Using Object Detection and Tracking with ROS 2
Enable object detection in the ZED ROS 2 Wrapper and display results in RViz 2
The Object Detection module can be configured to use one of the available detection models:
MODELDescription
MULTI_CLASS_BOX_FASTAny objects, bounding box based
MULTI_CLASS_BOX_MEDIUMAny objects, bounding box based, compromise between accuracy and speed
MULTI_CLASS_BOX_ACCURATEAny objects, bounding box based, more accurate but slower than the base model
PERSON_HEAD_BOX_FASTBounding Box detector specialized in person heads, particularly well suited for crowded environments, the person localization is also improved
PERSON_HEAD_BOX_ACCURATEBounding Box detector specialized in person heads, particularly well suited for crowded environments, the person localization is also improved, more accurate but slower than the base model
CUSTOM_YOLOLIKE_BOX_OBJECTSFor internal inference using your own custom YOLO-like model. This mode requires an ONNX file to be passed in the ObjectDetectionParameters. This model will be used for inference.
CUSTOM_RFDETRLIKE_BOX_OBJECTSSame as above, for an RF-DETR-like model. Requires ZED SDK >= 5.5
CUSTOM_BOX_OBJECTS_AUTODETECTSame as above, with the ZED SDK picking between YOLO-like and RF-DETR-like from the model outputs. Requires ZED SDK >= 5.5
The MULTI_CLASS_BOX and PERSON_HEAD_BOX modes use internal models that are provided and downloaded automatically by the SDK.
The three CUSTOM_* modes allow you to load your own ONNX model. The Custom Object Detection and Tracking with ROS 2 guide shows an example of how to export this model from a trained PyTorch model. This process must be done only once.
The result of the detection is published using a custom message of type zed_msgs/ObjectsStamped defined in the package zed_msgs.
Enable Object Detection
Object detection can be started automatically when the ZED Wrapper node starts by setting the parameter object_detection.od_enabled to true in the file common_stereo.yaml.
It is also possible to start the Object Detection processing manually by calling the service ~/enable_obj_det with the parameter True.
In both cases, the Object Detection processing can be stopped by calling the service ~/enable_obj_det with the parameter False.
The first time you run the ZED node with the object detection configuration, the SDK will optimize the model for the GPU used on the host device.
This process may take a long time, depending on the model size and the power of the GPU used. The optimized model will be saved in the /usr/local/zed/resources folder and reused in subsequent runs, which will no longer require the optimization process.
If the robot has no internet connection, the model files must be downloaded in advance. See the Offline Deployment guide.
[ZED][INFO] Please wait while the AI model is being optimized for your graphics card
This operation will be run only once and may take a few minutes
Object Detection results in RViz 2
To visualize the results of the Object Detection processing in RViz 2, the ZedOdDisplay plugin is required. The plugin is available in the zed-ros2-examples GitHub repository and can be installed following the online instructions.
The source code of the plugin is a valid example of how to process the data of the topics of type zed_msgs/ObjectsStamped.
Parameters:
  • Topic: Selects the object detection topic to visualize from the list of available topics in the combo box.
  • Depth: The depth of the incoming message queue.
  • History policy: Set the QoS history policy. Keep Last is suggested for performance and compatibility.
  • Reliability Policy: Set the QoS reliability policy. Best Effort is suggested for performance and compatibility.
  • Durability Policy: Set the QoS durability policy. Volatile is suggested for compatibility.
  • Transparency: the transparency level of the structures composing the detected objects.
  • Show skeleton: Not used.
  • Show Labels: enable/disable the visualization of the object label.
  • Show Bounding Boxes: enable/disable the visualization of the bounding boxes of the detected objects.
  • Link Size: the size of the bounding boxes’ corner lines.
  • Joint Radius: the radius of the spheres placed on the corners of the bounding boxes.
  • Label Scale: the scale of the label of the object.
