GStreamer - ZED X One Camera Source
The GStreamer element ZED X One Camera Source, zedxonesrc, injects the monocular color stream of a ZED X One camera into a GStreamer pipeline.
Properties
zedxonesrc is built and installed only on NVIDIA® Jetson™ platforms (L4T 35.3/35.4 or L4T 36.3 and newer), because the ZED X One cameras are connected through a GMSL2 capture card.
The following listing is the output of gst-inspect-1.0 zedxonesrc:
async-grab-camera-recovery: Async Grab Camera Recovery
flags: readable, writable
Boolean. Default: false
blocksize : Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
camera-flip : Mirror image vertically if camera is flipped
camera-fps : Camera frame rate
Enum "GstZedXOneSrcFPS" Default: 30, "30 FPS"
(120): 120 FPS - Only with SVGA. Not with ZED X One 4K
(60): 60 FPS - Not available with 4K mode
(30): 30 FPS - Available with all the resolutions
(15): 15 FPS - Available with all the resolutions
camera-id : Select camera from cameraID
Integer. Range: -1 - 255 Default: -1
camera-resolution : Camera Resolution
Enum "GstZedXOneSrcResol" Default: 2, "HD1200"
(4): 4K - 3840x2160 (only ZED X One 4K)
(3): QHDPLUS - 3200x1800 (only ZED X One 4K)
(2): HD1200 - 1920x1200
(1): HD1080 - 1920x1080
(0): SVGA - 960x600 (only ZED X One GS)
camera-sn : Select camera from the serial number
Integer64. Range: 0 - 999999999 Default: 0
camera-timeout : Connection opening timeout in seconds
Float. Range: 0.5 - 86400 Default: 5
coordinate-system : SDK Coordinate System
Enum "GstZedXOneSrcCoordSys" Default: 0, "IMAGE"
(0): IMAGE - Standard image (0,0) at top left corner
(1): LEFT_HANDED_Y_UP - Left handed, Y up and Z forward
(2): RIGHT_HANDED_Y_UP - Right handed, Y up and Z backward
(3): RIGHT_HANDED_Z_UP - Right handed, Z up and Y forward
(4): LEFT_HANDED_Z_UP - Left handed, Z up and Y forward
(5): RIGHT_HANDED_Z_UP_X_FWD - Right handed, Z up and X forward
coordinate-units : SDK Coordinate Units
Enum "GstZedXOneSrcUnit" Default: 0, "MILLIMETER"
(0): MILLIMETER - Millimeter
(1): CENTIMETER - Centimeter
(2): METER - Meter
(3): INCH - Inch
(4): FOOT - Foot
ctrl-analog-gain : Camera control: Analog Gain value
Integer. Range: 1000 - 30000 Default: 30000
ctrl-auto-analog-gain: Enable Automatic Analog Gain
Boolean. Default: true
ctrl-auto-analog-gain-range-max: Maximum Analog Gain for the automatic analog gain setting
ctrl-auto-analog-gain-range-min: Minimum Analog Gain for the automatic analog gain setting
Integer. Range: 1000 - 30000 Default: 1000
ctrl-auto-digital-gain: Enable Automatic Digital Gain
ctrl-auto-digital-gain-range-max: Maximum Digital Gain for the automatic digital gain setting
Integer. Range: 1 - 256 Default: 256
ctrl-auto-digital-gain-range-min: Minimum Digital Gain for the automatic digital gain setting
Integer. Range: 1 - 256 Default: 1
ctrl-auto-exposure : Enable Automatic Exposure
ctrl-auto-exposure-range-max: Maximum exposure time in microseconds for the automatic exposure setting
Integer. Range: 28 - 66666 Default: 66666
ctrl-auto-exposure-range-min: Minimum exposure time in microseconds for the automatic exposure setting
Integer. Range: 28 - 66666 Default: 1024
ctrl-denoising : Denoising factor
Integer. Range: 0 - 100 Default: 50
ctrl-digital-gain : Digital Gain value
Integer. Range: 1 - 256 Default: 3
ctrl-exposure-compensation: Exposure Compensation
ctrl-exposure-time : Exposure time in microseconds
Integer. Range: 28 - 66666 Default: 10000
ctrl-gamma : Image gamma
Integer. Range: 1 - 9 Default: 2
ctrl-saturation : Image saturation
Integer. Range: 0 - 8 Default: 4
ctrl-sharpness : Image sharpness
Integer. Range: 0 - 8 Default: 1
ctrl-whitebalance-auto: Image automatic white balance
ctrl-whitebalance-temperature: Image white balance temperature
Integer. Range: 2800 - 6500 Default: 4200
do-timestamp : Apply current stream time to buffers
enable-hdr : Enable HDR if supported by resolution and frame rate.
input-stream-ip : Specify IP address when using streaming input
String. Default: ""
input-stream-port : Specify port when using streaming input
Integer. Range: 1 - 65535 Default: 30000
name : The name of the object
String. Default: "zedxonesrc0"
num-buffers : Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
opencv-calibration-file: Optional OpenCV Calibration File
String. Default: ""
optional-settings-path: Optional Settings Path
String. Default: ""
output-rectified-image: Enable image rectification (disable for custom optics without calibration)
parent : The parent of the object
Object of type "GstObject"
sdk-verbose-log-file: SDK Verbose Log File
String. Default: ""
stream-type : Image stream type
Enum "GstZedXOneSrcStreamType" Default: -1, "Auto [prefer NV12 zero-copy]"
(-1): Auto [prefer NV12 zero-copy] - Auto-negotiate format based on downstream (prefer NV12 zero-copy)
(0): Image [BGRA] - 8 bits- 4 channels image
svo-file-path : Input from SVO file
String. Default: ""
svo-real-time-mode : SVO Real Time Mode
svo-recording-compression: Compression mode for SVO recording
Enum "GstZedXOneSrcSvoCompression" Default: 2, "H265"
(0): LOSSLESS - Lossless (PNG/ZSTD, CPU)
(1): H264 - H264 (GPU)
(2): H265 - H265/HEVC (GPU)
(3): H264_LOSSLESS - H264 Lossless (GPU)
(4): H265_LOSSLESS - H265 Lossless (GPU)
svo-recording-enable: Start/stop SVO recording at runtime (requires svo-recording-filename to be set)
svo-recording-filename: Output filename for SVO recording (.svo2 extension recommended)
String. Default: ""
typefind : Run typefind before negotiating (deprecated, non-functional)
flags: readable, writable, deprecated
verbose-level : ZED SDK Verbose level
Integer. Range: 0 - 999 Default: 1
Zero-copy NV12 stream type
When the plugin is built against ZED SDK v5.2 or newer, stream-type exposes an additional value (1), Raw NV12 zero-copy [NV12], that pushes NV12 buffers in memory:NVMM without any CPU copy, for direct consumption by the Jetson hardware encoders.
The default value (-1), Auto [prefer NV12 zero-copy], negotiates the format with the downstream element and selects the zero-copy NV12 path when it is available, falling back to Image [BGRA] otherwise.
Example pipelines
Display the color stream on the screen with FPS information
This simple pipeline starts the ZED X One grabbing using the default parameters of the zedxonesrc element and automatically converts (autovideoconvert) the frames to the correct format for the fpsdisplaysink element in order to be displayed on the screen with FPS information.
gst-launch-1.0 zedxonesrc ! queue ! autovideoconvert ! queue ! fpsdisplaysink
The queue element is used to decouple frames in a different queue thread, useful for data synchronization for more complex pipelines.
When using the ZED X One 4K model, you can leverage the full 4K resolution (3840x2160) by selecting camera-resolution=4:
gst-launch-1.0 zedxonesrc camera-resolution=4 camera-fps=15 ! queue ! autovideoconvert ! queue ! fpsdisplaysink
The intermediate QHD+ resolution (3200x1800), also exclusive to the ZED X One 4K, is selected with camera-resolution=3:
gst-launch-1.0 zedxonesrc camera-resolution=3 camera-fps=30 ! queue ! autovideoconvert ! queue ! fpsdisplaysink
When using the ZED X One GS model, you can stream frames at 1200p resolution (camera-resolution=2, the default) with 60 Hz frequency:
gst-launch-1.0 zedxonesrc camera-resolution=2 camera-fps=60 ! queue ! autovideoconvert ! queue ! fpsdisplaysink
