Start by Use Case
The pages to follow for robotics, AI, body tracking, AR/VR and simulation
Each section lists the pages to read, in order, for a common use case. If you do not have your hardware yet, start with the Choose the hardware step of your use case, when it has one. Otherwise, make sure your camera works with Set Up Your Device, then go straight to the software steps.
Robotics
- Choose the hardware for your robot: Physical AI, Logistics Automation or Offroad Autonomy.
- Install the ZED ROS 2 Wrapper and view the camera data in RViz 2: Getting Started with ROS 2 and ZED.
- Enable the modules you need: Depth Sensing, ZED SLAM (Positional Tracking), Object Detection and Tracking.
- Add the camera to your robot model: Robot Integration, and Multi-Camera setup for several cameras.
- Accelerate your pipeline with NVIDIA® Isaac™ ROS 5, on a Jetson™ or an x86_64 PC: ZED Isaac™ ROS Integration Overview.
AI and object detection
- Try the built-in detection of the ZED SDK, which detects and tracks people, vehicles and other classes in 3D: Object Detection, then the Object Detection tutorial.
- Use your own YOLO model to get the 3D position and tracking of your own classes. See How to Use YOLO with ZED, then Exporting YOLO ONNX Models.
- Use any other detector: send its 2D detections to the ZED SDK with Custom Object Detection.
- Run detection in ROS 2: Object Detection and Tracking and Custom Object Detection and Tracking.
Body tracking and human interaction
- Choose the hardware: see Smart Infrastructure, which covers scene analysis and interactive applications.
- Track the skeletons with the ZED SDK: Body Tracking, then the Body Tracking tutorial.
- Cover a larger area with several cameras: calibrate them with ZED360, the multi-camera calibration tool, then merge their data with the Fusion module.
- Animate avatars in a game engine: run the ZED SDK on one machine and send the skeletons to Unreal Engine 5 or Unity with Live Link.
AR, VR and mixed reality
- Choose the hardware: see Smart Infrastructure, which covers mixed reality.
- Install the plugin for your engine: Getting Started with Unity and ZED (Windows, Ubuntu) or Getting Started with Unreal Engine and ZED (Windows).
- Build your first application: Build your First AR/MR Application and AR Video Passthrough in Unity, or AR/MR in Unreal Engine 5.
- Add the features you need:
- In Unity: Spatial Mapping, Body Tracking, Object Detection.
- In Unreal Engine 5: Spatial Mapping, Body Tracking, Object Detection.
Simulation
- Learn what the ZED Isaac™ Sim extension does and how your code can read the simulated camera: ZED Isaac™ Sim Extension Overview.
- Install the extension: Get Started with Isaac™ Sim.
- Add a ZED camera to your scene: Setting up the ZED in Isaac™ Sim.
- Connect it to your software:
- ROS 2: Using the ZED with ROS 2 in Isaac™ Sim
- Isaac™ Lab: Using the ZED in Isaac™ Lab
- Depth images without the ZED SDK: SDK-free depth capture
Other integrations
Docker, GStreamer, OpenCV, PyTorch, MATLAB and the other integrations are listed in the Software Integrations overview.
