Building a C++ Application on Windows
Build the Hello ZED tutorial with CMake and Visual Studio on Windows
This section explains how to build an application with the ZED SDK on Windows platforms.
Setting Up a Project
We will build a simple tutorial application Hello ZED using the ZED SDK and CMake. CMake is a cross-platform project generation tool. It provides an easy way to build project files that can be used in the compiler environment of your choice. For example, a CMake script can produce Visual Studio projects and solution files.
  • Download and install the latest ZED SDK.
  • Download the ZED Examples sample code available on our GitHub page. You can also browse our GitHub for additional plugins and sample codes.
  • Open the tutorials/tutorial 1 - hello ZED/cpp folder to find the code we will build. The following files should be in the directory:
    • CMakeLists.txt
    • main.cpp
    • README.md
Building on Windows
On Windows, building an application with the ZED SDK requires CMake 3.5.0 or higher and Visual Studio 2019 or 2022 (the ZED SDK requires a C++17 compiler since version 5.1). Applications must be compiled for 64-bit.
When installing Visual Studio, make sure to select the Visual C++ option.
  • Open cmake-gui.
  • In “Where is the source code“, enter the path of the project folder where the CMakeLists.txt is located. Here we created a project folder “ZED_Tutorial_1” in Documents.
  • In “Where to build the binaries“, enter the previous path and add: /build.
  • Click on [Configure].
  • A dialog window asks you if CMake can create the “build” folder. Say yes.
  • Another dialog window will ask you to specify a generator for your project. Choose Visual Studio in Win64 and click on [Finish].
CMake needs to define the target platform as x64. On newer versions it is set by default; if not, you can set it manually.
  • CMake may take a few seconds to configure the project.
  • Click on [Generate] to build the Visual Studio project files.
  • CMake has now generated your project in the build directory. You can directly open the solution by clicking on [Open Project] or by closing the cmake-gui window and opening the build folder.
  • A Visual Studio solution has been generated. Open ZED_Tutorial_1.sln and set it in Release mode.
  • To run the builds from the Build menu or from keyboard shortcuts, set the ZED_Tutorial_1 target as the startup project.
  • You can now edit and compile your program in the Visual Studio IDE. Hit the Ctrl+F5 key to launch the program.
