up the **[ZED Link Quad](https://www.stereolabs.com/store/products/zed-link-capture-card-quad)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, and use the StereoLabs [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras with the NVIDIA® Jetson™ **AGX Orin** Developer Kit.
## Prerequisites
* 1x NVIDIA® Jetson™ AGX Orin Developer Kit.
* 1x **[ZED Link Quad](https://www.stereolabs.com/store/products/zed-link-capture-card-quad)** [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card
* 2x 1-to-4 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra Male to Female cables (included in the box)
* 1x NVIDIA® power supply to power the Development Kit (included with the devkit)
* 9V-19V (min 6W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (not included)
* \[Optional] **[Enclosure for AGX Orin Developer Kit](https://store.stereolabs.com/products/enclosure-for-orin-agx-devkit)**
![ZED Link Quad on AGX Orin materials](/_fern-img/f12fb66f785156fe023439b5be6edcb0cdb0b960d9c66a40d0c492a748c7cc48.webp)
If you encounter any issues during the installation process, please refer to the [troubleshooting page](/docs/products/embedded/zed-link-capture-card/gmsl2/troubleshooting) or contact [support@stereolabs.com](mailto:support@stereolabs.com).
Plug the capture card into the ‘Camera connector’ slot and secure it using the three provided screws:
![ZED Link Quad camera connector](/_fern-img/b649494e1886986be9211b89135a60021ea6bbf92df964291fe537e3f0d50aad.webp)
> It's important to **use the provided spacers and screws** to ensure a secure fit and avoid damaging the ZED Link device and the NVIDIA® Jetson™ AGX Developer Kit carrier board. StereoLabs is not responsible for any damage caused by improper installation and will not provide support for issues arising from incorrect installation procedures.
![ZED Link Quad screws installation](/_fern-img/7f41d340855e08b3d51f9ae9ebb06c8dd5aea2b8733011945a2423728d8a5955.webp)
Connect the power adapter cable to the white **J10** connector.
![ZED Link Quad power connection](/_fern-img/6b4dcc457b7364cdde195deec7c5509891d0fa4b74a8a67f0bbe1080fd74acfd.webp)
### \[Optional] AGX Orin Developer Kit Enclosure
If you are using an **AGX Orin Developer Kit**, we recommend you use the [Enclosure for the AGX Orin Developer Kit](https://store.stereolabs.com/products/enclosure-for-orin-agx-devkit) available for purchase on the StereoLabs store, to **securely integrate** our [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Capture Card while keeping the electronics safe. It also allows you to mount the Dev Kit on any surface using **VESA 75x75**, and gives the possibility to add **WiFi antennas** to boost your AGX Orin wireless transmissions.
![AGX Orin with enclosure](/_fern-img/4098c22836b4d970ae6eb8d41a3ad50356a9adf4ea4b3fcaa42e36dfd41c4a22.webp)
#### Installing the AGX Orin Enclosure
With the capture card **already installed** (as shown above) on the Dev Kit, place the enclosure and screw it in as shown below:
![AGX Orin enclosure installation](/_fern-img/60733fee2506f072532c98b5ceabdd716ead1135aa4f1efdb63ed12dd1d92aae.webp)
### Connect the camera
Connect one of the 8 wires from the **female** end of the two [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) 1-to-4 Fakra cables to your [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) camera. When you hear a *click*, the cable is securely connected to the camera.
![ZED X with Fakra cable](/_fern-img/95694c2856777b637c70f659e0d336d588116951a7df4c1afb0648869ef4bcb6.webp)
> Ideally, [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras should be plugged in before booting up. If this is not the case, you can restart the `zed_x_daemon` that will be installed by the driver in the next section.
Once the cables are connected, plug the power for the [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card (9V-19V) so that cameras will be powered through the FAKRA cable (PoC).
![Power adapter connection](/_fern-img/d4a08d04f4ec846445b73534a2924442fa109e158e4b084fefc3d8bcc9413b39.webp)
Now that the Developer Kit has been correctly set up, we can install the **associated software** and **drivers** for the ZED [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) cameras.
## Setting up the software
After setting up your ZED Link [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) capture card, please follow this guide to [Install the ZED Link Driver](/docs/products/embedded/zed-link-capture-card/gmsl2/install-and-upgrade-the-drivers/).
### Install the ZED SDK
The ZED Link Quad provides 8 [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) ports organized in 6 Groups (**A**, **B**, **C**, **D**, **E**, **F**):
* Group **A**: port **#0**
* Group **B**: port **#1**
* Group **C**: port **#2**
* Group **D**: port **#3**
* Group **E**: ports **#4** and **#5**
* Group **F**: ports **#6** and **#7**
![ZED Link Quad connections](/_fern-img/ebebf9332154278089822ca11408263692d5d0ce5d5ac9370c6f501f9986fdef.webp)
| Camera Type | Camera Model                                           | Max number of cameras **per Group**    | Max Resolution/FPS **per Group**                     |
| Monocular   | ZED X One GS ZED X One S                               | Up to 2 cameras                        | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Monocular   | ZED X One 4K                                           | 1 camera *only to port #0, #2, #4, #6* | 4K\@15fps QHDPLUS\@15fps HD1200\@60fps HD1080\@60fps |
| Stereo      | ZED X ZED X Mini ZED X Nano                            | 1 Camera                               | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
| Stereo      | ZED X ZED X Mini ZED X Nano                            | Up to 2 Cameras                        | HD1200\@30fps HD1080\@30fps SVGA\@60fps              |
| Mixed       | ZED X One GS/ZED X One S + ZED X/ZED X Mini/ZED X Nano | 1 ZED X One GS/S + 1 ZED X/Mini/Nano   | HD1200\@60fps HD1080\@60fps SVGA\@120fps             |
> Maximum resolution and framerate require no more than 2 cameras per 4-wire [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra connector.
### Enable full onboard synchronization
The ZED Link Quad card is essentially a composition of two ZED Link Duo cards. By default, the two [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) deserializers on the card are not synchronized together, causing the cameras connected to one 4-wire [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra connector to have different capture timestamps from the cameras connected to the second 4-wire [GMSL2](/docs/products/embedded/zed-link-capture-card/gmsl2#what-is-gmsl2) Fakra connector. To enable full synchronization, you must follow this procedure:
* Open a terminal (`Ctrl+Alt+T`)
* Edit the zed_x_daemon service file:
  sudo nano /etc/systemd/system/zed_x_daemon.service
  * Search for `sync_mode=<x>` and change it to `sync_mode=1`
  * Save the file and exit (`Ctrl+X`, `Y`, `Enter`)
* Instruct `systemd` to reload all service files and update its internal configuration
  sudo systemctl daemon-reload
* Connect the **pin #13** to the **pin #16** of the synchronization connector.
  *Unfortunately, the pins are not aligned, so you cannot use a jumper but you can use a small wire to connect the two pins together*.
  ![ZED Link Quad J17 sync connector](/_fern-img/5b1e4ac009380fc5c6b4ce714e0bb58c6c7105f91f94490e522d6635ae891d7d.webp)
  > It's not required to connect the **GND** pins together as they are already connected internally on the board.
* Restart the zed_x_daemon service
> Although frames are hardware-synchronized with 15µs precision, software timestamps are assigned upon driver receipt and may exhibit slight millisecond-level jitter. Frames are considered synchronized if the timestamp difference is less than one frame period (`1000/FPS` ms).
