Offline Deployment
The ZED SDK downloads some data from the StereoLabs servers the first time it needs it. On a system without an internet connection, such as a robot operating in the field or a machine on a secured industrial network, these downloads fail and the application cannot open the camera or enable the requested module.
This page explains how to retrieve this data on a machine with internet access and copy it to the target system, so that the target system works without an internet connection.
What the ZED SDK Downloads at Runtime
Before their first use, AI models must also be optimized for the GPU of the system. The optimization does not require an internet connection once the model files are present, but it takes time: optimizing all the available models takes about 40 minutes on an NVIDIA® Jetson AGX Thor™ and about one hour on an NVIDIA® Jetson AGX Orin™. To check which models are already optimized on a system, see Check if the AI models are optimized.
Calibration Files
Option 1: Download the Calibration File Manually
- On any machine with internet access, open
https://calib.stereolabs.com/?SN=<serial_number>, replacing<serial_number>with the serial number printed on the camera label. The browser downloads theSN<serial_number>.conffile. - Copy the file into the
settingsfolder of the target system (see the table above). Create the folder if it does not exist. - Repeat for each camera that will be used on the target system.
If your application stores the calibration files in a different location, set InitParameters::optional_settings_path to the folder that contains them.
A calibration file only depends on the camera serial number. The same file can be copied to any system the camera will be connected to, regardless of the platform or of the ZED SDK version.
Option 2: Use the Calibration Stored on the Camera EEPROM
All cameras produced after May 2026, except the ZED Mini, store the factory calibration on their internal EEPROM. With ZED SDK v5.3 or newer, these cameras can be opened without a local calibration file and without an internet connection: the ZED SDK reads the EEPROM and generates the calibration file in the settings folder automatically. Since ZED SDK 5.6, the EEPROM is read before any download is attempted.
Older cameras can be provisioned once: connect the camera to a machine with internet access and write the factory calibration to its EEPROM with the ZED Explorer --dc (--download_calibration) option:
The camera can then be moved to the target system.
A calibration file in the settings folder always takes precedence over the EEPROM data. See Camera Calibration for the full selection order.
AI Models
The resources folder contains two kinds of files:
- Downloaded models (
*.model2files, and*.modelfiles depending on the model and on the ZED SDK version): generic files that do not depend on the GPU or on the platform. They can be copied to any system that runs the same ZED SDK version. - Optimized models (hidden files named
.<model_name>_optimized-<signature>, plus.*_timing_cachefiles): generated from the downloaded models for one specific hardware and software configuration.
The models are prepared with the following ZED Diagnostic options:
Add -c to run ZED Diagnostic in command line mode, without a GUI. Optimizing only the models used by your application, with -ais X and -nrlo*, is much faster than optimizing all of them with -aio.
Choose the option that matches your deployment.
Option 1: Target Identical to a Reference System
Use this option to deploy a fleet of identical units, for example several robots with the same NVIDIA® Jetson™ module. The optimized models are copied as-is, so the target system starts immediately without any optimization step.
The reference system and the target system must be identical: same GPU or Jetson module, same NVIDIA® driver or JetPack version, same CUDA and TensorRT versions, and same ZED SDK version. If any of these differ, the copied optimized models are ignored and the ZED SDK optimizes the models again on first use.
On the reference system, connected to the internet, download and optimize the models used by your application:
Copy the whole
resourcesfolder, including the hidden files, to the target system. For example, on Linux:
Option 2: Target Different from the Download System
Use this option when the system with internet access has a different GPU, platform, or software stack than the target system, for example a development PC preparing the models for an NVIDIA® Jetson™ device.
On the system with internet access, install the same ZED SDK version as the target system, then download the models without optimizing them:
For an application that only uses depth sensing,
-nrlo_allalso downloads all theNEURALdepth models, but it optimizes them for the local GPU as well. This takes much longer than a download and is unnecessary, since these optimized models cannot be reused on the target system: prefer-aid. -
Copy only the downloaded model files to the
resourcesfolder of the target system. The*.model*pattern does not match the hidden optimized files. For example, on Linux: -
On the target system, optimize the models before running your application, with
-aioor, to save time, with-ais Xand-nrlo*for the models your application uses. No internet connection is required, since the model files are already present:If you skip this step, the ZED SDK optimizes each model automatically the first time it is used, which delays the start of your application.
On Windows, use C:\Program Files (x86)\ZED SDK\tools\ZED Diagnostic.exe with the same options, and the C:\ProgramData\StereoLabs\resources\ folder.
The user running the ZED SDK application on the target system must be able to read the copied files and to write to the resources folder, where the ZED SDK stores the optimized models.
Docker Containers
A container’s filesystem is reset every time the container is recreated: the calibration files and AI models downloaded or optimized inside it are lost, and an offline system cannot download them again. Prepare the settings and resources folders on the host as described above, then bind-mount them into the container:
Alternatively, copy the two folders into the image at build time. In this case, include the optimized models only if the image runs on systems identical to the one that optimized them (see Option 1).
See Keep AI Models and Calibration Files Across Containers for more details on sharing these folders, and Cache AI models and calibration files across containers when several containers share the same host.
Checklist Before Deployment
- The ZED SDK version on the target system is the same as the one used to download the AI models.
- The
SN<serial_number>.conffile of every camera is in thesettingsfolder, or every camera has its calibration stored on the EEPROM. - The downloaded model files of every AI model used by the application are in the
resourcesfolder. - The AI models have been optimized on the target system, or copied from an identical reference system.
- The application has been tested on the target system with the network disconnected, and no download or optimization message is printed when the camera is opened and the modules are enabled.
Troubleshooting
When the data the ZED SDK needs is missing and no internet connection is available, the following errors are reported:
