ZED Ecosystem
The ZED ecosystem has four parts. The ZED cameras capture stereo or monocular images. The ZED Box embedded PCs, built on NVIDIA® Jetson™, run the cameras and the ZED SDK. The ZED Link capture cards connect GMSL2 and MIPI cameras to Jetson™ developer kits. The ZED SDK turns the images into depth, tracking and detection. The integrations bring this data into ROS 2, AI frameworks and 3D engines.
To start with a new device, follow Set Up Your Device. To find the pages for your application, see Start by Use Case.
ZED SDK
The ZED SDK provides the modules below.
Code Samples
Start coding right away with the ZED SDK and explore its features with the following resources:
Discover the different ZED cameras and their specifications to find the one that best suits your needs. The Choosing Your Hardware guide and the Choose your camera steps help you select the camera, lens, sensor and options for your application.
Embedded devices
Discover the different ZED embedded devices and their specifications to find the one that best suits your needs. The ZED Box series page helps you select the host for your cameras.
Software Integrations
Integrations include ROS 2, NVIDIA® Isaac™ ROS and Isaac™ Sim, YOLO, Unity, Unreal Engine 5, Live Link, Docker, GStreamer, OpenCV, PyTorch and more. See the Software Integrations overview for the full list.
