ZED Link GMSL2 capture cards
Understand GMSL2 and set up ZED Link Mono, Duo and Quad cards on NVIDIA Jetson
If you recently purchased a StereoLabs ZED Link GMSL2 capture card, congratulations! This guide aims to help you become acquainted with the GMSL2 protocol and to give you the essential information you need to begin utilizing StereoLabs ZED Link GMSL2 capture cards with NVIDIA® Jetson™ devices and our GMSL2 stereo and monocular cameras.
What is GMSL2?
Gigabit Multimedia Serial Link (GMSL2) is a serial communication protocol that uses Analog Devices’ proprietary technology to transport high-speed, serialized data over coax or shielded-twisted pair (STP) cables for automotive camera and display applications. GMSL2 links operate at fixed data rates, including 3 Gbps or 6 Gbps on the forward channel, and 187Mbps on the reverse channel, depending on device capabilities and configuration. The figure shows a block diagram of a typical GMSL2 system.
Source: Analog Devices - GMSL2 Channel Specification User Guide - Rev 1
You can find detailed information about the GMSL2 configuration for our ZED Link cards in the respective datasheets.
The ZED X One Core does not use GMSL2. It streams MIPI CSI-2 data and requires a ZED Link MIPI capture card, described on the ZED Link MIPI capture cards page.
Setting up your system for using a GMSL2 camera
If you own a ZED Box, a ZED Box Mini, a ZED Box 2, or a ZED Box 2 Max, you can directly proceed to the guide to Install the ZED Link driver.
Make sure to have the necessary hardware to support the GMSL2 connection of the StereoLabs GMSL2 cameras. To choose the GMSL2 cables and their length, see GMSL2 Cables.
In this section, we will explain which configurations work with the GMSL2 capture cards and provide instructions on how to set them up.
Please note that our GMSL2 cameras are only compatible with NVIDIA® Jetson™ platforms. Here is the list of currently supported NVIDIA® Jetson™ models along with the corresponding setup guide link for your hardware.
NVIDIA® Jetson™ Xavier devices run JetPack 5. The latest ZED SDK no longer supports JetPack 5: the last release for JetPack 5.1.2 is ZED SDK 5.2, and the JetPack 5 drivers remain available on the drivers page. For new projects, choose a Jetson™ Orin™ or Jetson™ Thor™ platform. See Supported Platforms.
The ZED Box now includes GMSL2 connectivity as a standard feature. Older units could be purchased without a pre-installed GMSL2 capture card: that configuration is no longer available, and a capture card cannot be added to such a unit afterwards.
The ZED Box features a passive heat dissipation system that could be damaged if the device is disassembled, potentially causing failures and serious damage to the NVIDIA® Jetson™ module. As a result, the warranty will be void if the device is opened.
The ZED Link Mono enables you to connect ZED X, ZED X Mini, ZED X Nano, ZED X One GS, ZED X One S, or ZED X One 4K cameras to specific NVIDIA® Jetson™ devices:
Jetson™ deviceGMSL2 SupportGuide
NVIDIA® AGX Orin DevKit❌-
NVIDIA® Xavier AGX DevKit❌-
NVIDIA® Orin Nano DevKit✔️Setup Guide
NVIDIA® Xavier NX DevKit✔️Setup Guide
Other Jetson™ carrier boards-Please contact support@stereolabs.com
The ZED Link Duo enables you to connect ZED X, ZED X Mini, ZED X Nano, ZED X One GS, ZED X One S, or ZED X One 4K cameras to specific NVIDIA® Jetson™ devices:
NVIDIA® AGX Orin DevKit✔️Setup Guide
NVIDIA® Xavier AGX DevKit✔️Setup Guide
The ZED Link Quad enables you to connect ZED X, ZED X Mini, ZED X Nano, ZED X One GS, ZED X One S, or ZED X One 4K cameras to specific NVIDIA® Jetson™ devices:
NVIDIA® Orin Nano DevKit❌-
NVIDIA® Xavier NX DevKit❌-
Multi-Camera Combinations
Please refer to each of the setup guides for the ZED Link Duo and Quad capture cards to understand how to connect multiple cameras to the same capture card, and the different behaviors that can be expected according to the camera types and their connection ports on the capture card.
To synchronize cameras across capture cards or Jetson™ devices, or with an external trigger, see Multi-Camera Synchronization.
Specifications
See ZED Link GMSL2 Specifications for the complete hardware specifications of the ZED Link Mono, Duo and Quad capture cards, with the technical drawings, the 3D models, and the part numbers.
